WildmanC120 613 #1 Posted November 8, 2018 Probably going to put the carlisle tru power ags on the back of this. Cannot decide on 8.5 or 10.5" width. Looking to see everyone's setup. Also, what will look good in the front? This will be the machine running my snowblower and probably mowing a few acres a week come the summer. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #2 Posted November 8, 2018 Here is one of my tractors are used some 8.50 x 12 works good for me 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #3 Posted November 8, 2018 23x8.50x12 Carlisle power tracs on the Sears compact 8e and 23x10.50x12 Goodyear (same tread has hi-runs and other brands) on the other. I don't run ags on wheel horses except 701 which are original ones. The power tracs do the best out of all I tried. I do have bkt trentchers on a craftsman size 23x10.50x12. They do alright 1 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #4 Posted November 8, 2018 I do have set of b.f. Goodrich 6-12 ags for 552 wheel horse. It does ok but they vibrate the entire tractor while getting grip Share this post Link to post Share on other sites
ebinmaine 72,418 #5 Posted November 8, 2018 10.5 AG's rear 20 x 8 x 8 turfs front All 4 liquid filled. 3 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #6 Posted November 8, 2018 I like the OTR LAWN TRAC R1s, very close to size stated and didn't need chains running the 2stage last year, you can get tri-ribs in 16x6.50-8 but they are kinda pricey, I'm planning on a set of the same OTRs in 16x7.50-8 for the front of my blower tractor, good luck, Jeff. 2 1 Share this post Link to post Share on other sites
Tankman 3,523 #7 Posted November 8, 2018 Like the ag's but, don't need 'em much nowadays. Turfs and chains work well when pushing wet white cold junque. Do use ag's on my Allis. Always set up with a mid mount grader. http://www.millertire.com/categories/lawn-garden-tires/ 4 Share this post Link to post Share on other sites
peter lena 9,233 #8 Posted November 8, 2018 those 8.50 tires work good for me, being narrower they tend to get thru snow easier , and work very well with chains. the wider tires would be more likely give you a traction issue, because they are a softer foot print. recently picked up tires at wal mart as well at t/s good pricing and free to store shipping at both. I also used these stores , because the tires were not " crushed flat " in transport. that's important , trying to inflate a pancaked tire is not a good time. I also use , FLUID FILM as a tire lubricant , because of its rust stopping abilities inside the rim. good luck with your choice, pete 1 Share this post Link to post Share on other sites
71_Bronco 1,072 #9 Posted November 8, 2018 (edited) Not ags like you're talking about, but I went with Kenda Terra Trac's for my Bronco 14. These are 23x10.5-12 on 7" wide wheels. Also, i like having the fronts match, so the fronts will be the same. I went with these cause they are more aggressive than turfs, but not as much as ags Edited November 8, 2018 by 71_Bronco 4 1 Share this post Link to post Share on other sites
ACman 7,655 #10 Posted November 8, 2018 Those ORT,s @WVHillbilly520H have came stock on my kubota BX2230 and are a great tire . Check out Carlisle prices at Walmart https://www.walmart.com/ip/Carlisle-Tru-Power-Lawn-Garden-Tire-23X1050-12-LRB-4-ply-Wheel-Not-Included/150237909 . Be sure to look at HiRun Brand while your there too . 1 Share this post Link to post Share on other sites
Digger 66 3,488 #11 Posted November 8, 2018 I'll play.... 3 Share this post Link to post Share on other sites
WildmanC120 613 #12 Posted November 8, 2018 Thanks for all the pics so far. Keep them coming. Any of the rear to see width would be helpful. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #13 Posted November 8, 2018 Here's the MFG'S page...https://otrwheel.com/product/otr-lawn-trac/...from there you can check out all there different styles, Jeff. 1 Share this post Link to post Share on other sites
WildmanC120 613 #14 Posted November 8, 2018 3 minutes ago, WVHillbilly520H said: Here's the MFG'S page...https://otrwheel.com/product/otr-lawn-trac/...from there you can check out all there different styles, Jeff. Would those in 10.5 fit my rims? Share this post Link to post Share on other sites
AlexR 1,814 #15 Posted November 8, 2018 (edited) Deestone ag rear tires 23x10.5-12 people are right when they tell you these run small on width mine are in reality maybe a hair over 8 1/2 inches wide. I wanted more or less stock width so worked out great for me. Fronts are deestone 4.00x8 triribs Best rear photo I could find. Edited November 8, 2018 by AlexC120 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #16 Posted November 9, 2018 31 minutes ago, WildmanC120 said: Would those in 10.5 fit my rims? They will fit but they may "bulge" a bit at the sidewalls I put (NanKang)10.50s on my dad's Cub with the 7.5" wide wheels here's what they look like... 1 1 Share this post Link to post Share on other sites
AlexR 1,814 #17 Posted November 9, 2018 2 hours ago, Digger 66 said: I'll play.... Pretty sure this photo was the inspiration for me getting the tires I did. Cool tractor! 1 Share this post Link to post Share on other sites
pfrederi 18,635 #18 Posted November 9, 2018 Saying Deestones run small would be an understatement..Carlisle 10.50 vs Deestone 10.5 Share this post Link to post Share on other sites
Sparky-(Admin) 23,128 #19 Posted November 9, 2018 My vote is for the Carlisle All Trails for best all around traction ( and they are dang cool ). Mine are 23/10.5's. The ags are 23/10.5's on 8.5" wide rims. 2 1 Share this post Link to post Share on other sites
michaelb 0 #20 Posted November 9, 2018 i need a diagram on drive belt routing 1970 charger 10 Share this post Link to post Share on other sites
WildmanC120 613 #21 Posted November 10, 2018 Ended up ordering Tru powers in 8.5 width. The price was right and the width will fit my rims I already have. Plus should work well at that width since I will be using them in the snow this year. Now I just gotta figure out what I want on the front. Share this post Link to post Share on other sites
ebinmaine 72,418 #22 Posted November 10, 2018 5 hours ago, WildmanC120 said: Now I just gotta figure out what I want on the front. Turfs with a single wrap-around chain for snow/ ice steering traction? Run without the chain for 3 season usage on grass. 1 Share this post Link to post Share on other sites
RandyLittrell 3,903 #23 Posted November 10, 2018 On 11/8/2018 at 6:59 PM, pfrederi said: Saying Deestones run small would be an understatement..Carlisle 10.50 vs Deestone 10.5 WOW, first time I have seen someone post side by side pics and it really tells the story of how much difference there is!! Randy 1 1 Share this post Link to post Share on other sites
WildmanC120 613 #24 Posted November 10, 2018 7 hours ago, ebinmaine said: Turfs with a single wrap-around chain for snow/ ice steering traction? Run without the chain for 3 season usage on grass. Im torn between a rib tire and a turf tire. I think the ribs go well with the AGs and would make steering lighter. The wide turfs I think look a little better. The struggle is real haha. 1 Share this post Link to post Share on other sites
ohiofarmer 3,371 #25 Posted November 12, 2018 (edited) There is a mini-bike supply store in my area that has the 12 inch wheel size 4 ply rated ATV 4 wheeler tires for $80.00 a set..of two... I am tempted for at least one of my herd.... Edited November 12, 2018 by ohiofarmer Share this post Link to post Share on other sites
