The Tuul Crib 7,354 #26 Posted December 24, 2018 Anyone have any idea where I can find one of these gas caps Share this post Link to post Share on other sites
AMC RULES 37,259 #27 Posted December 24, 2018 Might try looking through a "kohler gas cap" search on Ebay. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #28 Posted December 24, 2018 32 minutes ago, AMC RULES said: Might try looking through a "kohler gas cap" search on Ebay. No luck there Share this post Link to post Share on other sites
AMC RULES 37,259 #29 Posted December 24, 2018 Maybe not today... save the search, I've seen them there before. 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #30 Posted December 24, 2018 (edited) 9 minutes ago, AMC RULES said: Maybe not today... save the search, I've seen them there before. I just checked they are on there 19 bucks free shipping NEW OEM Kohler Fuel Cap Part Number: 236655-S THIS PART IS USED ON SOME OF THESE MODELS AND MORE: K161 K181 K241 K301 K321 K341 K91 Edited December 24, 2018 by jabelman 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #31 Posted December 24, 2018 2 hours ago, jabelman said: I just checked they are on there 19 bucks free shipping NEW OEM Kohler Fuel Cap Part Number: 236655-S THIS PART IS USED ON SOME OF THESE MODELS AND MORE: K161 K181 K241 K301 K321 K341 K91 This is the screw in cap # Share this post Link to post Share on other sites
The Tuul Crib 7,354 #32 Posted December 24, 2018 I actually found it on eBay and it's part number 10756. It's a gravely part with the same diameter as the tag on the wheel horse tractor Share this post Link to post Share on other sites
953 nut 67,521 #33 Posted December 26, 2018 Check these out. https://www.fillernecksupply.com/industrial-and-machine-bayonet-quarter-turn-filler-necks-caps/ 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #34 Posted December 26, 2018 13 hours ago, 953 nut said: Check these out. https://www.fillernecksupply.com/industrial-and-machine-bayonet-quarter-turn-filler-necks-caps/ That's exactly the That I need. Didn't know that you could get the filler neck to you as well but that is not needed and it's cheaper than fleabay!! Thanx!! 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #35 Posted December 27, 2018 On 12/16/2018 at 5:04 PM, formariz said: I have used this unusual method for years and its always been extremely effective. No chemicals no noise. Takes a little thinking and setting up but once you have the system set up , then every other time its cake. I have a thread about it here somewhere. Its just plain electrolysis. I first do the inside of tank then the outside. So the positive is the anode to the water inside the tank and the negative the cathode goes to the out side of the tank? Right? How much baking soda is needed? Share this post Link to post Share on other sites
WHNJ701 4,173 #36 Posted December 27, 2018 did you soak it vinagar Share this post Link to post Share on other sites
The Tuul Crib 7,354 #37 Posted December 27, 2018 23 minutes ago, jabelman said: did you soak it vinagar Yes I did but a guy at work said the best way to do it is electrolysis. He said you would not have to seal the inside of the tank after you do this. Soaking in vinegar does work but it will rust almost instantly after you rinse it out. Share this post Link to post Share on other sites
formariz 12,381 #38 Posted December 27, 2018 (edited) 22 hours ago, The Tool Crib said: So the positive is the anode to the water inside the tank and the negative the cathode goes to the out side of the tank? Right? How much baking soda is needed? Correct, positive goes to the anode(inside tank) and negative goes to tank. Plug the exit hole on the bottom of tank and attach negative clip to that. My anode is bent so its horizontal inside of tank and as long as possible. Just ensure that anode does not touch tank. I use a rubber stopper with a hole in it. Amount of baking soda is not too critical in such a small quantity of fluid. Half a cup is OK. Just mix it well . 22 hours ago, The Tool Crib said: Yes I did but a guy at work said the best way to do it is electrolysis. He said you would not have to seal the inside of the tank after you do this. Soaking in vinegar does work but it will rust almost instantly after you rinse it out. Keep in mind that immediately after cleaning with any method that uses liquid it will start to rust immediately as it becomes in contact with air. I dry them slowly over a kerosene heater for a few minutes each time as not to overheat metal. Then you can seal it with your sealer of choice. With all due respect to all other methods and people who use them, I don't believe there is a more efficient or effective method, particularly when it comes to the inside of an enclosure like that. Cleaning is 100% complete and it is scientifically proven. You just have to be patient and work out the method for this particular application. Fully research the process as to why and how it works and you will understand why I make such a statement. Edited December 27, 2018 by formariz Share this post Link to post Share on other sites
Pullstart 70,793 #39 Posted December 27, 2018 It wouldn’t work inside a tank, but has anyone ever seen laser rust removal? My father in-law told me about it last night... it blew my mind. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #40 Posted December 28, 2018 Holy cow where can I get one!! Share this post Link to post Share on other sites
The Tuul Crib 7,354 #41 Posted December 28, 2018 Just looked at the article on that and it sells for 480,000 dollars!! I think I'll stay with electrolysis! 1 Share this post Link to post Share on other sites
bottjernat1 2,196 #42 Posted December 28, 2018 1 minute ago, The Tool Crib said: Just looked at the article on that and it sells for 480,000 dollars!! I think I'll stay with electrolysis! Holy crap! WOW! maybe if we start a go fund me page. And call it save our horses! we can buy one. LOL 1 1 Share this post Link to post Share on other sites
jebbear 386 #43 Posted December 31, 2018 I vote for electrolysis. Follow-up with a rinse of phosphoric acid (if you can find it), if not vinegar (just takes a little longer). I would advise against muriatic acid, destroys to much too fast and always seems to rust immediately upon removal. Share this post Link to post Share on other sites
jebbear 386 #44 Posted January 1, 2019 On 12/27/2018 at 5:57 PM, pullstart said: anyone ever seen laser rust removal? On 12/28/2018 at 11:29 AM, The Tool Crib said: Just looked at the article on that and it sells for 480,000 dollars!! I think I'll stay with electrolysis! Jeeeezem Petes! I must say that is totally amazing, but $480,000, naaahhh! Electrolysis and vinegar! 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #45 Posted January 1, 2019 OK so I got my gas tank cleaned out looks good on the inside. Ended up using vinegar and setting for around two weeks. As I am blowing air into the tank I've noticed two tiny pin holes pushing out bubbles . Is there a solution to line the inside of the tank which he fix this ? Share this post Link to post Share on other sites
Horseoholic 258 #46 Posted January 1, 2019 This product here made by POR 15 is a gas tank sealant that is for this purpose also is great for covering "Light" rusty areas inside fuel tanks. After coating tank it looks like brand new and fuel will not harm coating, I used this on a Continental engine and Clinton engine's fuel tanks with real good results. It can be purchased from Amazon, it can be pricey but worth it. Share this post Link to post Share on other sites
WHNJ701 4,173 #47 Posted January 1, 2019 20 minutes ago, The Tool Crib said: OK so I got my gas tank cleaned out looks good on the inside. Ended up using vinegar and setting for around two weeks. As I am blowing air into the tank I've noticed two tiny pin holes pushing out bubbles . Is there a solution to line the inside of the tank which he fix this ? red cote Share this post Link to post Share on other sites
richmondred01 2,383 #48 Posted January 1, 2019 I’ve just sealed one using a three step kit. ive got enough to do another or I’ve got tanks. pm me if interested. Share this post Link to post Share on other sites
Pullstart 70,793 #49 Posted January 2, 2019 I sealed up an S-10 tank with JB Weld 2 part epoxy once, it was a “quick fix” to get where we were going on the side of the road, but still holds to this day, last I checked anyway! Being the side of the road, you can imagine how much prep work was involved... I think I wiped the area with a rag, then applied the epoxy. Share this post Link to post Share on other sites
richmondred01 2,383 #50 Posted January 2, 2019 I been using Hirsch products for 30 years. It also needs to be prepped with etch and dried with a mixture of toluene and methyl Ethel ketone. The process takes several days but when it’s done right it lasts. I did the tank in my 40 Ford 30 years ago and stil no issues. https://www.hirschauto.com/ALCOHOL-RESISTANT-GAS-TANK-SEALER/productinfo/GTS/ Share this post Link to post Share on other sites
