troutbum70 858 #1 Posted March 25, 2019 The story is that brake drum is even more stubborn than my wife of 46 years, little over a week at it and still have yet to get that bugger to budge. Have tried to brands of penetrates, tried heating and sweating wax into around shaft. My puller is a 2 arm puller, wondering if the purchase of a 3 arm puller would give any advantage? Share this post Link to post Share on other sites
JAinVA 4,638 #2 Posted March 25, 2019 Doubt it.I get crazy with stuff like this.I was trying to get a truck moved that had a brake that would not let go.Hammer didn't help so out comes the sawsall Brake drums are a dime a dozen.Protect the shaft but don't worry about the drum.Just me but I would break out the angle grinder. Share this post Link to post Share on other sites
bc.gold 3,406 #3 Posted March 25, 2019 (edited) In your case you need to spray penetrating oil onto the drum while vibrating it with your pneumatic chisel. This is how I loosened the clutch plates in a John Deere model 70 that were rusted in solid. Edited March 25, 2019 by bcgold Share this post Link to post Share on other sites
ebinmaine 79,141 #4 Posted March 25, 2019 5 hours ago, troutbum63 said: that brake drum is even more stubborn than my wife of 46 years Ouch!! Well that should tell ya right there that you may need to go to Plan CWS. (Cut with something). Bc has a decent idea too. The extreme vibration of an air hammer and blunt tip on the outside of the drum could help. Patience is your friend if you want to save the drum but like JA I think I'd go to cutting by now too. Share this post Link to post Share on other sites
JoeM 10,035 #5 Posted March 25, 2019 Might try all three at one time. Install puller and tension, heat center section of drum, and apply a few wacks with hammer. Not a sledge! If it is a no go, then I am with JA, good cutting disc on a angle grinder. Penetrating fluid just makes you fill better, when you have mechanical binding. Rusted parts it may help. Share this post Link to post Share on other sites
bc.gold 3,406 #6 Posted March 25, 2019 4 hours ago, OILUJ52 said: Might try all three at one time. Install puller and tension, heat center section of drum, and apply a few wacks with hammer. Not a sledge! If it is a no go, then I am with JA, good cutting disc on a angle grinder. Penetrating fluid just makes you fill better, when you have mechanical binding. Rusted parts it may help. Like magic the vibration from the pneumatic hammer works the penetrating fluid into the hidden rust and washes it out which in turn loosens up the part. Share this post Link to post Share on other sites
troutbum70 858 #7 Posted March 25, 2019 I have applied tension, heat and 6lb. hammer at same time. Have not considered the pneumatic hammer, so that will be next approach. I leave the puller cranked down on it thinking at some point it may give up and come loose, as a last resort I will attempt cutting. Share this post Link to post Share on other sites
ebinmaine 79,141 #8 Posted March 25, 2019 41 minutes ago, troutbum63 said: I have applied tension, heat and 6lb. hammer at same time. Have not considered the pneumatic hammer, so that will be next approach. I leave the puller cranked down on it thinking at some point it may give up and come loose, as a last resort I will attempt cutting. I believe it's a good idea to leave the puller on there all the time. You are most certainly headed the right direction. It's about 99% likely that it would eventually come off given enough patience. It's just a matter of the ratio of Need for tractor vs that same patience. Share this post Link to post Share on other sites
troutbum70 858 #9 Posted March 25, 2019 No hurry I do have a good bit of yard clean up pending, but my commando 800 can tote the yard wagon around for that. 2 Share this post Link to post Share on other sites
JoeM 10,035 #10 Posted March 25, 2019 One other thing that may work is if there is a little end play in the shaft. Might be able to drive a couple wedges behind the drum and tap the shaft inward to break it free. ??? Share this post Link to post Share on other sites
squonk 46,857 #11 Posted March 25, 2019 Put tension on the pulley with the puller and apply heat at the same time. Share this post Link to post Share on other sites
troutbum70 858 #12 Posted March 28, 2019 Well finally got this bugger off, but as you can see I really beat the tar out of it and cracked it as well. I have another 417 but it sits way out in the back and no way easy to move it so not sure if I can get the drum off it. Any one have any idea if new ones are available or if only finding a used one. 1 Share this post Link to post Share on other sites
JoeM 10,035 #13 Posted March 28, 2019 I would give that used on a try. I know this one was tough but I have seen them when I thought they would not come off, they slide right off. Used in good condition is good too. I would take that old one and drive a nail through it into the shop walk............kind of like a trophy! 3 1 Share this post Link to post Share on other sites
ebinmaine 79,141 #14 Posted March 28, 2019 Yeah like Joe said... A good used one is perfectly fine. Post an in the wanted section of the classifieds or just call Lincoln at A to Z. He'll have one. Share this post Link to post Share on other sites
troutbum70 858 #15 Posted March 28, 2019 Well I have to check the other 417 as it is a hydro tractor so not sure if it is the same drum as the 8 speed, I know the brake bands themselves are different as how they mount. I have a fellow about 25 miles away that used to be a wheel horse dealer and he has a few things around along with some old tractors. Share this post Link to post Share on other sites
stevasaurus 23,708 #16 Posted March 29, 2019 That is one heck of a paper weight !! That could be a calendar shot. Go to A-Z and get a used one. Troutbum.....1 Brake drum..0 Share this post Link to post Share on other sites
troutbum70 858 #17 Posted March 29, 2019 I have a chassis out back and went back there today with a 6 foot pry bar and the one on that tractor after fourth try with pry bar it slid right off, as you can see from the picture the one on my running tractor put up a true fight. Fer sure when the replacement goes on it will a good coating of rust preventive. 1 Share this post Link to post Share on other sites
troutbum70 858 #19 Posted March 30, 2019 That's probably great stuff, I have anti-seize marketed by caterpillar several years ago. I have had very good luck with it on my 18 wheelers, my truck was almost as old as my wh 417 and there wasn't a nut or bolt that couldn't be readily be taken off with the hand tools I carried on the truck. Off which some of course required the 3/4 drive. I probably have more than I will use up now as I sold the truck and all and retired a couple years ago, a little bit of the stuff goes a long way. I have no idea who would have produced the stuff for caterpillar. I did notice the product you provided a picture of has a very high temp resistance, not sure if what I have would hold up to that temp. 1 Share this post Link to post Share on other sites
ebinmaine 79,141 #20 Posted March 30, 2019 1 hour ago, troutbum63 said: truck He said truck. I like trucks. Alot..... 1 Share this post Link to post Share on other sites
classiccat 548 #21 Posted March 30, 2019 2 hours ago, troutbum63 said: That's probably great stuff, I have anti-seize marketed by caterpillar several years ago. I have had very good luck with it on my 18 wheelers, my truck was almost as old as my wh 417 and there wasn't a nut or bolt that couldn't be readily be taken off with the hand tools I carried on the truck. Off which some of course required the 3/4 drive. I probably have more than I will use up now as I sold the truck and all and retired a couple years ago, a little bit of the stuff goes a long way. I have no idea who would have produced the stuff for caterpillar. I did notice the product you provided a picture of has a very high temp resistance, not sure if what I have would hold up to that temp. Congrats on getting that sucka off! Did the caterpillar stuff end-up everywhere like Permatex? Share this post Link to post Share on other sites
troutbum70 858 #22 Posted March 30, 2019 Well I suppose if one mishandled it, then it could be easily worn. But its like the old hair cream back in the day, ya know a little dab will do ya hi hi. My complaint with Permatex has always been its packaging, back in the day of using it my dad and I would open a new container scrape the applicator clean as much as possible back into container, then give the applicator a good gas bath, cut the applicator free from the lid and keep the applicator in a little bit of kerosene to prevent drying out then we could get a dab on the brush and apply with no mess and put the applicator back in our separate little jar. Way back then I think Permatex is all there was and before that everything got a little axle grease before going back together. 1 Share this post Link to post Share on other sites
