csvt99 173 #1 Posted March 30, 2019 Hey Guys, I picked up 314-8 today with a 42" RD deck. Less than 300 hours, good shape but needs a cleaning. I will be using this for mowing as it was time to return my dad's Kubota and my 877 was smoking me out. Can you offer any maintenance tips or references? Common problems to watch out for? I wasn't sure I would like the gear drive because I love my hydro, but so far I love it. Thanks! 7 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #2 Posted March 30, 2019 Good maintenance guide in the operator's manual. Do you have the model number and serial number so we send you to the correct info. Garry Share this post Link to post Share on other sites
clueless 3,348 #3 Posted March 30, 2019 314-8 with a 42 inch deck with lees than 300 hr , should get you thru at least another 30 years, with a little maintenance . 5 Share this post Link to post Share on other sites
csvt99 173 #4 Posted March 30, 2019 Model number is 73449 Serial 9901070 I have the manuals for the tractor and deck from the original owner. He said it sat for the past few years but he would run it every now and then. Share this post Link to post Share on other sites
JAinVA 4,638 #5 Posted March 30, 2019 Looks like you got a keeper.Grease the front end with the front tires off the ground. Change the oil every 20 hours and it should last many years. 2 Share this post Link to post Share on other sites
csvt99 173 #6 Posted March 31, 2019 Ok great to know. Why do I need to lift the front end for greasing? I'm assuming I should just jack it enough to get the weight off? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #7 Posted March 31, 2019 23 minutes ago, csvt99 said: Model number is 73449 Serial 9901070 I have the manuals for the tractor and deck from the original owner. He said it sat for the past few years but he would run it every now and then. This is what we have for the 1999 314-8 https://www.wheelhorseforum.com/search/?&q=1999 314-8&type=downloads_file&search_and_or=or&sortby=relevancy Garry 1 Share this post Link to post Share on other sites
csvt99 173 #8 Posted March 31, 2019 Wow! Thank you so much. You guys are awesome! Share this post Link to post Share on other sites
JAinVA 4,638 #9 Posted March 31, 2019 (edited) If you grease the machine with weight on the wheels it doesn't always get to the areas where the most metal to metal pressure is.With the front end lifted slightly grease you will have a better chance to it get where it is needed rather than just squirting out.Hope this makes sense.If it doesn't do it anyway for longer life. Edited March 31, 2019 by JAinVA 4 Share this post Link to post Share on other sites
953 nut 64,115 #10 Posted March 31, 2019 Looks like it has been well taken care of. Keep up he maintenance and you will be driving it forever! 2 Share this post Link to post Share on other sites
csvt99 173 #11 Posted March 31, 2019 This makes perfect sense. Would have never known, but I will make sure to do it. It was definitely steering harder than my 877. Share this post Link to post Share on other sites
roadapples 6,987 #12 Posted March 31, 2019 If it steers hard after greasing, a little toe in may make a big difference... 1 Share this post Link to post Share on other sites
csvt99 173 #13 Posted March 31, 2019 7 hours ago, roadapples said: If it steers hard after greasing, a little toe in may make a big difference... Thank you for the suggestion. I checked it last night after reading about the alignment in the manual. It looks okay but it definitely isn't toe in 1/4" or any at all. When it comes time to address it I will likely start a separate post if I have questions. Tinkering with this tractor is going to be fun! 1 Share this post Link to post Share on other sites
953 nut 64,115 #14 Posted March 31, 2019 Low air pressure can make the steering hard too. The book calls for 8 PSI, but I run about 12 PSI on my 418-C and find it steers much better. 4 Share this post Link to post Share on other sites
ebinmaine 77,335 #15 Posted March 31, 2019 3 minutes ago, csvt99 said: Tinkering with this tractor is going to be fun Hey welcome to the addiction !!! Seriously... Nice machine there. You'll find absolutely everything you need here on the site. Awesome bunch of folks. 3 Share this post Link to post Share on other sites
wildman 205 #16 Posted March 31, 2019 Very nice score 1 Share this post Link to post Share on other sites
classiccat 548 #17 Posted March 31, 2019 (edited) congrats! That machine looks well maintained! Very nice find! Edited March 31, 2019 by classiccat Share this post Link to post Share on other sites
peter lena 9,764 #18 Posted March 31, 2019 CSFT99 , how do the new guys always find the great stuff ? terrific find , doing a baseline service , checking over everything and servicing it will establish what you have, not that is isin,t already like new , let me get my druel cup . you might wipe down those painted surfaces with WD40 , to feed the and enhance the paint. just doing that will make that horse , pop with shine. keep us in the loop , thanks pete Share this post Link to post Share on other sites
csvt99 173 #19 Posted March 31, 2019 18 minutes ago, peter lena said: CSFT99 , how do the new guys always find the great stuff ? terrific find , doing a baseline service , checking over everything and servicing it will establish what you have, not that is isin,t already like new , let me get my druel cup . you might wipe down those painted surfaces with WD40 , to feed the and enhance the paint. just doing that will make that horse , pop with shine. keep us in the loop , thanks pete Pete, thank you for your words of affirmation. It means a lot to have my decision supported by fellow horse nuts. In my defense I have been looking for almost a year before pulling the trigger, so a little patience goes a long way. AND I learned how to mow on my grandfather's 1277 many moons ago. See attached picture for proof! 1 5 3 Share this post Link to post Share on other sites
Sarge 3,470 #20 Posted March 31, 2019 Sounds like you need to hunt around and find one of the 1277 models - they do pop up every so often but be prepared to have to find some replacement, original parts as most have been pretty abused. I have one here that was my first Horse, love it and you can't beat the classic long-hood look of that model. The mid to late 60's tractors are my favorite since they are the most simple to work on and don't have all the running boards and other covers in the way of swapping implements - not to mention the classic big tractor look and elegance. Lifting the front of the tractor by the frame, not the axle will go a long way to protect your front steering spindles and axle center pin. Those areas won't get greased with the tractor's weight on them - lift it carefully by the frame and do not use the cross tube on the bottom of a mule drive - or you'll bend it badly. Btw, welcome aboard. Sarge 1 Share this post Link to post Share on other sites
cschannuth 3,819 #21 Posted March 31, 2019 12 hours ago, csvt99 said: This makes perfect sense. Would have never known, but I will make sure to do it. It was definitely steering harder than my 877. I also have a very low hour 2000 314-8 it steers harder than any thing else that I have. I’ve tried everything and nothing seems to make much difference. Everything is tight and looks brand new. It’s a strange thing but I love it because it’s so tight and so quiet. 2 Share this post Link to post Share on other sites
oliver2-44 11,213 #22 Posted March 31, 2019 42 minutes ago, csvt99 said: Pete, thank you for your words of affirmation. It means a lot to have my decision supported by fellow horse nuts. In my defense I have been looking for almost a year before pulling the trigger, so a little patience goes a long way. AND I learned how to mow on my grandfather's 1277 many moons ago. See attached picture for proof! Thats a great picture and I sure good memories Share this post Link to post Share on other sites
ericj 1,579 #23 Posted March 31, 2019 I bought a 99 314-8 brand new. Used it for everything for several years, till I started collecting more tractors and didn't need it anymore for active duty. I then retired it with 300 + hrs on it. It now sits in my enclosed trailer and comes out for shows. Good luck with your wheel horse prize. eric j Share this post Link to post Share on other sites
LengerichKA88 1,885 #24 Posted March 31, 2019 That’s a good looking machine! Welcome to Red Square, this is the best site on the web! Share this post Link to post Share on other sites
Lee1977 7,553 #25 Posted March 31, 2019 Check the tab on the back side of the axle pivot they are usually broken. Clean the under side of the deck at least one a year and protect it from rust or anytime you have it off during the summer. Some of us paint the under side of the deck others oil them, and some used other products. One thing I do is prime and paint the aluminum spindle housing as the acid in the grass eats away at the aluminum. I have a 42" deck I got with a tractor that the aluminum housings are almost eaten trough. 1 Share this post Link to post Share on other sites
