MartyHorse 4 #1 Posted January 30, 2019 Hello, just bought a P220 from a Toro/Wheelhorse 520h. It's sitting on my workbench and I want to fire it up to see how it runs. I've looked at wiring diagrams to figure out the connector pins but am confused. Do I need to power anything in the multipin connector to start it? - thanks a bunch. Share this post Link to post Share on other sites
ohiofarmer 3,380 #2 Posted January 30, 2019 I would think that you would need to have all the safety switches wired into the connector. There is at the minimum a safety switch under the PTO lever and also the seat. There is a fuse or two as well. Share this post Link to post Share on other sites
MartyHorse 4 #3 Posted January 30, 2019 Yeah, I don't know what to bypass in the connector if anything. Is there an electric fuel pump? Share this post Link to post Share on other sites
Ed Kennell 42,414 #4 Posted January 30, 2019 The 520 has a vacuum operated fuel pump attached to the blower shroud. You could buy a 12VAC pump for bench testing. Make sure it is a low pressure (3PSI or less) pump. 1 Share this post Link to post Share on other sites
MartyHorse 4 #5 Posted January 30, 2019 Thanks Ed, do I need to power any of the wires in the pin connector to run it? Share this post Link to post Share on other sites
MartyHorse 4 #6 Posted January 30, 2019 I see there is a similar post on this: https://www.wheelhorseforum.com/topic/77350-how-to-start-p220-onan-off-wh/?tab=comments#comment-748443 I'll follow those instructions, thanks. 3 Share this post Link to post Share on other sites
cleat 7,388 #7 Posted January 30, 2019 The fuel pump if properly installed on the shroud should work fine, just put a hose from the bottom inlet to the pump into a container of gas. Then, the battery + cable from the starter solenoid just connects to the + on a battery. Connect a heavy gauge ground wire to an engine bolt then connect that to battery -. The only wire in the 9 pin you really need to worry about is the yellow one going to the + terminal on the coil. Connect that through a switch if possible then ideally through an inline 15A fuse to the + terminal on the battery. This will be the ignition switch. You should connect the center lead on the voltage regulator through a 30A fuse to the + terminal on the battery just to protect the regulator (If you don't do this it likely will not be the end of the world). Lastly, connect a wire from the small push on connector on the starter solenoid ideally through a momentary push button switch to the + terminal on the battery (this will be your starter switch). To start the engine, just turn on the switch to the coil then crank the engine using the momentary switch to she starter solenoid. To stop the engine, just turn off the switch to the coil. You will need to figure out a way to operate the choke and throttle. I would fasten the engine down to something to hold it from flipping over or falling down. 3 3 Share this post Link to post Share on other sites
KC9KAS 4,744 #8 Posted January 30, 2019 @MartyHorse to Share this post Link to post Share on other sites
ztnoo 2,300 #9 Posted January 30, 2019 4 hours ago, MartyHorse said: I see there is a similar post on this: https://www.wheelhorseforum.com/topic/77350-how-to-start-p220-onan-off-wh/?tab=comments#comment-748443 https://www.wheelhorseforum.com/topic/77350-how-to-start-p220-onan-off-wh/?tab=comments#comment-748443 Share this post Link to post Share on other sites
MartyHorse 4 #10 Posted January 31, 2019 Thanks for the all great detailed info and also the welcome! Share this post Link to post Share on other sites
953 nut 60,723 #11 Posted January 31, 2019 Sounds like @cleat has you covered on the whole operation. What model are you working on? Share this post Link to post Share on other sites
