RetroMower
Can a puller be a good mower again?
RetroMower
Recently I saw a 98 520H for sale near me for $600. I believe these models are held in high regard but the problem is this tractor is a puller. Its bright blue with leds under it. The deck is there but no belt, belt guard or rollers. Is this a worthy candidate for a resurrection into a garden tractor again? Or has its life as a puller made its future unpredictable and expensive? I have not seen it in person but the pics show it in good condition. I will try to upload some pics soon
Guest 88vic
As long as the previous owner has record of fluid and filter changes, mainly for transmission, test drive it fully after it has reached operating temp. Check to see if anything changes such as ground speed, abnormal noises or leaks. If all checks out, I wouldnt be scared of purchasing it. These tractors are reliable and tough. Hope it works out in your favor, you can never go wrong with a horse.
RetroMower
I know these are tough units but competitive pulling is probably the most abuse one can inflict on any machine. My concern is in this case the possible looming dollar amount outweigh practicality. I know this is a tough question even to see it in person let alone some pics
Guest 88vic
You could always buy another 520 and keep it as a spare 😉.   What is the asking price on what youre looking at ?
Guest 88vic
Nevermind I re read your post.  I would see if he would be willing to accept $500. Just my input.
JAinVA
That looks to be an 89 or 90 model by the straight front axle.Probably the least sought after 520 in my opinion.If it it had the heavier front end and gear reduction steering it might be worth the asking price.If you want a mowing WH tractor I think I'd look elsewhere.Pennsylvania has tons of them.Just my 2 cents worth
RetroMower
This was my feeling as well. In my mind if he would come down to 300-400 it might be worth sinking a few dollars into it. But then again i could very well spot a mower tomorrow that suffered much less and is ready to mow and doesn't need a repaint
JAinVA
I spend a lot of time looking at pictures of items for sale.I hate to admit this but I missed the hood.That is no 520.
RetroMower
Being a novice WH guy i would have never noticed the missing louvers. Well this is an open and shut case. If this lad either doesn't know the model or is lying i cant trust anything he has to say about this unit. This is why it pays to seek expert advice here on :rs:
WVHillbilly520H
Also 520H doesn't have a break pedal on the right like a gear jammer (8spd).
JAinVA
Could have been the elusive 520-8.Just kidding,Jeff, I missed that feature as well.Getting old!
Edited by JAinVA
WVHillbilly520H
I barely caught it with that black lower band.
WHNJ701
great subject!  this 854 was an x puller.  it had a ridiculous stack, wheelie bar and a 1" pulley on the trans and a ton of stickers,  after that it was put outside til I got it.  I put it all back to working tractor which I use weekly in mowing season.
it needed motor work from sitting outside and water coming in from the stack.
RetroMower
Beautiful machine and exactly what i thought possible for this blue mystery. It too is adorned with led ground effect lighting, the term "monster creeper" on the back in mailbox letters and stickers showing hes got a mossy oak endorsement. I will keep looking tho. I feel bringing a puller back to its intended purpose is among the most noble reasons to rescue a WH.
EricF
To venture a guess, returning a Wheel Horse from puller to daily worker isn't much different from repairing/restoring any other Horse that's been  messed about with by a previous owner. Replace worn parts... remove non-stock parts and replace with correct (or your preferred) ones... repair/rebuild anything that needs it... repaint... and back to work she goes. Note: Check for cracks where the back end of the frame bolts to the transmission. This is a stress point that can be damaged in pulling. But it can also be damaged in regular work, too. It can be welded and repaired, there are reinforcements that can be made so it never happens again -- several threads about that here on Red Square. 520H frames can also suffer cracks in the middle of the frame from hanging the heavy 60" mower deck. Those, too, can be repaired. (520 frames are strengthened in the rear end from the factory, which makes them unique.)
Worst-case single issue would be if the differential inside the transaxle has been welded up solid for serious pulling. (No differential action means the axle stubs will act as a solid straight axle -- both wheels will always pull at the same speed, so no wiggling as one wheel gains or loses traction in relation to the other.) But, the diff assembly can be replaced. And if the previous owner got into the transaxle to mess with the diff, that means they already pulled the hubs off the axles to get in there. Which means somebody else has already done one of the least-liked tasks on these tractors -- pulling hubs! Pulling them again will be easier because they haven't had as much time to get stuck on with rust and crud.
Wheel Horses make good pullers because they're already sturdy and powerful enough off the factory floor to do serious work like plowing -- it doesn't take a lot of work and parts/customization to make pullers out of them. Which makes it not too hard to put them back the way they were. Just a matter of figuring out what you need to remove/replace/rebuild. Plenty of tractors that have done nothing but work have needed heavy rebuilding just because of neglect. A puller has probably received some mechanical attention just for safety, so having been a puller doesn't automatically make a a clapped-out candidate for the parts bin. More likely just another stage in the life of a remarkable piece of machinery.
Besides -- it makes a cool story. You can have a tractor that did hard work for years, got rescued from the scrap heap to entertain folks in pulling contests, and then got a "retirement" with some TLC and plenty more good, honest work ahead of it.
By the way, squinting at that picture makes me think the original tractor in question is more like a 318. Notice the size of the front wheels, and their size in relation to the rears. Also, I kind of doubt the weights hanging down are any kind of "permanent" modification -- it looks like somebody put some barbell weights on a bar that's latched into the center Attach-a-matic hitch. Even if they damaged the hitch somehow, like by grinding the jaws to hold a thicker bar, it's just another group of parts that can be replaced. The Kohler engine is rebuildable and largely bulletproof - and if this isn't a 520, then it should have a Kohler. (Onans can be rebuilt; but parts are more expensive.) Extra lights can be removed. Previous owners have a knack for messing up wiring even on workers, so you're no worse off there if you have to un-do PO mistakes with lights and wiring. Gear-drive transmissions are simple and rebuildable. Hydro units still have a variation of the Uni-Drive geared rear end, just made as a final drive for the hydro unit. Hydro pumps can be rebuilt or replaced.
Bottom line, if you can negotiate a good price, get it and have fun! If you want to learn how to take apart and restore these tractors, this might be a good candidate for learning on. Look around on Red Square and you'll see some amazing examples of "basket cases" and piles of parts that have been brought back to life as fully functioning tractors that look brand-new. Unlike restoring old cars, where there's a rapid descent into way to much money and time unless you have an extensive shop at your disposal plus plenty of time and skills, these old tractors are much friendlier to your time and budget. They're small, largely simple, and repairable with basic skills and easy-to-learn ones where things get (relatively) a little more "advanced."
  • Heart 1
RetroMower
Thank you for this in-depth and insightful response. I guess purchasing a barn find thats been hibernating for a decade and a puller pose many of the same challenges. But there is that tiny grey area where pullers suffer deliberate punishment now and then compared to the constant wear and tear if ground maintenance. Bottom line is pullers deserve the same chance of resurrection as any machine.
  • Similar Content
    • 84Workhorse
      By 84Workhorse
      '97 520H for sale; Reason for selling; I bought it about 6 years ago when my GT-1800 engine died which I will be re-powering so I have too many tractors and something has to go.
      I can provide more information and pictures if needed.
      Details:
      All shown in pics included in the price. 998 hours; Engine is in good condition 48 in. mowing deck in sound condition, no rust through 42 in. SS snow blower, I used it twice in 5 years, tire chains go with it 42 in. snow blade sat in my storage shed for the last 35+ years. Rear axle bracket does not go with it b/c I have a tiller for my GT All lights and gauges work with the exception of the engine load gauge. The vacuum nipple is broken off.
    • Chaz54
      By Chaz54
      Full set of NOS Wheel Horse Chrome Embossed Hubcaps for a 520H.
      Let me know if you have questions, need more information, pictures, etc.
      Buyer pays shipping. Located in Washington, MO 63090
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
