dandan111 66 #1 Posted January 13, 2019 My blade is pretty much trashed. It's bent ,twisted and as of today the bottom brackets have ripped through the blade like a pop can. Have any of you guys fitted a warn blade onto a wheel horse blade frame? I have started shopping for a clean used blade but it's going to be hard to find a blade as nice as my tractor. Thoughts on new? Share this post Link to post Share on other sites
SylvanLakeWH 32,708 #2 Posted January 13, 2019 There are typically plenty of blades with and without frames on Craigslist in the SE Michigan area...perhaps your area too? That's where I would check first... 1 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,455 #3 Posted January 13, 2019 Like Jim said I would check CL, Ebay, and any other outlets before modifying the blade you have. That being said, with a welder, torch, and the right amount of skill anything is possible 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #4 Posted January 13, 2019 If you weren't so far away this lightly used 54" wide compact tractor blade I have would do the trick. Share this post Link to post Share on other sites
KC9KAS 4,746 #5 Posted January 13, 2019 @dandan111 Not sure where in Indiana you are at, but I have a couple of blades we could discuss. 1 Share this post Link to post Share on other sites
Blackhood Bill 728 #6 Posted January 14, 2019 dandan there are lots of blades also on Facebook marketplace. Good luck in your search. Share this post Link to post Share on other sites
dandan111 66 #7 Posted January 20, 2019 I got the blade welded back together. It's not so pretty anymore but it should get me by until I find what I want. Thanks. Share this post Link to post Share on other sites
