Firebug 267 #1 Posted January 21, 2019 Well I finally got my d 200 back together and ready to dig out from the weekend storm. I didn’t get 5 feet out of the barn and was stuck. Got it freed up and made it 10 feet before it happened again. I’m pretty frustrated with it, got the big Ag tires and filled them with washer fluid and all it does is spin. I have a set of chains but they are for the smaller tires so they don’t fit. And then I found out the new fuel valve I put ini is still leaking. About ready to throw my arms up for the day 1 5 Share this post Link to post Share on other sites
Digger 66 3,530 #2 Posted January 21, 2019 50 minutes ago, Firebug said: About ready to throw my arms up for the day Sometimes that's the best thing you can do . Things will look better tomorrow . 6 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,590 #3 Posted January 21, 2019 Take a break. Look at it again tomorrow. A fresh start. Glenn 3 Share this post Link to post Share on other sites
953 nut 69,128 #4 Posted January 21, 2019 Guess it is time to buy another set of chains. The "D has too much power for the conditions. 4 Share this post Link to post Share on other sites
JoeM 10,246 #5 Posted January 21, 2019 I pretty much found out AG tires are best in dirt, and the best thing for snow was turfs with chains. May D160 would push tons of snow with that set up. 5 1 Share this post Link to post Share on other sites
pfrederi 21,145 #6 Posted January 22, 2019 #1 I will come and take it off your hands #2 if it is icy /frozen ground ags will not do much for you #3 Get some wheel weights 50lbs per side Hang 150 lbs or more on the 3point 4 Share this post Link to post Share on other sites
wh500special 2,455 #7 Posted January 22, 2019 (edited) 14 hours ago, Firebug said: .... and all it does is spin.... That was always my experience with the D-autos also. I had 65 pound wheel weights on each rear wheel and about 150 pounds on the hitch before mine became useful. But it was still touch and go when the thrower was raised. With chains. I finally solved my D’s traction problem by selling it. You can probably solve yours with weights and chains. Good luck, Steve Edited January 22, 2019 by wh500special 3 1 Share this post Link to post Share on other sites
Shuboxlover 490 #8 Posted January 22, 2019 In my experience, a good set of chains (2 link with lugs) will do way more than any amount of weight you put on it. Just my $.02 3 1 Share this post Link to post Share on other sites
Pollack Pete 2,273 #9 Posted January 22, 2019 Can you type tirechains.com I've bought several sets from them.Fair prices.Quick shipping.Like others have said,some added weight too.That D should be a bear plowing snow. 1 Share this post Link to post Share on other sites
RandyLittrell 3,945 #10 Posted January 22, 2019 I recommend going back in the house till the snow goes away!! I hate the cold, if it weren't for loving all my family, I would be headed south!!! 2 1 1 Share this post Link to post Share on other sites
Firebug 267 #11 Posted January 22, 2019 I should have titled it d 200 frustration instead of disappointment. I put about 50 pounds of washer fluid in each tire, but that’s not enough weight. Not disappointed in it at all, just disappointed that I didn’t get the seat time I was hoping for. I have chains and rims for the 26-12-12 tires, just not the tall skinny ones. In my mind I was thinking those ag tires would just dig in and push. I was way off. That is the fun part, playing with different set ups to see what works and what doesn’t. Time to track down some 26 inch turfs 6 Share this post Link to post Share on other sites
squonk 48,062 #12 Posted January 22, 2019 An example: My Power King has 24” rear wheels with ags . Same as a Cub. I had some big freakin ring chains on it and it did great. But those chains were a pita. I got some Farmall 100 lb weights and filled the tires. Added a weight box. Left the chains off. On the hard pack slick snow like we just got it would spin. I found another set of regular chains for it and it’s a monster. I was fighting thru a 4 ft. packed snow pile and those rears would slip then the chain would grab and dig and power me forward 3 Share this post Link to post Share on other sites
Sarge 3,473 #13 Posted January 22, 2019 Without chains, the D's weight fights against itself easily. This thing weighs around 1,100lbs - it needs the traction to match its weight. All I run on mine is the 50lb 12" cast iron weights and chains - pushes way more than the C-160 with loaded tires, weights and chains could ever push - plus, it has a much larger and heavier blade. I prefer somewhat that it spins itself out versus damaging the rear axle, pump coupling or other parts. Give them enough traction - you will break something eventually. Parts start acting like a fuse when you overload the capability - if you have to weight one down that far you really should be using a larger machine in the first place. Yes, these things are tough - but they aren't a bulldozer, either, treat it accordingly. Sarge 2 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #14 Posted January 22, 2019 I would’ve assumed (I know what that makes me) that AGs would dig in as well. Sorry that your setup didn’t go the way you thought it would, but thanks for sharing your experience. Might save someone else a headache while their drives full of snow later. 1 Share this post Link to post Share on other sites
Firebug 267 #15 Posted January 22, 2019 I’ll get it, just going to take some trial and error, just didn’t want to have to pay someone to plow my driveways when I have a machine that’s more than capable of doing it. I didn’t have any issues with my d160 last year save for the motor letting go. But I did have the chains on it last year. Thought the gas would dig like the chains. But at least I didn’t scatter my motor this time 👍 6 Share this post Link to post Share on other sites
19richie66 17,932 #16 Posted January 22, 2019 Ouch! Share this post Link to post Share on other sites
Firebug 267 #17 Posted January 22, 2019 That one hurt a bit. Something else I noticed was only the left tire was spinning, is that right? I was under the impression that it was like a “locked” rear end where both tires would spin providing traction Share this post Link to post Share on other sites
Shuboxlover 490 #18 Posted January 22, 2019 I don't believe any Wheel Horse had posi-traction. The only one that had a locking diff was the D-250 I think Share this post Link to post Share on other sites
pfrederi 21,145 #19 Posted January 22, 2019 10 pinion rear ends used on Raiders Chargers and electros are limited slip and will spin both rear wheel sat the same time. The are big improvement over an open differential but not as good as a locker like the D250 2 Share this post Link to post Share on other sites
richmondred01 2,392 #20 Posted January 23, 2019 Wow that hurts to look at. Share this post Link to post Share on other sites
Firebug 267 #21 Posted January 23, 2019 Not one of the more enjoyable experiences Share this post Link to post Share on other sites
Rob R 989 #22 Posted January 23, 2019 (edited) Just don't understand the mystery on AG (Agricuttural) tires which I see all the time. AG tires were designed to be used in the dirt to plow, cultivation or pull dirt attachments, they are poor in snow and will tear the hell out of your lawn especially in the spring when things are sloppy and even a new driveway in the heat of summer. There is no substitute for 2 link chains on normal tires for ice or freezing snow.... this has been true since the dawn of the automotive age..... back in the 50's prior to snow and studded tires you stopped your vehicle when it snowed or in icy conditions and installed banded chains to get moving again, just like they do today on all the tractor trailers. My father could do this is less then 15 mins he then would get back in the straight eight Buick blow up his chest and proclaim "let it snow all I wants nothing is going to stop this baby now" and off we would go with the straight eight roaring like a lion! Edited January 23, 2019 by Rob R 2 Share this post Link to post Share on other sites
Firebug 267 #23 Posted January 23, 2019 I’m in a not so unique position that I multi task my tractors. Actual agricultural use in the spring for tilling and planting. Landscape duties all summer and snow plow in the winter. On more than one occasion I’ve needed my wife to pull the tractor out of the front yard because the turf tires just spun. Maybe July and August I can get by on turfs with no issues, so I started putting ag tires on everything. Like I said before, my simple mind thought the aggressive lugs would dig in and not have any problems pushing snow. Share this post Link to post Share on other sites
Rob R 989 #24 Posted January 24, 2019 2 hours ago, Firebug said: I’m in a not so unique position that I multi task my tractors. Actual agricultural use in the spring for tilling and planting. Landscape duties all summer and snow plow in the winter. On more than one occasion I’ve needed my wife to pull the tractor out of the front yard because the turf tires just spun. Maybe July and August I can get by on turfs with no issues, so I started putting ag tires on everything. Like I said before, my simple mind thought the aggressive lugs would dig in and not have any problems pushing snow. We all live and die with our decision(s) …. why you would put AGs on "everything" is beyond me.... guess they do look good but damn if you can plow snow with it... One of the most disappointing things in life to me is a snow blower that won't start and the second is a stuck plow tractor.... just saying...... Share this post Link to post Share on other sites
Firebug 267 #25 Posted January 24, 2019 I get it, I do more dirt work with them than the 3-4 times snow plowing. Plus I got tired of getting stuck in the grass. I couldn’t get anywhere with the turf tires. More than a handful of ties I needed to pull them out of the yard. That s why I decided to put gas on all my tractors. I can get more done with less time farting around. Now it seems the same issue I had in the summer with turf tires I’m now having in the winter with ag tires 1 Share this post Link to post Share on other sites
