Firebug 267 #1 Posted January 3, 2019 Just wanted to see if anyone had any experience with these tires. How they hold up etc. thinking of putting them on my c 160 plow project. Reading over the specs it said the section width is 4.2 with a rim width of 3. That’s a lot narrower than the stock rim width. I have seen videos of people cutting the rims to narrow or widen them, but that seems like a pia. Not sure what other rim options I have. I’m also thinking of filling them, and having a weight bracket off the front. Share this post Link to post Share on other sites
Firebug 267 #2 Posted January 3, 2019 Should have specified, that will have a dedicated brinley plow off the back, not a snow plow off the front Share this post Link to post Share on other sites
Dirtdog524 61 #3 Posted January 3, 2019 I haven't used the tri-rib tires but i do use the Ag tire Deestone and i am really satisfied. I am going on 4 years with these and they wear fine as well as have a good bite for snow removal. I would endorse them. 2 Share this post Link to post Share on other sites
Lee1977 7,638 #4 Posted January 3, 2019 (edited) I just put a set on my 312 on 3" wide rims. I like them makes steering a lot easer. I also used the 312 spindles for the 6" rims .I had reinforced them a couple years back. I have 25 x 900 x 12 All trail II on the back that I raised the fender bracket, gas tank, and rear fender. The front rim were WH trailer rims I had to take 3/4" width off the hub to make them fit. I chose to take it off the out side to make a wider stance. Edited January 3, 2019 by Lee1977 Add information 1 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted January 3, 2019 1 hour ago, Firebug said: Should have specified, that will have a dedicated brinley plow off the back, not a snow plow off the front these are destone and they work for me 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,559 #6 Posted January 3, 2019 I have deestone tri ribs on a 1076 and I think they are great. They really look good and work well, makes steering much easier. They won't work on those wide C160 rims, but firestone does make a tri rib in the correct size, it's just very expensive. You can get a set of the narrow wheel horse rims fairly cheap and swap spindles with an older machine if you want to go a cheaper route. 2 Share this post Link to post Share on other sites
Firebug 267 #7 Posted January 3, 2019 I like the way those look. I’ll have to start looking for the narrow rims. Those rims have a smaller Id I take so a spindle swap is also in order? What are the 3 inch rims you put on your 312? Original wheel horse rims? Share this post Link to post Share on other sites
Firebug 267 #8 Posted January 3, 2019 Sorry, I just reread that and saw they are wheel horse trailer rims Share this post Link to post Share on other sites
Achto 31,898 #9 Posted January 3, 2019 I'm running those on my plow tractor with the stock rims. 4 Share this post Link to post Share on other sites
Pullstart 70,103 #10 Posted January 3, 2019 I’ve got them on Putt Putt, Deestones front and rear. Share this post Link to post Share on other sites
Lee1977 7,638 #11 Posted January 3, 2019 (edited) 2 hours ago, Firebug said: I like the way those look. I’ll have to start looking for the narrow rims. Those rims have a smaller Id I take so a spindle swap is also in order? What are the 3 inch rims you put on your 312? Original wheel horse rims? They were 3/4" ID bushings in the rims I changed to 3/4" bearings. The hubs were 4 1/2" long we chucked them in the lathe and took off 3/4" to make them 3 3/4" long to fit on the 312 spindles.The 312 came wirh the little 6" rims and smaller tires. The 4 1/2" and 3 3/4" measurements were taken with the bearings installed to the out side of the bearings. Edited January 3, 2019 by Lee1977 1 Share this post Link to post Share on other sites
Firebug 267 #12 Posted January 3, 2019 Achto that is exactly what I’m looking to do with mine, and that look 1 Share this post Link to post Share on other sites
WHX?? 56,847 #13 Posted January 3, 2019 (edited) 4 hours ago, Mike'sHorseBarn said: They won't work on those wide C160 rims, but firestone does make a tri rib in the correct size, Mike is correct on the wider rims they will work but look goofy. He is spot on about the Firestones and is the only thing I would put on a beast of a C160 dang the cost. Miller tire is the only place you can get them and they are quite proud of them. In fact darn near the only place you can get a 16/6.50-8 tire these days is Miller. http://www.millertire.com/products/lawn-garden-tires/16x6-50-8/16x6-50-8-firestone-3-rib-front-4-ply/ I got these used for a little less than Miller from a fellow member. they are mounted on standard rims and look a little balloonish but not bad. I do have the Dees on my regular plow rig just like Dan's above with good results. Edited January 3, 2019 by WHX21 6 Share this post Link to post Share on other sites
Sparky-(Admin) 25,561 #15 Posted January 3, 2019 Can’t speak positive or negative about the Deestone tri-ribs, but I have used their AGs and wasnt to impressed with the size. Mine are supposed to be 23/8.50’s but they are both shorter and narrower. For that reason I would look at a different brand if I was in the market for rear AG tires. Again, I have no experience with their tri-ribs. Share this post Link to post Share on other sites
JoeM 10,032 #16 Posted January 3, 2019 The AG tires run smaller to size, 10.50's are closer to 8.50's. I have two sets mounted on two different FEL's and they have been pretty good. Only issue was one of the tires leaked slowly at the bead and I resealed it (re-popped), and it was never an issue again. Not sure if I didn't get it right the first time. They were pretty stiff being 6 ply. I have tortured them and have held up fine. I have a set of tri-rib but have not used them enough to comment. The brand seems good. Share this post Link to post Share on other sites
WHX?? 56,847 #17 Posted January 4, 2019 16 hours ago, Sparky said: Mine are supposed to be 23/8.50’s but they are both shorter and narrower. Aren't those Dees 23/10.5 you have on the back of yours Dan @Achto ? They don't appear to short or narrow to me? The rears on mine are Carlise tru-powers and seemed a little narrow but they are only 8.50's on the stock 1067 rims. Again a little $$ @ 100 a piece. 23/10.50's go for about a buck and a quarter. Very hard rubber, two seasons of use in the furrow and lots of running around at shows on gravel and asphalt and nubbies barely wore off. 16 hours ago, OILUJ52 said: one of the tires leaked slowly at the bead and I resealed it I had the same problem with the Firestone fronts. Only way to keep from losing air was to keep them at 16 psi or better but then they are hard as a rock. I prefer to run them at 10 lbs but are sure to leak at the bead and if the tractor sits they flat spot. Bead sealer helped but did not cure the issue. Probably caused by too small a rim. Tubes would fix everything. I'll live with it for now but keep the air chuck handy. 1 Share this post Link to post Share on other sites
Achto 31,898 #18 Posted January 4, 2019 2 hours ago, WHX21 said: Aren't those Dees 23/10.5 you have on the back of yours Dan @Achto ? No, those are Carlise's 8.50's on the back of mine. They are an older version of the Tru-Power's 1 Share this post Link to post Share on other sites
