mbn32166 5 #1 Posted January 21, 2019 So both of my wheelhorses went down in a period of 2 days.My C175 blew the main drive belt.Changed the belt but acts like rear end/transmission is locked.With the wheels off the ground both spin freely but as soon as they are on ground nothing,tractor wont budge. So then after plowing with my 312-8 blew the drive belt on that.Changed belt but now it doesnt want to move.Got it too back up little bit in reverse but doesnt seem to have any forward gears.It has been extremely cold dont know if that would have anything too do with it(teens to negative degrees with wind chill down in-20 to -30).Just looking for ideas or suggestions.May not be able to do anything till we get a warm spell.Thanks in advance. 1 Share this post Link to post Share on other sites
Blackhood Bill 728 #2 Posted January 21, 2019 I would start with checking simple things. Loose belt, low low fluids, loose pulleys, etc.... new to those wheel horse there will be more knowledgeable people who can help who will chime in. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,282 #3 Posted January 21, 2019 Any chance water in the oil has turned to ice? Garry 7 2 1 Share this post Link to post Share on other sites
953 nut 66,658 #4 Posted January 21, 2019 1 hour ago, mbn32166 said: It has been extremely cold dont know if that would have anything too do with it If the tractors were ever left outside during their lives it is likely that some water got into the gear box and the oil/water emulsification has frozen. If you can cover either one with a few blankets and put a heater under it for a few hours it should free up enough to change the oil. Be sure to jack up the front end so all the present oil will drain. The drain plug is near the back of the transmission and takes an allen wrench. Use 80-90 gear oil to refill it. 3 Share this post Link to post Share on other sites
ohiofarmer 3,435 #5 Posted January 21, 2019 To speed up that process, I lift the tractor with a hoist really high--so high that taking out the battery is a good idea. ithen take some clear vinyl tubing and snap it over the nipple on an old fashioned gas jug. On the fill hole of the jug, apply suction from a shop vac. To get it really clean, spray some kerosine in the fill hole with an equipment cleaner from Harbor Freight and all kinds of additional dirt comes outhttps://www.harborfreight.com/engine-cleaning-gun-68290.html open link to view the tool 3 Share this post Link to post Share on other sites
mbn32166 5 #6 Posted January 21, 2019 Well they have both been outside since I have owned the just dont have anyplace to store them inside.I changed the fluid in the C175 this past summer but I dont know if I got all the moisture out.AS far as the 312 just seemed odd it was working fine until belt went and now just doesnt want to move.Any how thanks for input when I get a couple days of warmer weather will try draining them and refillng and see what happens.Actually on that note would kerosene clean them out even without being able to run them? Share this post Link to post Share on other sites
ohiofarmer 3,435 #7 Posted January 21, 2019 The reason I used the cleaning gun to spray kero in there was I felt it might wash the dirt and rust off the gears. I used a suction hose to take all the residue out as you do not want that kero thinning down the gear oil.. All I know for sure is that the clear vinyl hose had a lot of brown grunge being sucked out of it..When it started turning clear, I put new gear oil in. It can be a dirty job. Maybe protect your eyes and wear old clothing you might have to throw away because of the smell. I just kept moving the end of the vinyl hose around the drain port to suck every place I could get. Share this post Link to post Share on other sites
wallfish 20,053 #8 Posted January 22, 2019 Remove the gear shifter and look inside at the shift forks. The opening in the forks should look like a small rectangle when it's in neutral. My guess is it's stuck in 2 gears at once since it was working then locked. Quick shifting does it when things aren't tight or the ball on the shifter is worn. You can move the forks with a large screwdriver back to the neutral position. Inspect the shifter for wear or if the "donut" is loose. Also keep the dog point set screw (which holds the shifter) semi tight. too loose can cause this. 3 1 1 Share this post Link to post Share on other sites
953 nut 66,658 #9 Posted January 22, 2019 10 hours ago, wallfish said: Quick shifting does it when things aren't tight or the ball on the shifter is worn But, Two of them in one Very Cold Day? At any rate, here is a helpful post. 1 1 Share this post Link to post Share on other sites
stevasaurus 23,712 #10 Posted January 22, 2019 I'm thinking the same thing as Wallfish. Jacked up he can turn the wheels...means the differential is OK and not froze. Stuck between gears seems like the problem. Thinking about 2 tractors doing that, when you have the same guy with bad shifting habits...it is very possible. Not to say mbn32166 has some bad habits...but if you are shifting fast from reverse to 2nd...or vise-versa...that is what happens. Easy fix...pull the shifter and use a large screw driver to pry the forks back into neutral...replace shifter. If this is your problem...you need to come to a complete stop before shifting and shift slowly and in the "H" pattern. Let us know what you find. 1 Share this post Link to post Share on other sites
953 nut 66,658 #11 Posted January 23, 2019 4 hours ago, stevasaurus said: Jacked up he can turn the wheels...means the differential is OK and not froze. Differential is higher than the oil level but the 44 tooth gear is all the way down in the oil and one of the gears on the input shaft is too. If the oil/water slurry is frozen the axle and differential gears will be able to turn but the others won't. 1 Share this post Link to post Share on other sites
wallfish 20,053 #12 Posted January 23, 2019 (edited) But, since he was using the tractors when they locked up, the gears weren't frozen in ice from sitting. Which is why I guessed shifter forks in two gears at once. Although it is certainly possible loose ice jammed into the gears while using it. EDIT After reading his post again, maybe it's one of each symptom Edited January 23, 2019 by wallfish 1 Share this post Link to post Share on other sites
stevasaurus 23,712 #13 Posted January 23, 2019 @953 nut The differential is not entirely out of the oil at any time. It sits in 1" to 1 1/2" of oil and has nice sized holes for the oil to flow in and out. In this picture, you can see that the differential goes from top to bottom in the case half. It does sit in enough oil to coat the pinions that are on the bottom. 1 Share this post Link to post Share on other sites
Spareparts 92 #14 Posted January 24, 2019 Fought this same problem this morning on my 2500 Anniversary Edition, changed the fluid this spring and installed a new boot but it still got about a qt. and half of water out after thawing it out. I put Valvoline 50 wt. in it and did my snow plowing and put in back in the warm shop and drained it again, milky looking oil came out. Then I read in one of the post's to jack up the front, went right out and jacked it up and got the rest of the oil out. Really good tip, thanks for that. 1 2 Share this post Link to post Share on other sites
mbn32166 5 #15 Posted January 26, 2019 Think I need to clarify something here.I wasn't using the C17. when the rear locked.I had started it and moved it a week or so before.and it was fine.The next time I started it and tried too move it was when I smoked the belt,I actually thought the rearend was frozen to the ground until my son pulled it out of where it was parked and then discovered the rear end was locked up.Again though it was probably in the 40s the last time it moved to the 20s when the belt blew and now it sits n 1-2 ft snow so nothing is going to be done with it for a while. 3 Share this post Link to post Share on other sites
stevasaurus 23,712 #16 Posted January 27, 2019 @mbn32166 this last post sounds like this horse is froze because of water. If you might get some of this real cold weather that we are getting here in Chicago (-10F and more), I am worrying about you cracking that transmission case. If it is just a touch of water, it may be alright, but if there is a fair amount it could crack it. At the very least, I would tarp the horse, that would stop the wind chill and maybe even hold some heat from the sun. If you have a dip stick, I'm thinking a can of Heat or a couple of cups of anti-freeze. If no dip stick, you could pull off the seat and fenders and add through a bolt hole. You could also put an oil pan under the trans and pull the drain plug and then tarp the horse. That way if we did get a thaw, it might drain the water. Let us know what you think. 2 Share this post Link to post Share on other sites
mbn32166 5 #17 Posted February 4, 2019 So finally got a warm day and went out and played around with the 312-8.Pulled the shifter and it looked ok and as near as I could tell it was in neutral.The set screw was fairly loose but it tightened and now the shifter is tight whereas before it had a lot of slop.I jacked the rear end off the ground,started her up and shifted through the gears.Wheels turn but theres no power .I could stop them with my hand.The other thing I noticed was they turn independently of one another.You could stop one and the other would keep spinning.Dont know if this means anything or not. Share this post Link to post Share on other sites
953 nut 66,658 #18 Posted February 4, 2019 Each axle and the pulley that your belt from the engine goes to have a key on them to lock the hubs and pulley to their respective shafts, If any one of these keys is broken it will prevent the tractor from moving. Take a magic marker and put a line on each one across the axle/hub and pulley/shaft. Do your test again and see which one is no longer lined up. Share this post Link to post Share on other sites
953 nut 66,658 #19 Posted February 4, 2019 Looking at your previous posts I see that the transmission was locked up, Apparently the gear oil has some water in it and had frozen. Pull the dip stick on the transmission and see if it is a clear golden oil color. Share this post Link to post Share on other sites
mbn32166 5 #20 Posted February 4, 2019 I did wonder about the keys in the shafts but have never had one sheer off before whether it was on 1 of my wheelhorses or other equipment I have owned through the years.I will try that and see what happens.As far as the locked trans that was on my C17 and I did check the oil and it is clear.But its still buried in a pile of snow so it will have to wait a little longer. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,282 #21 Posted February 5, 2019 If there is water in the oil and the tractor has sat idle for a period of time during temps above the freezing point the water will go to the bottom of the oil. If the drain plug is removed and nothing comes out it is likely a layer of ice that is preventing the oil from coming out. Garry 1 Share this post Link to post Share on other sites
mbn32166 5 #22 Posted February 5, 2019 I changed the oil in the C17 last summer but there still could have been water in it.I went out today started her up and she moved like nothing was ever wrong.I guess another fluid change is in her future.Now as far as the 312-8 I tried the magic marker and nothing the marks didnt move.I am starting to think internal damage of some sort just dont know where to go from here.Broken axle?I simply dont know.My son was using it to plow snow it was running moving fine,then the belt went.Changed the belt and now nothing. Share this post Link to post Share on other sites
953 nut 66,658 #23 Posted February 5, 2019 32 minutes ago, mbn32166 said: I changed the oil in the C17 last summer but there still could have been water in it.I went out today started her up and she moved like nothing was ever wrong.I guess another fluid change is in her future Be sure to jack up the front of the tractor while draining the oil from the transmission. There is a hump in the center of the bottom that can trap some oil if you don't jack it up. Share this post Link to post Share on other sites
stevasaurus 23,712 #25 Posted February 5, 2019 mbn...your post...#17 in this thread is normal...that is how the differential works. 1 Share this post Link to post Share on other sites
