WHwest8597 85 #1 Posted April 13, 2019 I'm continuing to have problems with having my 315-8 cutting out after 10 minutes if running. I changed fuel filter. Pulling the choke doesn't help at all. After letting it sit a while it will start back up and run for 10 minutes and stop. Any suggestions. I have turned the gas cap back and still nothing. I have no problem starting at first. It runs, then stops, cools down, then will start up again. Thanks. Share this post Link to post Share on other sites
ebinmaine 73,043 #2 Posted April 13, 2019 Possibly something electronic? Bad condenser? Bad coil? Most times when something will run, die, cool, run again, it isn't in the fuel system... Share this post Link to post Share on other sites
WHwest8597 85 #3 Posted April 13, 2019 Are these items attached to the engine or behind the dash? Share this post Link to post Share on other sites
BOB ELLISON 2,981 #4 Posted April 14, 2019 I'm sure someone will chime in later but I think it's in the ignition module .it may fail after the engines runs a little while and the module gets hot. Run it till it stops and take the plug out. Ground the plug to see if it's firing a good blue spark. If not it may be the module. 1 Share this post Link to post Share on other sites
BOB ELLISON 2,981 #5 Posted April 14, 2019 Download the manual from the manual section if you haven't already and look at the wiring diagram it will show you where it is. I think there a little pricey. If so you can put a sd in the wanted section someone will have one cheaper I'm sure. Share this post Link to post Share on other sites
The Tuul Crib 7,339 #6 Posted April 14, 2019 315 -8 ? Do you have pictures? Share this post Link to post Share on other sites
ZXT 2,401 #7 Posted April 14, 2019 I'm going to hedge my bets on it being the ignition coil or module. When a coil starts to go bad, it will work when cool but it'll break down when it gets hot. Once it cools down, it'll run fine until it warms up again. As has already been stated, check for spark when the engine dies. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #8 Posted April 14, 2019 Sounds like a coil to me as well... I have a 315-8 that I just acquired last summer, starts easy runs smooth and quiet... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,532 #9 Posted April 14, 2019 This should be the parts list for the engine. Compare the engine numbers - CH15S-44533 https://www.partstree.com/parts/kohler-engines/engines-horizontal/ch15-44533-kohler-ch15-engine-command-pro-toro-15hp-11-2kw/ What I would do is make up a properly gapped spark plug with a ground lead to have ready when the engine quits. Run the tractor until it quits and immediately switch the spark plug lead to the test plug and see if you still have spark. The test plug has a hose clamp around the base of the plug that captures a length of wire with an alligator clip on the other end. Get the clip on a good known engine ground. The reason for this is these coils normally fire at say 20,000 to 30,000 volts. If the spark gap is too wide the voltage may go to 40,000 or more volts because the energy is in there and needs to be released. The problem is the coil insulation will not contain very high voltage so it can blow a hole in the insulation. It could happen inside the coil before the spark gets to the plug wire so you never see it and the coil is done. This caution at one time was in service manuals because in the early days the insulation was not as good as it is today but it still has it's limits with the insulation improvements. The key is the clip on the end of the ground wire must be grounded so the coil does not exceed it's normal limits. You do not want to ruin a possibly good coil testing it. Garry 1 Share this post Link to post Share on other sites
buckrancher 2,695 #10 Posted April 14, 2019 if you still have spark after it quits running you are vapor locking in the fuel system brian 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #11 Posted April 14, 2019 3 hours ago, gwest_ca said: This should be the parts list for the engine. Compare the engine numbers - CH15S-44533 https://www.partstree.com/parts/kohler-engines/engines-horizontal/ch15-44533-kohler-ch15-engine-command-pro-toro-15hp-11-2kw/ What I would do is make up a properly gapped spark plug with a ground lead to have ready when the engine quits. Run the tractor until it quits and immediately switch the spark plug lead to the test plug and see if you still have spark. The test plug has a hose clamp around the base of the plug that captures a length of wire with an alligator clip on the other end. Get the clip on a good known engine ground. The reason for this is these coils normally fire at say 20,000 to 30,000 volts. If the spark gap is too wide the voltage may go to 40,000 or more volts because the energy is in there and needs to be released. The problem is the coil insulation will not contain very high voltage so it can blow a hole in the insulation. It could happen inside the coil before the spark gets to the plug wire so you never see it and the coil is done. This caution at one time was in service manuals because in the early days the insulation was not as good as it is today but it still has it's limits with the insulation improvements. The key is the clip on the end of the ground wire must be grounded so the coil does not exceed it's normal limits. You do not want to ruin a possibly good coil testing it. Garry Or go to Harbor Freight and get yourself one of these...https://www.harborfreight.com/90-in-line-spark-checker-63593.html...it will do what Garry described above and can stay attached while running. Share this post Link to post Share on other sites
