roadapples 6,987 #26 Posted February 7, 2019 Short answer, no. But you'll love it with a loader... 1 Share this post Link to post Share on other sites
Jojoca 49 #27 Posted February 8, 2019 How much money would you say that you have into the loader only minus the tractor? Share this post Link to post Share on other sites
MalMac 1,336 #28 Posted February 8, 2019 You don’t have to have the reduction steering to use the swept axel. You will need the tie rods. If you are going to use your existing lower steering shaft you will need to add a extension plate on the shaft because the 520 tie rods will not mount to a standard lower shaft. Unless the lower shaft came off a 1990 520. The 90 520 had standard fan gear steering with the swept axel. 1 Share this post Link to post Share on other sites
JoeM 10,080 #29 Posted February 13, 2019 looks like you have enough room in front of the wheels of a sweep axle to clear loader frame when down. Some homegrown ones come pretty close. Share this post Link to post Share on other sites
