ericl72
Shifting problems
ericl72
Hi,
I have a Wheel Horse D250 tractor. I bought it used a couple of  years ago and only ran it once before a set screw on the shifter handle went bad. To fix it I took the housing off, disassembled the shafts and forks fixed the set screw and put it back together. It only will shift into 2 of 4 gears. I haven't started the engine yet. If I start the engine will this help? Advice or an assembly schematic of the forks would help.
Also the transmission did not have anything in the case. What should it have? ATF or hydraulic fluid? Thanks.
stevasaurus
Can you post a model number of the horse, or tell us what year you think it is??
This link may help...
953 nut
I wouldn't start the engine quite yet.   The first thing I would suggest would be to jack up one rear tire and try to turn the transmission in neutral and then attempt to shift the gears again.
gwest_ca
Click on the blank space above the Tractor 1976 D-250 ......... Then click of the pictures that come up on the next page. Two of them are from the lube charts. One gives you code letters/numbers that are on the second page.
Garry
The Tuul Crib
:text-welcomeconfetti:to :rs:
:wwp:
ericl72
I will post more information  in the morning. Thanks for the comments so far.
KC9KAS
@ericl72 :text-welcomeconfetti: to :rs:
Sounds like the shift forks are not where they are supposed to be.
ericl72
Hi,
I went out and did chores this morning and tried to take pictures. The tarp covering my tractor is frozen to the ground. Near Durand, Illinois. I'll look over the attachments that have been sent and reply when it warms up a bit. Thanks.
ericl72
Once it warms up I'll check the forks to make sure I installed them correctly. In the mean time stay warm. Thanks.
  • Similar Content
    • HotRodMike
      By HotRodMike
      Just picked up a 312 8 Tractor, Shifter handle is very loose and it won't go into none of the gears. Any ideas? Fixes?
    • 'garGuyPaulie
      By 'garGuyPaulie
      Hello all - I have a 1990 312-8 that recently started being a pain to shift, and eventually it stopped shifting into 1st and reverse and was hard to get into 2nd and 3rd. After looking at some posts on here I discovered the possibility that a loose shifter could cause this problem. My shifter definitely had a lot of play in it so I proceeded to pull the seat, rear plate and shift plate off the tractor so I could get to the area where the shifter goes into the transmission. I removed the shifter, reseated it and got the dog head screw lined up in the shifter donut and was hoping that would fix the issue, but after getting it all reassembled and trying to shift even into 2nd or 3rd the shifter, while not as sloppy, now just turns side to side - taking it back out and inspecting the shifter I have discovered that the pin which holds the donut in place on the shifter has sheered and the donut is now able to free spin on the shaft. Not too much of a problem as I plan on just pressing the old pin out and replacing, however I am concerned that the ball on the end of the shifter seems to be getting pretty flattened off on the left and right sides of the ball. I tried looking up a replacement on Toro and several other parts websites but I can't find one anywhere - I can get the boot, everyone has those, but no shifter. My question is, does anyone know where I might be able to find a new shifter and more important, is a little flattening on the ball anything to worry about?
      Also, with the shifter out, looking down the hole my transmission looks like it's full of mud! Definitely doesn't look like the gear oil I put in it - anyone know what could be causing the transmission gear oil to be sludging up like that?
    • Team70R
      By Team70R
      Just picked up an old 60's model I believe! Still unsure of the model but that's for another day!  Anyway the shifter broke off right at the case. What's the safest way of getting the broken half out? I believe it's a 3 speed
