USHorse 41 #76 Posted November 18, 2018 Sorry....for the PTO Share this post Link to post Share on other sites
WildmanC120 615 #77 Posted November 18, 2018 42 minutes ago, USHorse said: Sorry....for the PTO So I ran power from battery to inline fuze holder, to switch then switch to PTO. PTO grounded to engine. Share this post Link to post Share on other sites
mpoore 26 #78 Posted yesterday at 06:22 AM I know this is an old topic, but I am hoping someone can clarify some things for me. I am attempting to replace a KT19 Series I in a C-195. The 22hp Predator seems like a good option given there are not a lot of options.The documentation is not as detailed as I would like, but I see no indication of ball bearings in the version of the engine being sold today. Some others posted it might have ball bearings. That could be an earlier version. They do not list the alternator output, so I cannot confirm that it is sufficient for an electric pto, but it would seem that it is since that's what others have done. I do see an internal thrust washer in the diagram. Has anyone tried to replace that with a torrington bearing? I wonder if there is enough room because that might be a way to use the manual clutch. Lastly, I am guessing that Predator engines share parts with a brand name engine. I see it advertised to replace a Honda GX630 or a Vanguard. I doubt it is a Vanguard clone because those have ball bearings.I would like to know I can get parts from other sources than HF. Being stuck ordering parts from HF is enough to hold out a little longer for a deal on something better supported. I have a K532 that I would love cram in there if I could find a governor for it. Ebay sellers are asking $200 for the governor. The cost of a governor and a rebuild kit is getting to the point that a new Predator is tempting. Share this post Link to post Share on other sites
pfrederi 21,056 #79 Posted yesterday at 01:07 PM Electric PTOs draw less than 4 amps Share this post Link to post Share on other sites
mpoore 26 #80 Posted 21 hours ago If its only 4 amp, then it should not be a problem. Another post made me think it was around 10 amps, which seemed like a potential problem depending on alternator output. Share this post Link to post Share on other sites
pfrederi 21,056 #81 Posted 2 hours ago 18 hours ago, mpoore said: If its only 4 amp, then it should not be a problem. Another post made me think it was around 10 amps, which seemed like a potential problem depending on alternator output. Electro 12s had Electric PTOS lights and a lighter on a 10 amp charging system. Share this post Link to post Share on other sites
