ebinmaine 77,123 #1 Posted November 26, 2018 I have several starter-generator setups here... only one is a Wheelhorse original. I need to find a mechanical voltage regulator that I can use but I have no way of knowing what these came off of or how to look one up. I don't see any part numbers on them. Three posts on one side. One on the bottom. How can I go about finding one of these? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #2 Posted November 26, 2018 Have never known of any other supplier of the starter/generator than Delco but there could have been. B&S service manual. Click on the pictures to find the chapter. Kohler Wheel Horse did use a B&S engine with a starter/generator but forget which model. Garry 2 Share this post Link to post Share on other sites
pfrederi 19,810 #3 Posted November 26, 2018 You can use either a 3 terminal or 4 terminal regulator. Other than 6 or 12 volt they are all pretty much the same. Some are marked positive ground but my S/G guy said it really didn't make any difference.... 1 1 Share this post Link to post Share on other sites
ebinmaine 77,123 #4 Posted November 26, 2018 @pfrederi What's the fourth terminal that does not get used? You just kind of toss that wire on the workbench and not worry about it? Share this post Link to post Share on other sites
pfrederi 19,810 #5 Posted November 26, 2018 Instead of the A terminal on the bottom of a 4 terminal unit it is on the top of a three terminal. The L terminal is not there on a 3 term unit If you have something that needs it you piggy back on the Bat terminal 2 Share this post Link to post Share on other sites
ebinmaine 77,123 #6 Posted November 26, 2018 Just now, pfrederi said: Instead of the A terminal on the bottom of a 4 terminal unit it is on the top of a three terminal. The L terminal is not there on a 3 term unit If you have something that needs it you piggy back on the Bat terminal Simple enough. Paul, you're a gentleman and a scholar. Thank you. 1 Share this post Link to post Share on other sites
