BHunter 1,701 #1 Posted January 21, 2019 Hi , Does anyone know where to buy the right length cables for a 1961 401 suburban? Mine are seized up. Thanks, Bob Share this post Link to post Share on other sites
ebinmaine 76,544 #2 Posted January 21, 2019 Bob can you get a picture of what you need? Share this post Link to post Share on other sites
BHunter 1,701 #3 Posted January 21, 2019 29 minutes ago, ebinmaine said: Bob can you get a picture of what you need? Share this post Link to post Share on other sites
KC9KAS 4,745 #4 Posted January 21, 2019 Got mine for a 551 on eBay. https://www.ebay.com/itm/Willys-Kaiser-Jeep-CJ2A-CJ3A-CJ3B-CJ5-Tractor-Car-Truck-Choke-Throttle-Cable/182497006421?hash=item2a7dab5355:g:Yr0AAOSwWxNY0ECr:rk:6:pf:0 3 Share this post Link to post Share on other sites
ebinmaine 76,544 #5 Posted January 21, 2019 I'll take a look and see what I have 1 Share this post Link to post Share on other sites
Achto 30,475 #6 Posted January 22, 2019 3 hours ago, BHunter said: Does anyone know where to buy the right length cables for a 1961 401 suburban? Here is another source. http://www.psep.biz/store/toro_mower_cables.htm They will need to be trimmed to length, which is quite easy to do. 2 Share this post Link to post Share on other sites
ebinmaine 76,544 #7 Posted January 22, 2019 Bob I only have one here and it's got a crease in it. Both above sources should be good for you. Share this post Link to post Share on other sites
BHunter 1,701 #8 Posted January 22, 2019 Just now, ebinmaine said: Bob I only have one here and it's got a crease in it. Both above sources should be good for you. Thanks for trying. I appreciate it. 2 Share this post Link to post Share on other sites
BHunter 1,701 #9 Posted January 22, 2019 3 minutes ago, Achto said: Here is another source. http://www.psep.biz/store/toro_mower_cables.htm They will need to be trimmed to length, which is quite easy to do. Thanks for the link 1 Share this post Link to post Share on other sites
WHNJ701 4,168 #10 Posted January 22, 2019 2 hours ago, KC9KAS said: Got mine for a 551 on eBay. https://www.ebay.com/itm/Willys-Kaiser-Jeep-CJ2A-CJ3A-CJ3B-CJ5-Tractor-Car-Truck-Choke-Throttle-Cable/182497006421?hash=item2a7dab5355:g:Yr0AAOSwWxNY0ECr:rk:6:pf:0 I ordered the same for mine I didn't install them yet 1 Share this post Link to post Share on other sites
BHunter 1,701 #11 Posted January 22, 2019 2 hours ago, KC9KAS said: Got mine for a 551 on eBay. https://www.ebay.com/itm/Willys-Kaiser-Jeep-CJ2A-CJ3A-CJ3B-CJ5-Tractor-Car-Truck-Choke-Throttle-Cable/182497006421?hash=item2a7dab5355:g:Yr0AAOSwWxNY0ECr:rk:6:pf:0 Thank you Share this post Link to post Share on other sites
Achto 30,475 #12 Posted January 22, 2019 2 minutes ago, BHunter said: 2 hours ago, KC9KAS said: Got mine for a 551 on eBay. https://www.ebay.com/itm/Willys-Kaiser-Jeep-CJ2A-CJ3A-CJ3B-CJ5-Tractor-Car-Truck-Choke-Throttle-Cable/182497006421?hash=item2a7dab5355:g:Yr0AAOSwWxNY0ECr:rk:6:pf:0 These cables have the correct knobs for the year of your tractor. Share this post Link to post Share on other sites
dells68 7,499 #13 Posted January 22, 2019 I ordered a set exactly like those off of eBay for my 701 and they look great. Only one drawback, no way to lock the throttle to keep it on place. I like the idea someone else said about pulling the sire out of the sheath and kinking it a little to give it a little resistance. 2 Share this post Link to post Share on other sites
wallfish 18,859 #14 Posted January 22, 2019 5 hours ago, BHunter said: Hi , Does anyone know where to buy the right length cables for a 1961 401 suburban? Mine are seized up. Thanks, Bob Seized up or frozen from water inside? If frozen warm them up and soak them in antifreeze. You can cut the Z bend off and pull out the wire. The rust on the wire easily attaches to the ice so clean them up, gease'm and re-install. 2 Share this post Link to post Share on other sites
BHunter 1,701 #15 Posted January 22, 2019 48 minutes ago, wallfish said: Seized up or frozen from water inside? If frozen warm them up and soak them in antifreeze. You can cut the Z bend off and pull out the wire. The rust on the wire easily attaches to the ice so clean them up, gease'm and re-install. Seized. Is there a product I can soak them in that will desolve the rust? Share this post Link to post Share on other sites
wallfish 18,859 #16 Posted January 22, 2019 1 minute ago, BHunter said: Seized. Is there a product I can soak them in that will desolve the rust? Cider vinegar. It should work overnight. 2 Share this post Link to post Share on other sites
ebinmaine 76,544 #17 Posted January 22, 2019 @wallfish has a good idea there. You really should be able to carefully separate your existing cables if they are all solid and look okay. You should be able to reuse them. Patience is your friend. 1 Share this post Link to post Share on other sites
BHunter 1,701 #18 Posted January 22, 2019 1 hour ago, ebinmaine said: @wallfish has a good idea there. You really should be able to carefully separate your existing cables if they are all solid and look okay. You should be able to reuse them. Patience is your friend. I have lots of patience. They can soak in vinegar all winter if needed. Thanks 1 1 Share this post Link to post Share on other sites
rdeanrj58 68 #19 Posted January 22, 2019 Is there a tool to put a new z-bend in the wire? Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #20 Posted January 22, 2019 7 minutes ago, rdeanrj58 said: Is there a tool to put a new z-bend in the wire? 2 pair of pliers works for me, hold the wire with one bend with the other. 2 Share this post Link to post Share on other sites
rdeanrj58 68 #21 Posted January 22, 2019 It's always hard for me to get the center part small enough Share this post Link to post Share on other sites
ebinmaine 76,544 #22 Posted January 22, 2019 Just now, rdeanrj58 said: It's always hard for me to get the center part small enough I agree with that. Get a pair of decent quality needle-nose vise grips to hold the end of the wire at the end of the vice grips about 3/16 of an inch from the end you can then use another pair of pliers in addition to a hammer to create the Z bend around the parts that is gripped in the needle nose pliers Share this post Link to post Share on other sites
rdeanrj58 68 #23 Posted January 22, 2019 I'll give that a try. I've got a throttle cable I'm trying to free up now Share this post Link to post Share on other sites
wallfish 18,859 #24 Posted January 22, 2019 Z bend pliers or the little Z bend tool. https://www.amazon.com/s/?ie=UTF8&keywords=z-bend+pliers&tag=geminipcstand-20&index=aps&hvadid=34278908673&hvqmt=e&hvbmt=e&hvdev=c&ref=pd_sl_23xunr1iyq_e 2 Share this post Link to post Share on other sites
rdeanrj58 68 #25 Posted January 22, 2019 Yeah that's what I'm talking about 1 Share this post Link to post Share on other sites
