Roym 2 #1 Posted March 5, 2019 Hello I recently aquired a 1989 414-8 with 1300 hours on the meter, The headlights are not working and there is a dark green wire with a female lead hanging in front of and below the battery compartment coming from the front of the tractor which is not attached to anything. With the length of this wire I cannot see what it could attach to. I have cleaned all ground connections, installed new 15 amp fuses (they no longer blow when I attempt to turn the lights on at the switch ???), tested the headlights themselves, bypassed the light switch, and installed a grounded led fixture as a taillight where there were reflectors installed with grommets. I am thinking (not being experienced at this) that the ignition switch may be next in line but that hanging wire is driving me a little crazy. Any suggestions ?? Thank you Share this post Link to post Share on other sites
pfrederi 20,998 #2 Posted March 5, 2019 Welcome to red square. Wiring diagrams for you r 414-8 are here click on the tractor picture Share this post Link to post Share on other sites
WHX?? 57,645 #3 Posted March 5, 2019 Is there a way to trace the wire back to it's point of origin. Guessing you have a multi meter or simple 12v tester is there power on that lead to ground with the headlight and/or light switch in the on positions? Share this post Link to post Share on other sites
953 nut 68,178 #4 Posted March 5, 2019 3 hours ago, Roym said: I am thinking (not being experienced at this) that the ignition switch may be next in line If your volt meter and/or hour meter are working with the key in the "ON/RUN" position then the ignition switch and 15 amp fuse are OK. Is there power to and from the light switch? Share this post Link to post Share on other sites
Roym 2 #5 Posted March 6, 2019 Thank you for your responses and the welcome. I have a 12 volt tester and will check power from ignition switch to light switch and from switch to lights as well as the “mystery” wire which I will attempt to track back to its origin. 1 Share this post Link to post Share on other sites
Roym 2 #6 Posted March 8, 2019 Sorry for the delay getting back here but the cold has been unbearable in my unseated shed. I cleaned all grounds and the switch terminals and wired and grounded a rear light. The rear light worked off the switch but the front lights didn’t so I will replace the wire from the switch to the front lamps and hope they work. 1 Share this post Link to post Share on other sites
squonk 47,773 #7 Posted March 8, 2019 Make sure your hood is grounded! 1 Share this post Link to post Share on other sites
Roym 2 #8 Posted March 8, 2019 Thanks Mike, I will check that first thing in the am Roy Share this post Link to post Share on other sites
Roym 2 #9 Posted March 10, 2019 Mike You were on the money. I replaced the hood to chassis ground and..........lights front and rear! Thank you for the advice. I deeply appreciate your insight and this forum. Royals Share this post Link to post Share on other sites
