Marv 994 #1 Posted April 22, 2019 What are your thoughts on the UGL product Drylok? I need to do my basement walls. I am working on removing previous finish from the concrete block. Thinking about trying to sand blast it off. Not really looking forward to that though. Is Drylok the way to go for sealer? Marv Share this post Link to post Share on other sites
WHNJ701 4,171 #2 Posted April 22, 2019 I have a block house, I used dry lock with the 10 year rating. it was last painted in the 1960s, it took a lot, 10 gallons to do, I just scrapped it real good. also painted a 8" strip at the floor. it's basically thick white paint with sand mixed into to it. it helped brighten up the basement and the condensation. it doesn't solve water issues. Share this post Link to post Share on other sites
peter lena 9,785 #3 Posted April 22, 2019 having delt with this issue for years , first question ,water problem source? any way to divert or reduce water flow point? mine was a fire place lower ash box , that was flooding with ground water. waterproofing is temporary at best, drilled and tapped a hole in the bottom of ash box wall. install nipple and a " 1" pipe tee ", allowing me to drain out ,yet have access to route out a clog. garden hose to that and my sump pit , lets it naturally drain by it self, about a 3/8 " constant flow discharge . also went after town to clean out storm drains , reducing ground water. i know your problem is different , but if you can reduce / divert the ground water to your foundation , that will help out , pete Share this post Link to post Share on other sites
Marv 994 #4 Posted May 2, 2019 On 4/21/2019 at 8:40 PM, jabelman said: I have a block house, I used dry lock with the 10 year rating. it was last painted in the 1960s, it took a lot, 10 gallons to do, I just scrapped it real good. also painted a 8" strip at the floor. it's basically thick white paint with sand mixed into to it. it helped brighten up the basement and the condensation. it doesn't solve water issues. Thanks for that info. Marv Share this post Link to post Share on other sites
Marv 994 #5 Posted May 2, 2019 On 4/22/2019 at 8:15 AM, peter lena said: having delt with this issue for years , first question ,water problem source? any way to divert or reduce water flow point? mine was a fire place lower ash box , that was flooding with ground water. waterproofing is temporary at best, drilled and tapped a hole in the bottom of ash box wall. install nipple and a " 1" pipe tee ", allowing me to drain out ,yet have access to route out a clog. garden hose to that and my sump pit , lets it naturally drain by it self, about a 3/8 " constant flow discharge . also went after town to clean out storm drains , reducing ground water. i know your problem is different , but if you can reduce / divert the ground water to your foundation , that will help out , pete Pete, I am working that issue too in hopes it will solve the problem. thanks Marv Share this post Link to post Share on other sites
rjg854 12,868 #6 Posted May 2, 2019 I attacked my basement water problem by taking up the concrete 16" away from the walls and installing perimeter drainage and then to a daylight gravity drain. Then replacing the concrete. The foundation which is poured concrete, never had any type of drainage. Then drylocked the walls. I love my basement now. I used to call it the pit. Not totally dry, there is still a damp spot, but no longer floods. 1 Share this post Link to post Share on other sites
Dakota8338 115 #7 Posted May 3, 2019 On 4/21/2019 at 7:07 PM, Marv said: Can you install a 'French Drain' around the perimeter of the basement? Share this post Link to post Share on other sites
WHNJ701 4,171 #8 Posted May 3, 2019 take a good look at your gutters and make sure your leaders go far away from the house too 2 Share this post Link to post Share on other sites
953 nut 64,362 #9 Posted May 3, 2019 We had moisture problems at my church which had been "repaired" several times over a twenty year period. Five years ago we trenched two feet wide around the basement down to below the footers. The foundation was pressure washed and after it dried hot tar was sprayed on and insulation board was applied to the tar. Drainage pipes were laid in the trench and routed to the daylight side of the basement. The trench was then filled with coarse gravel topped off with rubber mulch. This approach seemed extreme, but the result has been a dry basement and about 2500 square feet of habitable space which had been unusable added to our Church. Share this post Link to post Share on other sites
