osubrutus1 3 #1 Posted February 18, 2019 does anyone know if a mower deck form a 314-A will fit on a C-175? Share this post Link to post Share on other sites
Stepney 2,356 #2 Posted February 18, 2019 Shouldn't be an issue. Pretty much every tach-A-Matic deck fits any of the T-A-M tractors. With exception to the 60" and 37"sd. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #3 Posted February 19, 2019 22 hours ago, osubrutus1 said: does anyone know if a mower deck form a 314-A will fit on a C-175? First of all to Do you mean a 314-8? Share this post Link to post Share on other sites
osubrutus1 3 #4 Posted February 19, 2019 No, its A, hydro. Im going tomorrow to look at it. It has a 42" deck I was needing for my C-175. Now Im trying to decide if I should sell the C-175 and keep my blade and tiller or take deck from 314 and sell the tractor. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,455 #5 Posted February 20, 2019 The 42" decks sold for the oldest C-175 twin were 05-42MR01 rear discharge 05-42MS01 side discharge The decks sold for the 1985 314-A were 05-42MR03 rear discharge 05-42MS04 side discharge The decks on both tractors could be older or newer. Here is a list of the decks in the order they were produced for the long frame tractors Rear discharge Mower DNA 1976 model 65-42MR01 replaced by - (Has the flat spindle belt idler pulley mounted on a triangular plate.) 1977 model 75-42MR01 - Both decks use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded. (Has the flat spindle belt idler pulley mounted on a triangular plate.) ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1977 model 75-42MR02 replaced by 1978 model 85-42MR01 1979 model 95-42MR01 1979 model 95-42MR02 1980-1983 model 05-42MR01 1984 model 05-42MR02 1985 model 05-42MR03 1986-1988 model 05-42MR04 1989-1990 model 15-42RC01 1990-1992 model 15-42RC02 1993-2012 model 78350 - (These decks use blades with 3/4" center hole) Side discharge Mower DNA 1966-1967 model RL-426 replaced by 1968 model 5-1421 1969 model 5-1422 1970 model 5-1423 1971 model 5-1000 1971-1972 model 5-1001 1973-1974 model 5-1010 1975 model 5-1011 1975 model 5-1012 1976 model 65-42MS01 1976 model 65-42MS02 1977 model 75-42MS01 - These 42" side discharge decks all use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1977 model 75-42MS02 replaced by 1978 model 85-42MS01 1979 model 95-42MS00 1979 model 95-42MS01 1980 model 05-42MS01 1981-1983 model 05-42MS02 1984 model 05-42MS03 1985 model 05-42MS04 1986-1988 model 05-42MS05 1989 model 15-42SC01 1990 model 15-42SC02 1990-1992 model 15-42SC03 1993-2007 and 2009-2012 model 78345 - These decks all use blades with a 3/4" center hole. Garry Share this post Link to post Share on other sites
