ericj 1,580 #1 Posted January 24, 2019 I have a 520-8 that I bought at the big show this year. I installed the extension kit on it with the snowplow. Problem is that the transmission drive pulley is rubbing the extension. I thought Oh well I'll just slid the axle bracket over to the right to give it some clearance, problem is that there's no extra room for the brake band. On top of this problem the belt is also rubbing the hitch pin clips that hold the extension kit to the plow frame, the cross rod. My pulley is bent up some adding to the problem, has anyone on here put a plow on the 520-8 and had any issues with the extension rubbing anything ???? any help would be very appreciated. eric j 1 Share this post Link to post Share on other sites
wallfish 20,689 #2 Posted January 24, 2019 No experience with your issue but could the bracket on the trans be mounted wrong? Like in front of the axle instead of below it? Just seems like it's riding too high from your description 2 Share this post Link to post Share on other sites
ericj 1,580 #3 Posted January 24, 2019 48 minutes ago, wallfish said: No experience with your issue but could the bracket on the trans be mounted wrong? Like in front of the axle instead of below it? Just seems like it's riding too high from your description No I mounted the bracket myself a few months back in preparation of mounting the plow. I do have to go make sure the frame is broken, I'm pretty sure it's not, no movement of any kind but will double check it eric j 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #4 Posted January 24, 2019 @richmondred01, Mark can you help Eric out, since you just finished up the redo on your 520-8 with snow plow. Thanks. 1 Share this post Link to post Share on other sites
case442 132 #5 Posted January 25, 2019 Hello Eric, Mine did the same. I did the same and moved the brackets over a little and the mine worked fine. MIke 2 Share this post Link to post Share on other sites
ericj 1,580 #6 Posted January 25, 2019 28 minutes ago, case442 said: Hello Eric, Mine did the same. I did the same and moved the brackets over a little and the mine worked fine. MIke thanks, I guess I have to replace my bent up transmission pulley and try it again eric j 2 Share this post Link to post Share on other sites
Turftech 82 #7 Posted January 25, 2019 Do you have the 1" spacers mounted between the hitch and the axle? I believe the original extension kits had two lengths of carriage bolts so the spacers would be added on the 520-8 to clear the pulley. The reason I know this is my 1994 520-H came with the extensions installed, upon disassembly the blocks were found to be powder coated red. Researching on Red Square I came across a post showing pictures of a newly opened NOS.extension kit with the blocks. Hope this helps 2 2 Share this post Link to post Share on other sites
Shynon 7,723 #8 Posted January 25, 2019 7 hours ago, Turftech said: Do you have the 1" spacers mounted between the hitch and the axle? I believe the original extension kits had two lengths of carriage bolts so the spacers would be added on the 520-8 to clear the pulley. The reason I know this is my 1994 520-H came with the extensions installed, upon disassembly the blocks were found to be powder coated red. Researching on Red Square I came across a post showing pictures of a newly opened NOS.extension kit with the blocks. Hope this helps I have a couple sets of those, not sure if they are complete though 1 1 Share this post Link to post Share on other sites
ericj 1,580 #9 Posted January 25, 2019 11 hours ago, Turftech said: Do you have the 1" spacers mounted between the hitch and the axle? I believe the original extension kits had two lengths of carriage bolts so the spacers would be added on the 520-8 to clear the pulley. The reason I know this is my 1994 520-H came with the extensions installed, upon disassembly the blocks were found to be powder coated red. Researching on Red Square I came across a post showing pictures of a newly opened NOS.extension kit with the blocks. Hope this helps now that you mention I do remember reading something about that will have to check into that 4 hours ago, Shynon said: I have a couple sets of those, not sure if they are complete though if you have any of the blocks I would be interested in a set if your willing to sell eric j 2 Share this post Link to post Share on other sites
oliver2-44 11,782 #10 Posted January 25, 2019 RedSquare Like... "Ace The helpful Place" 2 1 Share this post Link to post Share on other sites
Sarge 3,473 #11 Posted January 25, 2019 RS is far better than ACE - it doesn't push Chinese built garbage...lol. Sarge 3 Share this post Link to post Share on other sites
SPINJIM 1,997 #12 Posted January 25, 2019 14 hours ago, Turftech said: Do you have the 1" spacers mounted between the hitch and the axle? I believe the original extension kits had two lengths of carriage bolts so the spacers would be added on the 520-8 to clear the pulley. Any pictures of those spacer blocks ? I'm planning on installing a plow with the extension on my 520H, and wasn't aware of the spacers. If you have a spare set, I'd be in line behind Eric to buy them from you. Thanks, Jim 1 Share this post Link to post Share on other sites
ericj 1,580 #13 Posted January 25, 2019 3 hours ago, SPINJIM said: Any pictures of those spacer blocks ? I'm planning on installing a plow with the extension on my 520H, and wasn't aware of the spacers. If you have a spare set, I'd be in line behind Eric to buy them from you. Thanks, Jim I think the spacers are only needed on 8 speed tractors. I've been using plow extensions on 520-H for years and never had a problem before this 8 speed eric j 1 Share this post Link to post Share on other sites
richmondred01 2,393 #14 Posted January 26, 2019 (edited) Mine rubbed too on the 520-8. Easy fix. I ground a small portion of the extension off in the area causing the aforementioned issue. No problem since. All the best. Edited January 26, 2019 by richmondred01 Share this post Link to post Share on other sites
Shynon 7,723 #15 Posted January 26, 2019 I have 2 sets may not be complete. Share this post Link to post Share on other sites
richmondred01 2,393 #16 Posted January 26, 2019 Pm sent Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #17 Posted January 27, 2019 The 119840 spacer blocks are still available from Toro and will likely be for eternity. https://www.partstree.com/parts/toro/parts/119840/ Garry Share this post Link to post Share on other sites
Sarge 3,473 #18 Posted January 27, 2019 Looks like a pretty easy part to duplicate - and price it at a lot lower point than what Toro is asking, lol. Sarge Share this post Link to post Share on other sites
ericj 1,580 #19 Posted January 29, 2019 I had a friend that was my dad's wheel horse dealer, and also a machinist, make me 2 blocks. I installed them today and now the plow works as it should and even lifts a little higher. and the price was right. eric j 1 Share this post Link to post Share on other sites
