The Tuul Crib 7,340 #1 Posted February 17, 2019 I recently went to Napa and found a grease Seal for the PTO bell. Till now I have not thought about adding grease to this location. There is no grease zerk in this area. The grease seal was a 14810. Does anyone else grease these needle bearing often ? Share this post Link to post Share on other sites
Jojoca 49 #2 Posted February 17, 2019 Yes you should smear wheel bearing grease on them Periodically. 1 Share this post Link to post Share on other sites
cleat 8,118 #3 Posted February 17, 2019 Not too often. And not too much, just a little on you finger and spread it on the bearing then slide the PTO back together and give it a spin. It should spin easily and quietly. 2 Share this post Link to post Share on other sites
lynnmor 8,268 #4 Posted February 17, 2019 Because of engine heat, I wash out all the old grease and use synthetic grease that won't melt. 2 1 Share this post Link to post Share on other sites
WHX?? 53,379 #5 Posted February 17, 2019 Good idea Lynn, I have just been using wheel bearing grease but will have to get a tub of syn. A small dab on the seal to avoid seal burn. Share this post Link to post Share on other sites
peter lena 9,567 #6 Posted February 17, 2019 agree with lynnmor on the synthetic grease, the spin up is quicker and smoother , use synthetic lube at all related points. if you add washers at the pto lever rod starting point, next to battery platform , and firm up its initial movement, it will transform its engagement, mine is so smooth its effortless. I finished mine off with a HEIM JOINT at the engine lever end. pete 1 Share this post Link to post Share on other sites
ebinmaine 75,834 #7 Posted February 17, 2019 33 minutes ago, peter lena said: agree with lynnmor on the synthetic grease, the spin up is quicker and smoother , use synthetic lube at all related points. if you add washers at the pto lever rod starting point, next to battery platform , and firm up its initial movement, it will transform its engagement, mine is so smooth its effortless. I finished mine off with a HEIM JOINT at the engine lever end. pete I wouldn't mind seeing a picture of that whenever you get a chance..... 2 Share this post Link to post Share on other sites
oliver2-44 11,076 #8 Posted February 17, 2019 (edited) @peter lena I to would appreciate a picture of that Helm Joint on the PTO rod Edited February 17, 2019 by oliver2-44 1 Share this post Link to post Share on other sites
peter lena 9,567 #10 Posted February 17, 2019 adding a heim joint to pto rod, having done this many times , http://www.wheelhorse.org/phpBB3/viewtopic.php?f=3&t=7483 this is a no brainer, simple and easy, to over thread the 3/8"x 16 thread on rod to a 3/8" x 24 fine thread to match the heim joint thread. I just match the joint against what is there for fitment, on the pictures # 3 and # 5 are the pto rod. adding this, and firming up the start of rod movement next to battery ( taking out all the play in angular movement with washers and lubricant ) make this lever work like magic. its easy, give it a try. Pete 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #11 Posted February 17, 2019 I'll have give the synthetic grease a try for myself . Probably will do this on the yearly maintenance list! 1 Share this post Link to post Share on other sites
