seven 202 #1 Posted April 26, 2019 It won't stay running on low idle it's it's like it doesn't spark all the time it'll spark and then I'll miss a spark and then I'll spark some more it's just missing it does not have a coil on it I'm wondering if its the points or if I'm not sure? I don't think it's fuel related. It might be a weak batterybut I charged it and it still still does the same thing basically it has intermittent spark Share this post Link to post Share on other sites
Stepney 2,356 #2 Posted April 26, 2019 No coil? You probably have a magneto ignition then, is it a 1968 model? I converted mine to a 12v coil when my magneto failed. May not be original, but WH used that system for many many years, compared to a mag. Anyway. If the points are clean and set properly, I'd start with changing the condenser and doing an ohm. test on the coil. Could be breaking down internally. Share this post Link to post Share on other sites
seven 202 #3 Posted April 26, 2019 Well I've been having this problem Gor years now and pretty sure with some advice kinda like to go to a coil .not sure how thou Share this post Link to post Share on other sites
pfrederi 21,300 #4 Posted April 27, 2019 Just to be sure you have a Kohler motor. (In 1970 some Charger 12s had Tecumsehs). If you have the Kohler you will have to get a new ignition switch and an internally resisted coil. Share this post Link to post Share on other sites
