clueless 3,438 #1 Posted February 2, 2019 I'm replacing the clutch plate on my c160, the pto needle bearing looks to be in good shape, the ball bearing is a little questionable. Is there a NAPA number for the 5196/109842 bearing and the 6663 oil seal? Also after removing the two snap ring is the bearing easy to remove? First time doing this, looks fairly easy. Share this post Link to post Share on other sites
squonk 48,076 #2 Posted February 2, 2019 Napa PP204RR6 or 704250 SME Bearing. Don't have a seal # Share this post Link to post Share on other sites
pfrederi 21,145 #3 Posted February 2, 2019 WH6663 is CR 14810 Share this post Link to post Share on other sites
clueless 3,438 #4 Posted February 9, 2019 (edited) Okay, got my new outer bearing and oil seal. Got the old bearing out and had to soak the PTO stub shaft with some penetrating oil and after about an hour and a little coaxing with a punch and a hammer it came off the bearing. Now what's the best way to install the shaft and the bearing, the shaft looks like it's going to take a little persuasion to slide into the bearing. It's tighter than Dicks hat band, for you younger guys that's tight. While I'm a BFH kinda guy I don't think that's the way to go . As always any advice is appreciated. Edited February 9, 2019 by clueless Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted February 9, 2019 I'd like to help you on this one but when I got this tractor the PTO bell was off and all I had to do was to treat it to electrolysis then the bearing popped right out Share this post Link to post Share on other sites
pfrederi 21,145 #6 Posted February 9, 2019 Usually best way to deal with the interference fit of a bearing is a press. Share this post Link to post Share on other sites
squonk 48,076 #7 Posted February 9, 2019 I usually get the outer brg in by tapping it in with a hammer and punch. You can freeze the new bearing in you Frigidaire freezer and heat you PTO bell in your Magic Chef oven if you like to make it go easier. Just check your dinner a few nights to make sure you're not getting too much iron in your diet! 1 Share this post Link to post Share on other sites
lynnmor 9,038 #8 Posted February 10, 2019 If you badlly mushroomed the old shaft, replace it. If it is just rusty and dirty, file any burrs and clean with sandpaper. Properly prepared, it should tap in easily. I have had some that were too loose and needed Locktite 603. Share this post Link to post Share on other sites
clueless 3,438 #9 Posted February 18, 2019 Next question, replaced the out bearing and cleaned the needle bearing and used a little syn grease on it. Put a new oil seal on, should the seal be flush with the clutch plate or down against the bearing? There is about a 1/8" gap. Share this post Link to post Share on other sites
cleat 9,324 #10 Posted February 18, 2019 I believe mine are all flush. Share this post Link to post Share on other sites
Racinbob 13,135 #11 Posted February 18, 2019 Yes, flush. It really wouldn't hurt to be recessed a bit but it would create a spot for dirt to collect. I use the appropriate sized flat washer on the shaft and tap it home with a short piece of PVC pipe. You can feel and hear when the washer hits the case and the seal will be perfectly flush. Share this post Link to post Share on other sites
ebinmaine 80,649 #12 Posted December 4, 2021 On 2/9/2019 at 5:13 PM, squonk said: I usually get the outer brg in by tapping it in with a hammer and punch. You can freeze the new bearing in you Frigidaire freezer and heat you PTO bell in your Magic Chef oven if you like to make it go easier. Is Whirlpool brand ok to use? Share this post Link to post Share on other sites
squonk 48,076 #13 Posted December 4, 2021 13 minutes ago, ebinmaine said: Is Whirlpool brand ok to use? Only at a higher voltage! 2 Share this post Link to post Share on other sites
