T-Mo-(Moderator) 4,928 #1 Posted October 17, 2018 Found this Cub Cadet 100 on CL. Ad says it still runs, but needs a "car" battery. It has the 42 inch front blade with it. Ad also says it's a 1960, which we all know is incorrect since IH didn't sell their first L&G until 1961, and it was the Original. The 70 and 100 came out later, in 1963. Anyways, it doesn't run and has at least the starter/generator froze up, if not the engine (let's hope not!!!!). Seller says it needs a coil, but I have to address that when I can access the engine and the S/G situation. It was a brother and sister who had it, it was their dad's who bought it new. They still have the operator's manual for it. Deck worn out long, long ago, and after seeing their yard, I can understand why. I told him the rear tires were on backwards, but he said they were always like that and I wasn't the first one to point that out. I didn't get it home until late last night, so the only pictures I have is from the ad. 10 2 Share this post Link to post Share on other sites
Jerry77 1,218 #2 Posted October 17, 2018 (edited) I had a 62....the one in the pix is a later model..maybe 64 or 65? mine was an original with 7 hp and oil bath air cleaner and 38 in deck..that frame looks even later than that... Edited October 17, 2018 by Jerry77 found the emoji Share this post Link to post Share on other sites
71_Bronco 1,072 #3 Posted October 17, 2018 Hopefully it's an easy fix on the motor. Neat looking tractor, congrats Share this post Link to post Share on other sites
Razorback 1,370 #4 Posted October 17, 2018 Looks promising. I hope you can get it running! Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,928 #5 Posted October 17, 2018 42 minutes ago, Jerry77 said: I had a 62....the one in the pix is a later model..maybe 64 or 65? mine was an original with 7 hp and oil bath air cleaner and 38 in deck..that frame looks even later than that... I'll have to check the serial number as soon as I can....as I said the 100 didn't debut until 1963 and was built through 1965 when it got replaced by the 102, 122, 123 (plus the 71 replaced the 70). Share this post Link to post Share on other sites
ebinmaine 80,481 #6 Posted October 17, 2018 Early Cub is what got me interested in the GT stuff in the first place. My grandfather had a yellow/white one I remember from the 1970s and bought a red (682??) Around 1980. Looking forward to seeing how this one turns out. Please keep us posted. And as always... More. would be awesome. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #7 Posted October 17, 2018 Good deal, I grew up on an Original and a 106 was my first (out on my own) garden tractor, still have the Original that has been upgraded with a 70s 8hp from a Gravely, and most of the cubs through the 90s were decent machines even after MTD took over in the mid 80s, Jeff. 3 Share this post Link to post Share on other sites
WHX?? 57,950 #8 Posted October 18, 2018 No matter the issues, those are all fixable, looks like a nice survivor, orginal and inside kept. Just something about that hood ornament. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,928 #9 Posted October 18, 2018 Good news and bad news. I loosen the belt to the S/G to see which was locked up, the S/G or the engine. It was the engine....I pulled the plug and it isn't looking too good. I see rust on top of the piston and the plug was weird looking. All I had was a bit of motor oil, so I put a little straight through the plug hole and the engine turned just a tiny bit. I will get something a bit stronger, maybe transmission fluid, and pour a bit of that in and let it sit for a spell. Good news, the S/G isn't seized up. So, there's that. 2 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,928 #10 Posted October 18, 2018 Some pictures from before I got it off the trailer. It still has the original dealers tag on it. I haven't check the serial number yet to see what year it is. 2 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,486 #11 Posted October 18, 2018 Nice find for sure! I never had the chance to work on the cubs as much, I was always told the rear end on them is super strong and coveted by pulling tractor enthusiast? Still a wonderful find. Share this post Link to post Share on other sites
ebinmaine 80,481 #12 Posted October 18, 2018 24 minutes ago, T-Mo said: Good news and bad news. I loosen the belt to the S/G to see which was locked up, the S/G or the engine. It was the engine....I pulled the plug and it isn't looking too good. I see rust on top of the piston and the plug was weird looking. All I had was a bit of motor oil, so I put a little straight through the plug hole and the engine turned just a tiny bit. I will get something a bit stronger, maybe transmission fluid, and pour a bit of that in and let it sit for a spell. Good news, the S/G isn't seized up. So, there's that. look up online and see what the ultimate rust breaker is. I think it was something strange like transmission fluid and acetone or power steering fluid and acetone. Something like that. pull the oil drain plug out and leave the pan under it and dump some of your rust breaker in the cylinder whatever it is. if you leave the plug out and the pan under it, cleaned, you can see how much is moving through the engine. if it's moving at all right now, fair chance you'll get that thing running without too much work. 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,677 #13 Posted October 18, 2018 I've dumped marvel mystery oil in the head and let them sit before and it seems to break them loose. A cub 100 is a tractor I would like to own someday. I still use a cub 102 to mow grass with that belonged to my wife's grandfather and it still runs and works like a champ. Also have the cub original that my great grandfather bought brand new. I can't say much bad about the old cubs other than when they break they are a pain in the butt to work on compared to a horse. Keep us updated on your progress! 1 Share this post Link to post Share on other sites
Razorback 1,370 #14 Posted October 18, 2018 I sure hope you get it running. I really like my 1966 model 123 (the first hydrostatic they made). Mine has a mower deck and a tiller.... I bought it to use the tiller, deck works but is stored in the shed). And, yes, the rear end IS beefy! 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #15 Posted October 18, 2018 Those Cub Cadet rears are actually Farmall Cub center sections with different axles/housings, that's why they are rather beefy/tough, but look at those old Panzer's with their Chrysler rears, all the different brands have their strong and weak points if one manufacturer had been great in all areas there wouldn't have all the cool old lawn and garden tractors we thirst after.... @T-Molooks like a really good specimen you have there, the Original was actually belt driven to clutch but the 70/100 was the first direct flywheel to clutch shaft driven. 1 Share this post Link to post Share on other sites
dcrage 636 #16 Posted October 18, 2018 Terry That dealer tag is for a closed hardware store in south St Louis county. I contemplated buying a used Cub from them back in 1990 when I purchased my 310-8. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,928 #17 Posted October 18, 2018 46 minutes ago, dcrage said: Terry That dealer tag is for a closed hardware store in south St Louis county. I contemplated buying a used Cub from them back in 1990 when I purchased my 310-8. I figured as much - I googled them and they come up on one link with an address and a phone number. The address is 11500 something like that Concord Village Road, which appears now as a Pawn Shop. The phone number takes me to a eye clinic. It's too bad small shops like that aren't in business anymore, which is par for the Wheel Horse dealers for the most part. I know IH used various type stores like hardware stores to sell their tractors and equipment, so it didn't surprised me that this Cub Cadet was bought new at a hardware store. Share this post Link to post Share on other sites
TIGman 2,006 #18 Posted October 18, 2018 Great find T-Mo ! Will make you a nice one. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,928 #19 Posted October 19, 2018 Update: I pulled the drain plug and there were no metal shavings or parts in the oil - but a slight trace of possible water. The engine seems to be loosening up some, I was able to turn it more and I can see the piston moving now. I pour a mixture of transmission fluid and acetone in to loosen it up some more. On a side note, I couldn't live with the rear tires on backwards anymore, just in case someone excuse me of doing it. So I switch the tires around so they're now pointing in the right direction. 4 1 Share this post Link to post Share on other sites
Mows4three 833 #20 Posted October 19, 2018 Keep the photos coming, please. Sounds like a great project tractor. I just saw an International 123 in good condition that made my heart race. The thought BRIEFLY went through my head that I should ask about it's availability. That was followed by the even stronger thought of trying to justify it to my wife..... You get the picture. Glad you switched the tires around. That would have bugged me, too. Cheers! Dave Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,928 #21 Posted October 19, 2018 Dave, I had a 123 - it was the first hydrostatic drive tractor IH built for the Cub Cadet line. I know a lot of people refer the wide frame CCs over the narrow frames, but I like the narrow frames the best. Yes, there is less room to work on them, but they're also cooler to look at. Here is my 123 that I had (I should have kept it and at least one of my 104s I had). 1 Share this post Link to post Share on other sites
ebinmaine 80,481 #22 Posted October 19, 2018 1 hour ago, T-Mo said: switch the tires around so they're now pointing in the right direction Oh Thank you Share this post Link to post Share on other sites
Mows4three 833 #23 Posted October 20, 2018 T-Mo: That's a nice 123. I didn't know there was a difference in the frame widths on the IH line of garden tractors. See that? Learn something new on this forum every day! Dave Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,928 #24 Posted October 20, 2018 8 hours ago, Mows4three said: T-Mo: That's a nice 123. I didn't know there was a difference in the frame widths on the IH line of garden tractors. See that? Learn something new on this forum every day! Dave The first few series were the narrow frames. First was the "Cub Cadet" now known as the Original, which debuted in 1961. It was replaced in a couple of years by the 70 and 100. Then came the 71, 102, 122, and 123. Next was the 72, 104, 105, 124 and 125. Next was the 73, 106, 107, 126, 127 and 147 (the first 14 hp Cub Cadet). These were all narrow frames. Due to the tightness of the narrow frame and anything bigger than a 12 hp engine, for the next series IH made the front of the frame wider to accommodate the bigger engines. This is refer to as the wide frame. First of the wide frames was the 86, 108, 109, 128, 129, 149 and 169 (the first 16 hp engine in a CC). From then on, all the GTs from IH was wide frames. Other than the 70 series, i.e 70, 71, 72, and 73 which were all gear drive tractors, IH used even numbers for gear drives, i.e. 102, 122, 104, 124, etc., and odd numbers for hydrostatic drive tractors, i.e. 123, 125, 127, etc. Also note each new series jumped up in increments of twos (again except for the 70 series and the 86). For instance, 100, 102, 104, 106, 108, for the gear drives, and 123, 125, 127, etc. for the hydrostatic drives. After the first wide frames were introduced, which had a solid mounted engine, IH came out with the Quiet Line series which had iso mounted engines and engine side panels. Also, the numbering system now changed to 800 for the 8 hp model, 1000 and 1200 for the gear drive, and 1250, 1450 and 1650 for the hydrostatic drive tractors. The last of the IH built CCs were the 82 series, 482, 582, 682, 782, and 982. These were now red to match the IH farm tractors. This page might help: http://www.ihcubcadet.com/ Share this post Link to post Share on other sites
Mows4three 833 #25 Posted October 20, 2018 Thanks for all that info T-Mo. Good reading, for sure. I'm including a couple pics from the Craig's List post for the HI Cub 123 I mentioned. The guy wants $575 (might take less) and the machine looks very clean for what he claims is a 1965 tractor. Must have truly been shed/barn/garage kept. Cheers! Dave Share this post Link to post Share on other sites
