The Tuul Crib 7,339 #1 Posted October 10, 2018 Anyone have a source of where to find tail lights to replace on these fenders ? Tractor supply, AutoZone any place or parts supplier ? Share this post Link to post Share on other sites
ebinmaine 71,914 #2 Posted October 10, 2018 I don't have the answer to this question but I would like to know what it is so I'm going to follow along..... Share this post Link to post Share on other sites
The Tuul Crib 7,339 #3 Posted October 10, 2018 25 minutes ago, ebinmaine said: I don't have the answer to this question but I would like to know what it is so I'm going to follow along..... Thanx Eric!👍 Share this post Link to post Share on other sites
JAinVA 4,636 #4 Posted October 10, 2018 Most any auto parts store will have them.They are used mainly as marker lights on utility trailers. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #5 Posted October 10, 2018 53 minutes ago, The Tool Crib said: Anyone have a source of where to find tail lights to replace on these fenders ? Tractor supply, AutoZone any place or parts supplier ? Yes those and Walmart too.https://www.autozone.com/exterior-lighting/clearance-light/blazer-clearance-light/378117_0_0....or...https://www.walmart.com/ip/Optronics-MC-32RBP-Red-Rectangular-Reflector-Clearance-Marker-Light/146817686...or LEDs https://www.superbrightleds.com/moreinfo/oval-marker-lamps/oval-led-truck-and-trailer-lights-4-led-side-clearance-lights-w-4-high-flux-leds-pigtail-connector/580/ 2 1 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #6 Posted October 10, 2018 9 minutes ago, WVHillbilly520H said: Yes those and Walmart too.https://www.autozone.com/exterior-lighting/clearance-light/blazer-clearance-light/378117_0_0....or...https://www.walmart.com/ip/Optronics-MC-32RBP-Red-Rectangular-Reflector-Clearance-Marker-Light/146817686...or LEDs https://www.superbrightleds.com/moreinfo/oval-marker-lamps/oval-led-truck-and-trailer-lights-4-led-side-clearance-lights-w-4-high-flux-leds-pigtail-connector/580/ Thanks for the info brother I think this might help me out!!👍 1 1 Share this post Link to post Share on other sites
ebinmaine 71,914 #7 Posted October 10, 2018 12 minutes ago, The Tool Crib said: Thanks for the info brother I think this might help me out!!👍 @WVHillbilly520H Big fan of the LEDs... 1 Share this post Link to post Share on other sites
953 nut 59,322 #8 Posted October 10, 2018 (edited) These Tractor Supply lights look like the factory lights and are priced right. https://www.tractorsupply.com/tsc/product/blazer-b444r-4-in-dual-bulb-clearance-side-marker-red?cm_vc=-10005 Edited October 10, 2018 by 953 nut 1 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #9 Posted October 10, 2018 (edited) 5 minutes ago, ebinmaine said: @WVHillbilly520H Big fan of the LEDs... Yep the best lighting ever was or the LED lights. These as well as lighting throughout my house! Edited October 10, 2018 by The Tool Crib 1 Share this post Link to post Share on other sites
ebinmaine 71,914 #10 Posted October 10, 2018 20 minutes ago, The Tool Crib said: Yep the best lighting ever was or the LED lights. These as well as lighting throughout my house! Us too. Whenever a bulb goes out in house or shop.. led replaces it. Share this post Link to post Share on other sites
jay bee 912 #11 Posted October 11, 2018 I bought these at Menards. They almost look like original to me. They measure about 4' by 2". https://www.menards.com/main/tools-hardware/automotive/towing-cargo-management/trailer-lighting-wiring/towsmart-reg-red-dual-bulb-rectangular-clearance-light/1411/p-1444447113987-c-1527167451363.htm?tid=5612619303434024714&ipos=42 Share this post Link to post Share on other sites
AndyK149 62 #12 Posted October 11, 2018 I posted a write up on LEDs in this thread: Any of the 4x2 surface mount trailer lights work well. Several are linked above. You will be happy! Share this post Link to post Share on other sites
71_Bronco 1,072 #13 Posted October 15, 2018 Has anybody added more than the stock number to theirs? I have a single light in the middle of my fender pan (Bronco 14), and was thinking about adding 2 more, one on each side like the newer ones have, giving me 3 total. Not sure how i'd wire it though Share this post Link to post Share on other sites
ebinmaine 71,914 #14 Posted October 15, 2018 25 minutes ago, 71_Bronco said: Has anybody added more than the stock number to theirs? I have a single light in the middle of my fender pan (Bronco 14), and was thinking about adding 2 more, one on each side like the newer ones have, giving me 3 total. Not sure how i'd wire it though Nick I haven't done it on a tractor but I've done it a few times on pickup trucks and semi trucks. As long as you're using an LED light that is self grounding or you have a good ground circuit tying all the lights together, you could run quite a good many lights on one tractor and the amperage draw is very minimal. Running the circuitry for a lighting system is pretty close to being as easy as you can get. All you have to do is join in The hot wire to the other hot wires and if you have a ground, do the same thing. Otherwise the chassis is its own ground. Share this post Link to post Share on other sites
JimmyJam 542 #15 Posted October 16, 2018 On 10/10/2018 at 7:32 PM, 953 nut said: These Tractor Supply lights look like the factory lights and are priced right. https://www.tractorsupply.com/tsc/product/blazer-b444r-4-in-dual-bulb-clearance-side-marker-red?cm_vc=-10005 I got the same one at Tractor Suppy. Share this post Link to post Share on other sites
peter lena 9,190 #16 Posted October 16, 2018 picked up a pair of led lights at wal mart , 12 $ , great in the winter ,plowing or blowing snow , pete Share this post Link to post Share on other sites
