ebinmaine 77,518 #1 Posted November 1, 2018 I picked up an 8 speed transmission of unknown year or model the other day from a fellow redsquare member. The right hand axle tube has a crack in it so I'm going to take it apart and check over the internals to see what's usable for the future for me. I have the 8-speed that came out of a 1974 c-160 that is very tired and sloppy. It is most likely that I'll combine the best of those two Transmissions. What are the really common issues or things that I should be looking for to try to save? Share this post Link to post Share on other sites
Pullstart 68,944 #2 Posted November 1, 2018 I’d save all the parts! 3 3 1 1 Share this post Link to post Share on other sites
pfrederi 19,943 #3 Posted November 1, 2018 22 minutes ago, pullstart said: I’d save all the parts! 1 1 Share this post Link to post Share on other sites
WHX?? 55,197 #4 Posted November 1, 2018 1 hour ago, ebinmaine said: should be looking for to try to save must be having a on that question! 2 Share this post Link to post Share on other sites
ebinmaine 77,518 #5 Posted November 1, 2018 Just now, WHX21 said: must be having a on that question! I was blond when younger. Long since gone all gray. Still no smarter. 1 3 Share this post Link to post Share on other sites
TravelinJavelin 621 #6 Posted November 1, 2018 hey if the shift rails are good and and if yuo can spare 4 pinions i'll buy them from you 2 1 Share this post Link to post Share on other sites
ebinmaine 77,518 #7 Posted November 1, 2018 34 minutes ago, TravelinJavelin said: hey if the shift rails are good and and if yuo can spare 4 pinions i'll buy them from you Pm sent Share this post Link to post Share on other sites
buckrancher 2,696 #8 Posted November 2, 2018 Hi Low range shift fork and axles 1 1 Share this post Link to post Share on other sites
ebinmaine 77,518 #9 Posted November 2, 2018 1 minute ago, buckrancher said: Hi Low range shift fork and axles Which brings another question to Mind Brian. Travelin Javelin, Brandon, wants to buy some shift forks for his 953. Is there a slide rule or micrometer measurement I can take to see if the ones I have are any good? The transmission itself shifts quite loosely. Share this post Link to post Share on other sites
The Tuul Crib 7,347 #10 Posted November 2, 2018 14 hours ago, ebinmaine said: Pm sent Save the wish bone! Thanksgiving is near! 3 Share this post Link to post Share on other sites
WHX?? 55,197 #11 Posted November 2, 2018 3 hours ago, buckrancher said: Hi Low range shift fork and axles And hi/lo gear... Share this post Link to post Share on other sites
stevasaurus 23,620 #12 Posted November 2, 2018 The shift rails never wear out...if the shifter is sloppy, it is because of the adjustment of the dog point set screw...or the ball on the shifter...or the shift forks themselves. 2 Share this post Link to post Share on other sites
ebinmaine 77,518 #13 Posted November 2, 2018 1 minute ago, stevasaurus said: The shift rails never wear out...if the shifter is sloppy, it is because of the adjustment of the dog point set screw...or the ball on the shifter...or the shift forks themselves. Okay cool so if Brandon is looking for rails and pinions I should be able to help him out 1 Share this post Link to post Share on other sites
953 nut 64,283 #14 Posted November 2, 2018 12 minutes ago, ebinmaine said: Brandon is looking for rails and pinions I should be able to help him out If the axles on your trans are 1 1/8" you probably should send Brandon @TravelinJavelin the whole differential. 1 Share this post Link to post Share on other sites
ebinmaine 77,518 #15 Posted November 2, 2018 2 minutes ago, 953 nut said: If the axles on your trans are 1 1/8" you probably should send Brandon @TravelinJavelin the whole differential. That's true. I don't know what size those axles are. I'm hoping to tear into this tomorrow morning. Share this post Link to post Share on other sites
stevasaurus 23,620 #16 Posted November 2, 2018 His axles are 1 1/8"...if you are going to send him just the pinions...count the teeth just to make sure they are the same. The pinions should be the same. The axle length could be different though. :) 1 Share this post Link to post Share on other sites
953 nut 64,283 #17 Posted November 2, 2018 2 hours ago, stevasaurus said: count the teeth just to make sure they are the same. The pinions should be the same. The axles on @TravelinJavelin 953 have been cut for the snap rings already so a complete differential seemed to be the way to go. The shipping will be higher, but the piece of mind is 3 Share this post Link to post Share on other sites
TravelinJavelin 621 #18 Posted November 6, 2018 that tranny if its a 1974 it should be a 5091 model which the 1 1/8th axles so this should be golden for sure! Share this post Link to post Share on other sites
