The Tuul Crib 7,340 #1 Posted November 25, 2018 The last few times I have started my 414-8 It is clicked and clicked when I turn the key then it would start.To me it sounds like I might be having problems with the starter. Not really sure what it might be. Any ideas? Share this post Link to post Share on other sites
ebinmaine 77,126 #3 Posted November 25, 2018 @953 nut He has nailed it I believe. 2 Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted November 25, 2018 Definitely sounds like a bad, loose, or corroded connection! 2 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #5 Posted November 26, 2018 Will give it a look. Share this post Link to post Share on other sites
LengerichKA88 1,885 #6 Posted November 27, 2018 Have you tried beating it with a hammer? If so, try a bigger hammer? 😂 Share this post Link to post Share on other sites
953 nut 63,986 #7 Posted November 27, 2018 2 hours ago, KyleLengerich said: Have you tried beating it with a hammer? If so, try a bigger hammer? 😂 you will crack the magnets! Share this post Link to post Share on other sites
LengerichKA88 1,885 #8 Posted November 27, 2018 13 minutes ago, 953 nut said: you will crack the magnets! I know, I just couldn’t resist. That was always a buddy mines response to starter questions. 1 Share this post Link to post Share on other sites
Tractorhead 9,216 #9 Posted November 27, 2018 First check all electrical connections, mostly a scruffy connection to + or ground is the reason for. Depending of type of starter it give 2 posibillities. a gear, that snaps up while powering , lifted by a release fork. a gear that snaps while starter torques. if not dismount the starter frome Engine and verify, if startergear moves easy while powering. (take care of torque of starter while powering) if startergear don't moves easy, use MOS2 spray on startergearshaft. just my 2 cents Share this post Link to post Share on other sites
The Tuul Crib 7,340 #10 Posted November 28, 2018 21 hours ago, KyleLengerich said: Have you tried beating it with a hammer? If so, try a bigger hammer? 😂 28 oz framing hammer? Share this post Link to post Share on other sites
LengerichKA88 1,885 #11 Posted November 28, 2018 (edited) 22 minutes ago, The Tool Crib said: 28 oz framing hammer? I always use a 3# sledge 😂🤣 All seriousness though, we’re you able to figure it out? Edited November 28, 2018 by KyleLengerich Share this post Link to post Share on other sites
The Tuul Crib 7,340 #12 Posted November 28, 2018 7 minutes ago, KyleLengerich said: I always use a 3# sledge 😂🤣 All seriousness though, we’re you able to figure it out? Haven't had a chance to get to it because of the holiday season may try this weekend let you know Share this post Link to post Share on other sites
LengerichKA88 1,885 #13 Posted November 28, 2018 25 minutes ago, The Tool Crib said: Haven't had a chance to get to it because of the holiday season may try this weekend let you know I was just curious. I’m having starter issues, so I’ve been paying attention to all the threads related lol. Share this post Link to post Share on other sites
Tractorhead 9,216 #14 Posted November 28, 2018 If Your Tractorengine wont electric start, push it 😂 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #15 Posted November 28, 2018 7 hours ago, KyleLengerich said: I was just curious. I’m having starter issues, so I’ve been paying attention to all the threads related lol. Just got home from work cleaned up the terminals got to the starter connection and low and behold it was loose! Cleaned all the connections no problems now! 1 1 Share this post Link to post Share on other sites
LengerichKA88 1,885 #16 Posted November 28, 2018 I got mine squared away too! Did yiu also take it for a victory lap around the yard, or was that just me? 😂 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #17 Posted November 28, 2018 8 minutes ago, KyleLengerich said: I got mine squared away too! Did yiu also take it for a victory lap around the yard, or was that just me? 😂 Well know that must've been just you. It's a little cold right now so I'm inside warming up. 1 Share this post Link to post Share on other sites
Tractorhead 9,216 #18 Posted November 29, 2018 6 hours ago, The Tool Crib said: Well know that must've been just you. It's a little cold right now so I'm inside warming up. Maybe you need a seat heater.....👍😂 Share this post Link to post Share on other sites
