aghead 72 #1 Posted December 8, 2018 I have new firestone 16 6.50-8 tri ribs for my '78 C-101. I have some 8x 3.5" WH wheels that are too narrow for the tires, I think, are they too narrow? The tires call for 5 3/8" wide wheels. If not, I want NEW wheels in the wider size. What hub width will I need? I measure 3 3/4" wide x 3/4" bearings. Is this correct and if so where can I source new wheels? Firestone Tire Details: Overall Diameter: 16.4" Overall Width: 6.3" Ply Rating: 4 ply Tubeless Rim Width: 5-3/8" Tread Depth: 17/32" Max Load: 620 LB @ 28 PSI Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #2 Posted December 8, 2018 Have you tried eBay Amazon or Surplus Center... Share this post Link to post Share on other sites
aghead 72 #3 Posted December 8, 2018 What I have found is that they state the hub width and I am not sure how long the hub should be. (from inner to outer bearing) Share this post Link to post Share on other sites
The Tuul Crib 7,353 #4 Posted December 9, 2018 I just got some tires that are 4.80 4.00 x8 for the front of my 855. I thought at first they were going to be a little bit narrow for the rims but once mounted and aired up they look great! Share this post Link to post Share on other sites
aghead 72 #5 Posted December 9, 2018 ^ Those do look very nice! My prob is I have wider tires and narrow wheels. Share this post Link to post Share on other sites
The Tuul Crib 7,353 #6 Posted December 9, 2018 3 minutes ago, aghead said: ^ Those do look very nice! My prob is I have wider tires and narrow wheels. The 16 6.50 x8 should work . I don't like to put a larger tire on a rim than what is supposed to be. Like the 23 8.50 x 12. While the 10.50 would look cool you don't get the full effect of the tire. Share this post Link to post Share on other sites
aghead 72 #7 Posted December 9, 2018 ^ for the 6.50 width tire, they recommend a 5-3/8" wheel width. My wheel is 3.5". That's almost 2" difference. Share this post Link to post Share on other sites
The Tuul Crib 7,353 #8 Posted December 9, 2018 2 minutes ago, aghead said: ^ for the 6.50 width tire, they recommend a 5-3/8" wheel width. My wheel is 3.5". That's almost 2" difference. JMO I would stay with 4.80 4.00 x 8 then like I just installed on mine Share this post Link to post Share on other sites
oliver2-44 11,375 #9 Posted December 9, 2018 Post an add in the clasified section here and someone will probably have the rims you need. Miller tire has a selection of new rims $$ An important detail is how long your spindles are? My C81 C161 and C16o all have 16 by 6.5 by 8 tires on original wide front rims. So I would think you spindes are long enough, but it would be a good thing to check Share this post Link to post Share on other sites
Lee1977 7,632 #10 Posted December 9, 2018 My 312-8 the front spindles are 3 3/4". I used Wheel Horse trailer wheels that the hub measured 4 1/2" with the bearings installed I had to remove 3/4" to make them fit. The rim width was 3" and worked great with The 400 x 8 tri ribs. Share this post Link to post Share on other sites
aghead 72 #11 Posted December 9, 2018 1 hour ago, The Tool Crib said: JMO I would stay with 4.80 4.00 x 8 then like I just installed on mine Problem is I already have the new tires (16 6.50-8). The narrow wheels arrived after tires and were not the wide wheels, but 3.5" wheels. I figured mi 1978 c-101 had the wide rims. The beads on the narrow wheels are too rusted to clean up and mount tubeless, so I need/want new wheels. Even if I used tubes, I am unsure of the tire & narrow rim ability to work. I don't have any other wheels to measure the hub width (outside bearing to inside bearing?) I need this measurment to ensure correct new wheels. These narrow wheel's hub width measure about 3-3/4". Share this post Link to post Share on other sites
aghead 72 #12 Posted December 9, 2018 5 minutes ago, Lee1977 said: My 312-8 the front spindles are 3 3/4". I used Wheel Horse trailer wheels that the hub measured 4 1/2" with the bearings installed I had to remove 3/4" to make them fit. The rim width was 3" and worked great with The 400 x 8 tri ribs. Ok, 3 3/4" hub width. Thanks! My rim is 3.5", My tires are 6.50-8" tri ribs. I assume tires are too wide for the rims. Thank you...and good engineering on adapting your wheels.! Share this post Link to post Share on other sites
Pullstart 69,607 #13 Posted December 9, 2018 You could always try to mount them to see if you like the look... the rubber won’t be able to tell you that the wheel is too narrow, it’ll be your preference on how it bulges... a set of tubes will be cheaper than another set of wheels most likely... Share this post Link to post Share on other sites
ericj 1,579 #14 Posted December 9, 2018 (edited) 1 hour ago, aghead said: Problem is I already have the new tires (16 6.50-8). The narrow wheels arrived after tires and were not the wide wheels, but 3.5" wheels. I figured mi 1978 c-101 had the wide rims. The beads on the narrow wheels are too rusted to clean up and mount tubeless, so I need/want new wheels. Even if I used tubes, I am unsure of the tire & narrow rim ability to work. I don't have any other wheels to measure the hub width (outside bearing to inside bearing?) I need this measurment to ensure correct new wheels. These narrow wheel's hub width measure about 3-3/4". I have the Firestone tri-ribs 16x6.50x8, they came on my loader tractor. I replaced them with 18x8.50x8 I believe 5 ribs on the loader. I then put the tri-ribs on my utility 520 that I plow snow with and use the garden plow on. I can tell you you will need another set of the wider rims to put your tires on, I don't believe they will fit on the narrow rims that you have. Check the classified adds on here. I might have a set of rims, but it would be awhile till I could get a chance to even look for them,, and if they are off a tractor not sure what length spindle they would have come off of. The C101 should have come with the wide rims, could you check the rims on the B80, maybe swap rims if they are eric j Edited December 9, 2018 by ericj Share this post Link to post Share on other sites
WildmanC120 613 #15 Posted December 9, 2018 I bought the narrow rims from Miller's the other day and the wheel hubs ate too narrow for my tractor spindles. I had to make a spacer to get them to fit. Share this post Link to post Share on other sites
aghead 72 #16 Posted December 9, 2018 1 hour ago, WildmanC120 said: I bought the narrow rims from Miller's the other day and the wheel hubs ate too narrow for my tractor spindles. I had to make a spacer to get them to fit. Thanks for the info. Exactly what I needed to know! The wide rims at Millers are also 3/4" too narrow at only 3" wide hubs. Share this post Link to post Share on other sites
aghead 72 #17 Posted December 9, 2018 2 hours ago, ericj said: I have the Firestone tri-ribs 16x6.50x8, they came on my loader tractor. I replaced them with 18x8.50x8 I believe 5 ribs on the loader. I then put the tri-ribs on my utility 520 that I plow snow with and use the garden plow on. I can tell you you will need another set of the wider rims to put your tires on, I don't believe they will fit on the narrow rims that you have. Check the classified adds on here. I might have a set of rims, but it would be awhile till I could get a chance to even look for them,, and if they are off a tractor not sure what length spindle they would have come off of. The C101 should have come with the wide rims, could you check the rims on the B80, maybe swap rims if they are eric j Perfect info, what I've been needing to know! The B80 has the wide wheels. I thought it did. (I finally got home to check) Its tires are too good to break down to use the wheels, and the narrow wheels I received are way rusted/pitted where the tire beads. I hate to even spend time on them to try them out on the b80. I guess a tube would work? I also assumed the C101 had the wide wheels. (it came with little yellow wheels) Thanks! Share this post Link to post Share on other sites
