dave647 27 #1 Posted October 23, 2018 how critical is the thickness of the facing material? do you recommend rivets or glue? i can get john deere clutch discs for $20 but they are .160 thickness. does the pto clutch have it's own oil reservoir and if so how to add oil (amount and type) any help will be appreciated. thanks dave Share this post Link to post Share on other sites
pfrederi 20,903 #2 Posted October 23, 2018 I just put a new lining on an older Charger 10 (6" PTO) it is .125 thick The old 6 inch PTOs were riveted the new 6-3/4 inch are bonded. Might be easier to glue the JD one on.... The outer ball bearing is sealed the inner needle bearing needs some grease applied to it. 1 Share this post Link to post Share on other sites
dave647 27 #3 Posted October 23, 2018 would it be advisable to drill and tap for a zerk? i have installed zerk at brake and clutch pedals and installed a remote zerk at the left side of cowl for the steering bushing. thanks Share this post Link to post Share on other sites
Lost Pup 187 #4 Posted October 24, 2018 6 hours ago, dave647 said: would it be advisable to drill and tap for a zerk? i have installed zerk at brake and clutch pedals and installed a remote zerk at the left side of cowl for the steering bushing. thanks Luv to see a pic of the remote zerk to the steering bushing. Share this post Link to post Share on other sites
dave647 27 #5 Posted October 24, 2018 i am old school and will have to figure out the photo process. i hate computers. and cell phones,and electronic ignitions,and safety switches,and lawyers,and politics,and ......... 1 2 Share this post Link to post Share on other sites
953 nut 67,517 #6 Posted October 24, 2018 4 hours ago, dave647 said: have to figure out the photo process. Once the photo has been downloaded to your computer the process of adding it to your post is rather easy. Just go down near the paper clip symbol and left click on the choose files... which will take you to your computer's photo file. Select the photo you wish to post and double click on the photo. The computer will now come back to the posting and the photo will be at the bottom of the page. Click on the "+" sign on the photo and it will be added to your post. Give it a try! 1 Share this post Link to post Share on other sites
pfrederi 20,903 #7 Posted October 24, 2018 14 hours ago, dave647 said: would it be advisable to drill and tap for a zerk? i have installed zerk at brake and clutch pedals and installed a remote zerk at the left side of cowl for the steering bushing. thanks No. A zerk may lead to over greasing. Excess grease will get on you friction surface. Pull the PTO bell once or twice a season. N work some grease into the needle bearing but not an excessive amount 1 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #8 Posted October 24, 2018 Can the face of the clutch wheel be turned like a brake rotor? Share this post Link to post Share on other sites
Skipper 1,792 #9 Posted October 24, 2018 yes, but don't make it too thin 1 Share this post Link to post Share on other sites
pfrederi 20,903 #10 Posted October 24, 2018 (edited) 1 hour ago, The Tool Crib said: Can the face of the clutch wheel be turned like a brake rotor? May be too small a diameter for the machines...but why would you want to?? I have never seen a bell with a damaged surface other than some rust that you can take off with some emery cloth. The brass rivets do not damage the steel bell. Besides you can get good used bell for not much more than a shop would charge to resurface...if they could do it. Edited October 24, 2018 by pfrederi 1 1 Share this post Link to post Share on other sites
dave647 27 #11 Posted October 24, 2018 here comes the pictures. they are not award winning (my first attempt) any questions please ask. steering bushing is a steel 3/4 id x 1" od with a 1" stop collar welded to it. drilled thru set screw location on stop collar. used a 1/4" brake line and a 3/8" x 1/8" reducer bushing to screw zerk into. 1 1 Share this post Link to post Share on other sites
dave647 27 #12 Posted October 25, 2018 more pictures 1 2 Share this post Link to post Share on other sites
Pullstart 70,789 #13 Posted October 25, 2018 Great idea! Share this post Link to post Share on other sites
