Anthony Wendover 124 #1 Posted March 28, 2009 I put the new 48" deck on the tractor and took the blower and snow cab off last night. I do have a issue though. I can Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #2 Posted March 28, 2009 Check to see if the rubber stops one the mower carriage are contacting the bottom of the footrests when the mower is completely raised. If they are not, you'll need to adjust the lift link eyebolt per the following IPL: (nos 20/22) Because of the "thickness" or height of the WH decks and the mounting carriages, they do not clear the ground by much when in the fully raised position. It is not uncommon for the gauge wheels to skim along on the ground with the mower raised - especially if you have them set for a higher cutting height. Share this post Link to post Share on other sites
C-Series14 15 #3 Posted March 28, 2009 TT is correct and just for added info, I put my deck wheels to lowest setting while the deck is raised and not in use... Share this post Link to post Share on other sites
Anthony Wendover 124 #4 Posted March 30, 2009 When the deck is raised the rubber stops are about 3 or 4 inches away from the footrests.. I took the deck off and took the chain off and I can Share this post Link to post Share on other sites
Anthony Wendover 124 #5 Posted April 1, 2009 Whelp I adjusted the front of the deck to level it out in the lift position. I then cranked that nut just to the point of just being able to push the lift button. So its ass end is up now about a inch I think it is... Share this post Link to post Share on other sites
