AMC RULES 37,220 #26 Posted October 21, 2018 Wonder, could a loose valve seat lock it up like that? Share this post Link to post Share on other sites
WildmanC120 613 #27 Posted October 21, 2018 46 minutes ago, c-series don said: I would say if you pulled the plugs already fill the cylinders with Marvel Mystery oil and let it sit for a day or two. Then try to bump it over with a wrench. I can't be bothered with it. I need something I can depend on for this winter. I'm either gonna repower it or dump it. Share this post Link to post Share on other sites
WildmanC120 613 #28 Posted October 21, 2018 46 minutes ago, c-series don said: I would say if you pulled the plugs already fill the cylinders with Marvel Mystery oil and let it sit for a day or two. Then try to bump it over with a wrench. I can't be bothered with it. I need something I can depend on for this winter. I'm either gonna repower it or dump it. Share this post Link to post Share on other sites
ericj 1,579 #29 Posted October 21, 2018 sometimes when you crank a motor over with a low battery the starter will stick engaged. Try turning the motor over backwards and see it it frees up. What you describes sounds like a weak battery instead of a motor trowing a rod and locking up. good luck eric j Share this post Link to post Share on other sites
WildmanC120 613 #30 Posted October 21, 2018 23 minutes ago, ericj said: sometimes when you crank a motor over with a low battery the starter will stick engaged. Try turning the motor over backwards and see it it frees up. What you describes sounds like a weak battery instead of a motor trowing a rod and locking up. good luck eric j Not to be rude, but I have stated in several posts that it will not turn over by hand forward or backward. Share this post Link to post Share on other sites
Tuneup 1,452 #31 Posted October 21, 2018 So sorry to hear this! I'd want to keep it with that rare config but as you said your purpose is for a reliable machine for the soon-to-be-here winter. I'd say find a K Kohler but there's no guarantee you'll have a good engine then either. A Predator or similar would have to be engineered into that space, as you know. It's not a bolt-down. I have a 13 HP Vanguard sitting on a bench with nothing to do I could send to you but...same thing - engineering. You don't have to have 22HP - could get a smaller Harbor Freight engine. You might have to sleeve the crank for the PTO and the crank is unlikely to be bearing reinforced but would serve for the season. Pickle... https://www.harborfreight.com/engines-generators/gas-engines/13-hp-420cc-ohv-horizontal-shaft-gas-engine-epa-60340.html Share this post Link to post Share on other sites
WildmanC120 613 #32 Posted October 21, 2018 6 hours ago, Tuneup said: So sorry to hear this! I'd want to keep it with that rare config but as you said your purpose is for a reliable machine for the soon-to-be-here winter. I'd say find a K Kohler but there's no guarantee you'll have a good engine then either. A Predator or similar would have to be engineered into that space, as you know. It's not a bolt-down. I have a 13 HP Vanguard sitting on a bench with nothing to do I could send to you but...same thing - engineering. You don't have to have 22HP - could get a smaller Harbor Freight engine. You might have to sleeve the crank for the PTO and the crank is unlikely to be bearing reinforced but would serve for the season. Pickle... https://www.harborfreight.com/engines-generators/gas-engines/13-hp-420cc-ohv-horizontal-shaft-gas-engine-epa-60340.html Putting a smaller engine on this than 18-20 HP seems like a waste. I already have a C-120 with a 12hp on it. The whole purpose was to get a twin cylinder of at least 16hp and hydro lift to run my snow blower comfortably. My biggest issue right now is that I do not have a garage. I only have a 8x10 shed, so it's very difficult to work on things. There is not really a lot of room to work inside. I have been working outside but the temps have now dropped into the 40's. Share this post Link to post Share on other sites
Ed Kennell 42,430 #33 Posted October 21, 2018 (edited) I believe there have been a couple threads on here detailing the 22HP predator installation. As I recall, it was not that complicated. Oops, I just saw your post looking for the installation post. Edited October 21, 2018 by Ed Kennell 1 Share this post Link to post Share on other sites
WildmanC120 613 #34 Posted October 21, 2018 2 hours ago, Ed Kennell said: I believe there have been a couple threads on here detailing the 22HP predator installation. As I recall, it was not that complicated. Oops, I just saw your post looking for the installation post. Thanks. I have not had much luck yet finding a good swap thread for the predators yet. Pretty sure I can make some mounts easy enough with some aluminum bar stock and not have to modify the tractor. Share this post Link to post Share on other sites
Tuneup 1,452 #35 Posted October 23, 2018 Hopefully, you'll take the time to let us follow the saga of the retrofit but understood if not as it's getting colder faster. You're welcome to move south! I can't tell you how much less wood I chop and snow I shovel after we moved from northern NJ to Atlanta... Get 'er done and good luck! 1 Share this post Link to post Share on other sites
WildmanC120 613 #36 Posted October 23, 2018 22 minutes ago, Tuneup said: Hopefully, you'll take the time to let us follow the saga of the retrofit but understood if not as it's getting colder faster. You're welcome to move south! I can't tell you how much less wood I chop and snow I shovel after we moved from northern NJ to Atlanta... Get 'er done and good luck! I will be sure to post pics etc if I end up going the engine swap route. It has gotten cold quick here in upstate NY though. Not good working outside weather. Share this post Link to post Share on other sites
WildmanC120 613 #37 Posted October 24, 2018 And so it begins.... 2 Share this post Link to post Share on other sites
Ed Kennell 42,430 #38 Posted October 24, 2018 Don't forget...... Share this post Link to post Share on other sites
WildmanC120 613 #42 Posted October 24, 2018 Well there is my progress so far. I was hoping to mount it to the same plate the briggs was on but that will not work as then the engine is too tall and the hood will not fully close. Also the stock exhaust will need to be modified. The muffler outlet points toward the operator so that's not very good. Also the pipes will need to be either extended a little or rolled down as the hood hits the muffler. 1 Share this post Link to post Share on other sites
Pullstart 67,299 #43 Posted October 26, 2018 On 10/24/2018 at 6:11 PM, WildmanC120 said: Well there is my progress so far. I was hoping to mount it to the same plate the briggs was on but that will not work as then the engine is too tall and the hood will not fully close. Also the stock exhaust will need to be modified. The muffler outlet points toward the operator so that's not very good. Also the pipes will need to be either extended a little or rolled down as the hood hits the muffler. Good to see you are working through instead of dumping the tractor! I have that engine on my wood splitter, it’s a beast but do yourself a favor and install a fuel shut off if you haven’t already. My crankcase fills with fuel after sitting a while and the fuel tank is level with the engine. also, if you have a welder, a cheap but effective way to accomplish re-routing the exhaust is look for a cheap set of v8 headers on Craigslist or eBay... and they have a ton of special bends you can cut apart and use to put the spent gas about anywhere you’d like. 1 Share this post Link to post Share on other sites
Tuneup 1,452 #44 Posted October 26, 2018 You might be able to mount a couple of pepper pot mufflers in a pinch since time is critical. That'll serve for the season. You're making progress! I do wish I was closer - would take that Briggs off your hands. Share this post Link to post Share on other sites
