Bow_Extreme 580 #1 Posted March 23, 2009 Well I figured I would ask your opinions on this before I decide to do this. I'm thinking about swapping my standard cement filled Wheel Horse weights for a steel set. I suppose I would do this more for asthetics than aything. I like the look of the steel weights. Would these weigh less or more than the cement filled. I would have to say much less but I could be wrong. Also, can you stack these weights at all or maybe just put in longer rods or blts to do this? Or should I stick with the current weights? Share this post Link to post Share on other sites
wheel horse 1045 2 #2 Posted March 23, 2009 depends on what type of steel weights you use i,ve had both Share this post Link to post Share on other sites
Coadster32 793 #3 Posted March 23, 2009 Don't forget, you can fill the tires with liquid also. I have a Charger12 that had cement filled plastic 55lb weights on it. I got a set of Tires filled, with no weights attached, and they weighed 75lbs each!! It's more pleasing to the eye than any weights. Now I can park it right next to the wall also. Hub caps may be in my future. :drool: Share this post Link to post Share on other sites
stevebo-(Moderator) 8,601 #4 Posted March 23, 2009 There are steel in which you can stack. They look like the farmall cub front weights. They have a nice look. They make some that fit inside the rim so they are flush mounted with the tire. The farmall ones are light so you will want to stack them. The flush mount set i have are heavier. I guess it depends on what you are looking for... Good luck- Share this post Link to post Share on other sites
