TC10284 113 #1 Posted January 28, 2019 I have a 42" attach-a-matic deck that I'm repairing. One of the spindle pulleys has a hole rusted in the grove and needs to be replaced. I don't have the exact model number of the deck, right now, but I can get it. But for the moment, when I look it up on Parts Tree, the pulley that's listed (Number 5) doesn't seem to match up in size with the other blade pulley's. https://www.partstree.com/parts/toro/mower-deck-assemblies/15-42sc01-toro-42-side-discharge-mower-deck-1989/rear-side-discharge-mowers-42-48-in-107-122-cm/ Does anyone know what the correct pulley's are, and where is the key listed? Share this post Link to post Share on other sites
Ed Kennell 45,031 #2 Posted January 28, 2019 The two single sheave outside pulleys #5 are the same size as the bottom sheave on the double center pulley. So the three pulleys driving the blades are the same size. There are no keys in the pulleys. The pulleys are locked to the spindle with the lock washer and nut. Share this post Link to post Share on other sites
953 nut 64,322 #3 Posted January 28, 2019 some did have keys, you need to remove the old one to be sure the replacement is correct. Share this post Link to post Share on other sites
953 nut 64,322 #4 Posted January 28, 2019 This is the 1984-85 42" Rear Discharge. I had one like it. Has a woodruff key. 1 Share this post Link to post Share on other sites
daveoman1966 3,882 #5 Posted January 28, 2019 Lt or Rt side pulley for a 42" deck WITH woodruff key is # 106072. It has a 3/4" bore. The other pulley WITHOUT a woodruff key is # 109967 and it has a 5/8" bore. 2 2 Share this post Link to post Share on other sites
Ed Kennell 45,031 #6 Posted January 28, 2019 Some additional info on the deck pulleys. The older decks had the cast iron double D holes for locking to the spindles. Then Wheel Horse changed to the keyed pulleys. And then changed to the present keyless design that uses only the lock washer and nut to attach the pulleys as shown in Dave's above post. This is why it is necessary to use your correct deck model number when searching for parts. The Double D pulleys. 2 1 Share this post Link to post Share on other sites
TC10284 113 #7 Posted January 28, 2019 8 hours ago, daveoman1966 said: Lt or Rt side pulley for a 42" deck WITH woodruff key is # 106072. It has a 3/4" bore. The other pulley WITHOUT a woodruff key is # 109967 and it has a 5/8" bore. Thanks! I was able to find what I needed with the top pic part number! 1 Share this post Link to post Share on other sites
