Tractorhead 9,217 #1 Posted January 6, 2019 (edited) Hi, because my search for Wheel Horse here in Bavaria just ends up with 200- Series, i lurking arround for an other option. (green yellow is completley out of discussion.) So i compared the smaller Kubotas 5000- Series and Iseki Tx1000 because they are also no that big and seems from Size similar to the C- Series. does anybody knows where are the advantages and disadvantages? Anybody own such a small kubota or iseki an can give me some infos about? I look primary on the 2WD version not the 4WD. Edited January 6, 2019 by Tractorhead Share this post Link to post Share on other sites
JoeM 10,216 #2 Posted January 6, 2019 I'm guessing that would be a Kubota B5000? My Neighbor has a Kubota B4200 and it has been pretty good almost trouble free, runs on sifter of fuel! Turning radius is pretty wide. Another one is the G series diesel, not so good I hear, rear end issues. Share this post Link to post Share on other sites
Tractorhead 9,217 #3 Posted January 7, 2019 Hi Joe, basically i would preferr a Wheelhorse 3xx or 5xx or a C Series, but nothing in Earthly Pricerange available here in a Range of 1800Km. Another Tractors i have found was the Small Tractor Kubota B5000E just as a 2WD. (i don't wanna 4WD, because of more Weight and large turn radius.) Weight of an B5000E is about 350 - 380 Kilos with Rear Lift (lifts 500 Kilos) and fitted with 10 HP 2Cylinder Diesel Engine. Some of the older Japanese Ricefield Tractors. They will be sale here used but refurbished for about 3500€ In working condition. unrefurbished they start at 2500€ A Compare was the Iseki TX1000. Only one Weel Horse 312 i have found in last 1/2 Year in extreme worse condition and with defect Engine for 5800€. I Call to the Guy, if this shall be a honest Pricerange he want's and he means, yes - that was "cheap" ... no further Comment .. Thanks so far for your info's. Share this post Link to post Share on other sites
Digger 66 3,530 #4 Posted January 7, 2019 I have no knowledge to give but one piece of advice : If you plan on buying something and you need help deciding , " A picture is worth a thousand words " . And the more , the better . Share this post Link to post Share on other sites
Tractorhead 9,217 #5 Posted January 7, 2019 (edited) Grabed a pic i found, to give you an idea, what i'm looking for To don't be missunderstood, i love my small 212 Horse and it works even better than i ever expected with the FEL. I didn't give it up and it will be kept, but i doubt, that it can be sensefully be used, to Plow a potato patch. this pic was a 4WD Kubota b5000. Edited January 7, 2019 by Tractorhead Share this post Link to post Share on other sites
Digger 66 3,530 #6 Posted January 7, 2019 I'd give my right arm for one of those . They're tough to find in The States in decent shape anymore . Share this post Link to post Share on other sites
Tractorhead 9,217 #7 Posted January 7, 2019 3 minutes ago, Digger 66 said: I'd give my right arm for one of those . They're tough to find in The States in decent shape anymore . Maybe right Arm i bit tooo expensive,😂 but here they selled between 2500 and 4500€ depending on shape. price hops and drops a bit within this range.. i'm honestly lurking for... including an FEL the cost rises to 7500€ - 10000€ .🙄 But thats tooo much i find. Share this post Link to post Share on other sites
ClassicTractorProfessor 5,455 #8 Posted January 8, 2019 I dont have any experience with those small Kubotas, but if they're built anything like their larger models then they cant be beat...farmer I used to work for baling hay every summer had an M9000 for a loader tractor. That machine got used and abused by everyone and their dog, and the only things we did to it was two clutches, an instrument cluster, and I had to rewire some of it once after a packrat got into it. Those four repairs over a 10 year period...I'd say that's a good tractor 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #9 Posted January 8, 2019 Sounds good. talked yesterday to a fellow, he told me that this small tractors shall be an ultimativeley tool for snowplow and light farm working. Even there are several tools available for. The three point hitch on the back ist easy able to lift roundabout 500 Kilos with front counterweight. His cousin have such a tractor.... my interest about is growing more... Share this post Link to post Share on other sites
bc.gold 3,406 #10 Posted January 8, 2019 (edited) 19 hours ago, Tractorhead said: Grabed a pic i found, to give you an idea, what i'm looking for To don't be missunderstood, i love my small 212 Horse and it works even better than i ever expected with the FEL. I didn't give it up and it will be kept, but i doubt, that it can be sensefully be used, to Plow a potato patch. this pic was a 4WD Kubota b5000. The B5000 is in the Kubota Grey market list below, dealers in the USA and Canada will not acknowledge the tractor nor are they permitted to sell you parts. Nothing wrong with a Grey just make sure the 3 point will accept north American made implements and that the PTO turns in the proper direction. https://www.kubotausa.com/gray-market-tractors Buyers Beware! Avoid "Gray Market” Used Kubota Tractors Used Kubota tractors, originally sold in Japan, are being imported into this country. These "gray market" units were not designed for sale in the United States. They were designed and manufactured for the Japan market and imported into the United States by individuals or entities independent of Kubota and without Kubota's authorization. These "gray market" units are different in several important respects from the tractors that Kubota makes for the United States, and which Kubota Tractor Corporation sells in the United States. These tractors are not ordinarily equipped with important safety equipment such as ROPS and seatbelt, PTO shield, safety decals, or operator's manual. Neither Kubota Tractor Corporation nor its affiliated company Kubota Corporation of Osaka, Japan, provides parts, service or any warranty support for Kubota "gray market" units in the United States. There is no responsibility whatsoever either by Kubota or its authorized dealers for these "gray market" units. Please be advised that since April 30, 1997, the importation, distribution and sale in the United States of Kubota "gray market" units under 50 PTO horsepower has been prohibited by a General Exclusion Order of the United States International Trade Commission. Kubota initiated this legal action because the unauthorized importation, distribution and sale of Kubota "gray market" tractors by individuals or companies independent of Kubota adversely affected Kubota's reputation in the United States and with the United States consumer. Following an extensive evidentiary hearing in the Fall of 1996, the United States International Trade Commission affirmed a finding by the Administrative Law Judge that the importation, distribution and sale of these "gray market" tractors infringed upon Kubota's registered trademark, issued a General Exclusion Order prohibiting further importation, and issued various Cease and Desist Orders against the respondents. In 1997, the Court of Appeals for the Federal Circuit in Washington, D.C. affirmed the Commission decision. Kubota intends to continue its efforts to ensure that the Orders of the United States Government, in this regard, are fully enforced. If you have any questions or wish to obtain a copy of this Order, please write to our General Counsel: Mr. Bruce Shanahan c/o Kubota Tractor Corporation 1000 Kubota Drive Grapevine, TX 76051 Phone Number: 817-571-0900 Tips to Identify Gray Market Tractors Check the Model Number: View a list of Kubota tractor models designed and manufactured for the Japanese Market (Gray Market Tractors) View a list of Kubota tractor models designed and manufactured for the US Market (not Gray Market Tractors) Check the labels and manuals: No safety or operation labels are written in English If an Operator Manual is provided, the model number on the face of the manual will differ from the model number on the tractor If a serial number plate is on the tractor, the information on the plate is written in Japanese The tractor may be equipped with Japanese rice paddy tires (much higher thread lugs than U.S. agricultural tires) and information on the tire is written in Japanese Some models have no over-running PTO clutch Contact Kubota Tractor Corporation Customer Satisfaction Department for assistance finding out if your tractor is a Gray Market Tractor. List of Gray Market Tractors Below is a list of Kubota models designed and manufactured for Japanese Market. Tractor Models Construction Models Models A-GB Models GB-GL Models GL-GT Models KJ-KT Models L-L1 Models L1-XB A-13 GB14 GL221 KJ11 L27 L1-20 A-14 GB15 GL240 KL21 L33 L1-22 A-15 GB16 GL241 KL23 L46 L1-24 A-17 GB18 GL260 KL25 L120 L1-26 A-19 GB20 GL261 KL27 L140 L1-28 A-30 GB110 GL268 KL30 L170 L1-33 A-155 GB130 GL277 KL33 L200* L1-38 A-175 GB140 GL280 KL36 L240 L1-43 A-195 GB150 GL281 KL43 L260* L1-45 B-10 GB160 GL300 KL28H L270 L1-185 B-40 GB170 GL301 KL31H L280 L1-195 B52 GB180 GL320 KL34H L350 L1-205 B72 GB200 GL321 KL38H L1500 L1-215 B92 GB115 GL337 KL41H L1501 L1-225 B1200 GB135 GL338 KL46H L1511 L1-235 B1400 GB145 GL350 KL50H L1801 L1-245 B1402 GB155 GL367 KL210 L1802 L1-255 B1500 GB175 GL368 KL230 L2000 L1-265 B1502 GL-19 GL400 KL250 L2002 L1-275 B1600 GL-21 GL417 KL270 L2200 L1-285 B1702 GL-23 GL418 KL300 L2201 L1-295 B1902 GL-25 GL430 KL330 L2202 L1-315 B5000 GL-26 GL467 KL210H L2402 L1-325 B5001 GL-27 GL470 KL230H L2600 L1-345 B6000* GL-29 GL530 KL250H L2601 L1-385 B6001 GL-32 GL600 KL270H L2602 L1-435 B7000 GL-33 GT-3 KL280H L2802 L1-455 B7001 GL-35 GT-5 KL310H L3001 T22 B1-14 GL-40 GT-8 KL340H L3202 X-20 B1-15 GL-43 GT19 KT20 L3500 X-24 B1-16 GL-46 GT21 KT22 L3602 XB-1 B1-17 GL-53 GT23 KT24 L4202 Bb260 GL200 GT26 KT27 L4214 GB13 GL201 GT30 KT30 L1-18 *L200 & B6000 models designed for Japan are different in numerous important respects from L200 & B6000 models designed for the United States. Tractor List last updated March, 2004. Edited January 8, 2019 by bcgold 1 Share this post Link to post Share on other sites
bc.gold 3,406 #11 Posted January 8, 2019 (edited) The Kubota B5000 was a very good tractor, the one I purchased was equipped as shown in the video below after removing the tiller I had installed an after market 3 point, the pto has three speeds. The rice paddy tires with the extra high lugs are a bit rough on solid ground. Edited January 8, 2019 by bcgold 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #12 Posted January 8, 2019 4 minutes ago, bcgold said: The Kubota B5000 was a very good tractor, the one I purchased was equipped as shown in the video below after removing the tiller I had installed an after market 3 point, the pto has three speeds. https://www.youtube.com/watch?v=jXwiAoL086E Hi, Thanks for your info's. While i'am outside of the US (over the great pond ) bigger Wheelhorses are here extremly rare to find. if so, the call astronomical prices for. Regards Stefan Share this post Link to post Share on other sites
bc.gold 3,406 #13 Posted January 8, 2019 7 minutes ago, Tractorhead said: Hi, Thanks for your info's. While i'am outside of the US (over the great pond ) bigger Wheelhorses are here extremly rare to find. if so, the call astronomical prices for. Regards Stefan I loved that B5000 it was the crappy snow blower with expensive parts that I did not cotton too and where I live you either have a snow blower or live in an old age home. We live on a small acreage with a very long driveway that I keep clear then also blow in walking trails so the missus can walk the dog. It quite funny watching a small dog trying to lift a leg in three feet of snow. The tiller worked great but you need to have the tractor in four wheel drive to keep the tiller from pushing you forward in excess. I tilled a large plot then planted a bunch of garlic that some borrowing ground critters ate before most of the bulbs before they had chance to grow. This year I'm going to have a go at been keeping, using a few traps to lure in a few swarms. Share this post Link to post Share on other sites
bc.gold 3,406 #14 Posted January 8, 2019 (edited) On 1/6/2019 at 4:37 PM, OILUJ52 said: I'm guessing that would be a Kubota B5000? My Neighbor has a Kubota B4200 and it has been pretty good almost trouble free, runs on sifter of fuel! Turning radius is pretty wide. Another one is the G series diesel, not so good I hear, rear end issues. Turning radius on my B5000 was tight with feather light steering. For an older tractor it was turn key from the day I purchased it and it never once gave me a lick of trouble in the two years that I owned it. Kubota engines are of high compression, higher than most diesels so you never want to use either on them. If the engine wont start in cold weather check your glow plugs make sure the wiring is not broken or corroded, if the tractor sleeps outdoors tarp it with a 100 watt light bulb overnight. Older Kubota engines are direct injection and these engines start better in cold weather than the newer indirect injection diesels, in fact the latter engines all seem to eventually end up with cylinder head cracks in the chambers. Edited January 8, 2019 by bcgold 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #15 Posted January 9, 2019 6 hours ago, bcgold said: Kubota engines are of high compression, higher than most diesels so you never want to use either on them. If the engine wont start in cold weather check your glow plugs make sure the wiring is not broken or corroded, if the tractor sleeps outdoors tarp it with a 100 watt light bulb overnight. Older Kubota engines are direct injection and these engines start better in cold weather than the newer indirect injection diesels, in fact the latter engines all seem to eventually end up with cylinder head cracks in the chambers. Hi, again thanks for your feedback. About the Enginecracks, i have heard same, but i also see - some "special experts" they providing the one and only "LPG quickstart" guideance or they use Brake Cleaner as Coldstart "Fireup- helper tool". This was in the past a bad habit even here in some Truck Companies. Especially in the late 70-ies also Mercedes, MAN, Büssing and and and- provides use LPG to fireup Cold Dieselengines. But in that timeline nobody think about the long term consequences. in later 80ies some Companies use both methodes as cheap fireup helper in Winter instead check them for good working conditions. "a little LPG injected in intake manifold was much cheaper, than an oilchange before Winter...." This where sentences i have heared not only once... I never try that issue after i have heard once a Dieselengine started by spray LPG in the intake manifold. Yes - the Engine starts immediately, even if it was bit worn and normally this engine should'nt fire up - not easy- but if you hear once that sound of such an Enginestart and you got a bit Fuel in Blood, you never wanna hear that sound again. Horrible - i heard the Engine deep inside crying abou this rape. To easy fireup an Dieselengine i learned two lessons: 1. To easy fireup an Dieselengine even if the engine is bit worn, use a Air preheater like a Hairdryer or similar and preheats the intakeair while fireing up. This is the gentlest procedure for the Engine to fireup ideal condition will shurely be a preheated Engine to Fireup - but mostly - it's a wish to have. 2. Oilchange Service direct short before Winter additional on older worn Engines half Oilchangeservice interval, fresh Oil lubricates better and an light worn engine cranks easier and starts easier. - LPG or Brake Cleaner as Fireup- helper is the wosest, you can do to an unwilling Diesel Engine. Cylinder and Headcracks will be results of such Engine Rape. 1 Share this post Link to post Share on other sites
Keith 21 #16 Posted January 20, 2019 On 1/8/2019 at 12:58 PM, bcgold said: The B5000 is in the Kubota Grey market list below, dealers in the USA and Canada will not acknowledge the tractor nor are they permitted to sell you parts. Nothing wrong with a Grey just make sure the 3 point will accept north American made implements and that the PTO turns in the proper direction. Other than the pto direction, I wouldn't be scared by the grey market Kubota. I have a grey market B6001. It is the same as a B6100. Unless you plan to have the Kubota dealer make all repairs, you should probably just purchase parts from an online site like Messicks. There is a good choice of used Kubota parts on Ebay. These tractors don't need a lot of repairs if they are regularly serviced. Many of these older B series have 70mm stroke engines in two or three cylinders with different bore. I believe the Japanese emissions regulations banned older diesels, and used tractors got dumped to buyers in other countries. The U.S. Kubota dealers complained of unfair competition. Kubota and other manufacturers claimed the used Asian sub-compact tractors were unsafe (lacked ROPS that were required in the U.S.) and lobbied the U.S. government to ban their importation. That safety campaign is interesting because Kubota provided a free ROPS upgrade for my grey market tractor - they did this because of some lawsuits from users who flipped tractors. Share this post Link to post Share on other sites
bc.gold 3,406 #17 Posted January 20, 2019 I believe the Kubota B6001 is the only Grey to have a counter clockwise rotating pto, there is an after market gear available to fix the issue. Here's a link to the discussion, https://tractorpoint.com/cgi-bin/tractorreview/pda_msgByThread.pl?parentnum=44749 Share this post Link to post Share on other sites
Keith 21 #18 Posted January 20, 2019 (edited) B6000 is counter clockwise rotation. The B6100 is standard. The Orange Tractor Talks site is the best resource. There were some planetary reverser adaptors produced for the B6000 but they hard to find. I'd heard that there is a way to disassemble the B6000 and swap some part to reverse the PTO, but nobody seems to know anymore how to do that. I'd bet that the parts from another Kubota would swap. Kubota's online parts reference helps me to find which parts can be swapped from model to model. I cross reference the part number with the Messicks lookup system and that returns all of the tractor models that particular part will work with. The B6100 is a 3 cylinder diesel. The B6000 is a slightly smaller displacement two cylinder. I believe - I may be wrong, that all of the original B series motors were 70mm stroke up to the four cylinder B9200. Towards the end of production some or the original B series had an option for hydrostatic transmission. My 4x4 Kubota weighs about 1,100 pounds, the B9200 weighs 50 percent more and its 3PH can lift much more weight. If you find an older Kubota that needs some work, buy it and repair it if the price is right. Parts are available. They tend to be parted out because the dealer's repair cost is too great, when it might need a $200 part - or less if you can find that part used on Ebay. Edited January 20, 2019 by Keith formatting Share this post Link to post Share on other sites
bc.gold 3,406 #19 Posted January 20, 2019 (edited) The real story behind surplus Japanese tractors and other grey market equipment along with automobiles, once a piece of equipment reaches a certain age it must be taken out of service and replaced with new - this keeps the wheels of industry rolling. Zen-Noh https://www.zennoh.or.jp/english/about_zen-noh/history.html Until the foundation of ZEN-NOH Where does Kubota Fit In? Well, when you are the number 1 agricultural cooperative in the world, Kubota will make tractors just for you and stick your name on them. Since ZEN-NOH is the largest agricultural coop in Japan, it has tractors, rice combines, wrapping machines and many other products – not just equipment, produced for them under their ZEN-NOH brand name by some of the largest companies in Japan – Kubota included. It is not unlike your local grocer having its own brand of cereal, salad dressings or pasta sauce – it had another company manufacture those items to its specifications. Kubota has manufactured literally thousands of tractors for ZEN-NOH over the years and labeled them right on the assembly line with the ZEN-NOH name plate. Often a Z prefix was added to the existing Kubota model number identifier making an L1501 into a ZL1501 tractor. Once built, the tractor was mated to a matching Kubota tiller and shipped directly to The Procurement Division of ZEN-NOH for their disposition. Edited January 20, 2019 by bcgold Share this post Link to post Share on other sites
ohiofarmer 3,475 #20 Posted January 20, 2019 Since there was interest in iseki, i will tell you my first hand experience. Iseki tractors were imported by White, now a part of Agco-Allis or whatever they call it today. My dad was getting up in years and he could no longer lever stones on to the stone boat to remove them from the ground. He needed a tractor with a front end loader to help him lift stuff and keep working past retirement age. This tractor was about 60 Horsepower and the thing that struck me was during the dealer preparing the tractor, part of the proceedure was using cloth sandpaper on the pins of the three point hitch. Show me an American tractor with such tight tolerances. Dad always took care of his machinery--always stored inside. the paint on the Iseki was thin and lost whatever gloss was there pretty quickly. everything else on the machine was just great. I would not be afraid of them from a quality standpoint 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #21 Posted January 24, 2019 On 20. Januar 2019 at 12:59 PM, ohiofarmer said: Since there was interest in iseki, i will tell you my first hand experience. Iseki tractors were imported by White, now a part of Agco-Allis or whatever they call it today. My dad was getting up in years and he could no longer lever stones on to the stone boat to remove them from the ground. He needed a tractor with a front end loader to help him lift stuff and keep working past retirement age. This tractor was about 60 Horsepower and the thing that struck me was during the dealer preparing the tractor, part of the proceedure was using cloth sandpaper on the pins of the three point hitch. Show me an American tractor with such tight tolerances. Dad always took care of his machinery--always stored inside. the paint on the Iseki was thin and lost whatever gloss was there pretty quickly. everything else on the machine was just great. I would not be afraid of them from a quality standpoint Thanks to all of you, for your open and honestly answers. i take a decision, will pickup next weekend. .... pic come soon .. Share this post Link to post Share on other sites
Dakota8338 115 #22 Posted January 25, 2019 I previously owned a Kubota B6000E, 12.5 HP, twin cylinder diesel engine with a three forward speed transmission & one reverse. It has been a few years since I traded it, but I am only remembering one range, but there may have been a low & high range. I believe that tractor was sold new in the USA since it came with an owners manual and other Kubota literature, although I purchased it used. It was an excellent little tractor, with one exception, the PTO rotated backwards for using any USA manufactured PTO driven equipment and the left hand rotating equipment designed for it cost about three times what standard right hand rotating equipment did. I purchased a PTO conversion unit for the little tractor so I could use standard right hand PTO rotating equipment. That conversion unit back in the early 1980's cost some $375. The B6000E being taller provided greater ground clearance over the 1979 WH C-141, I had at that time, allowing it to easily straddle rows with small plants making cultivation much easier than with the Wheel Horse, which required much wider middles for cultivation work. The WH could break ground more easily with the 12 inch turning plow than the B6000E could, so there were trade offs between the two very comparable units. The diesel consumed less fuel, as would be expected, but over all the B6000E was a great little tractor, but smaller than I desired so I eventually traded it for something else. 1 Share this post Link to post Share on other sites
Keith 21 #23 Posted January 25, 2019 That PTO reverser would sell for a good price today. My B6001 is 4wd. It has three speed with high and low range. It weighs about 150 pounds more than my Power King. The PTO has 3 speeds, normal rotation. I also have a L275 27 hp Kubota, but its a project. The cylinder heads often crack, it might be a maintenance issue with these. New cylinder heads are available. The L275 weighs more than a Ford 8N and has live PTO and shuttle shift. When these were new Kubota didn't offer hydrostatic transmissions. I have an extra Kubota transmission. I think the Kubota transmission would improve the Power King as its much beefier than the two BG T92s, but its also quite a bit wider so I'd have to modify the sheet metal to make it fit. I believe the 70 mm stroke Kubotas could be swapped from chassis to chassis. It is possible to build a configuration that Kubota never offered, given that overall length is respected. The 70 mm motors were available in two, three and four cylinder models. Tim Share this post Link to post Share on other sites
Tractorhead 9,217 #24 Posted January 25, 2019 It was once an affordable price, but more the optics what takes me to that decision... Opposite to my first decision, i choosed a 4WD. once again, i will plan and built my own FEL again from Aluminum, using the 1-st design, but get few improovements. Especially after i did my tests with first version, what impresses me same maybe most what that little thing last's. dimensions will be changed a bit. The weight i can lift isn't needed to increasing, even the liftheight was also perfect so far. 150Kg to lift is definiteley enough, more i don't want. My consideration is each Kilo i put on A Tractor additional, each faster it wear. But a rear 3point and few others are required.. Stay tuned.. Share this post Link to post Share on other sites
