Paulragan 15 #1 Posted October 8, 2018 Hi there , I'm looking for a good carb for my k8, pls let me now if I need to post elsewhere on the site, thanks Paul Share this post Link to post Share on other sites
ebinmaine 79,136 #2 Posted October 9, 2018 Why do you need a carburetor? Do you not have one? Is yours worn out? Just plain dirty? There are Chinese import carbs available all over the Internet like on eBay. They run between about 11 and $20. The only thing to really watch for other than the obvious of making sure you get the right body is that the choke is often going the wrong direction. It is possible to swap your own choke into the replacement carburetor. Another alternative would be to contact Lincoln at A to Z tractor and have him send you a good used carb or a rebuild kit. Share this post Link to post Share on other sites
953 nut 66,586 #3 Posted October 9, 2018 This manual should give you more information to go on. Share this post Link to post Share on other sites
WHX?? 56,847 #4 Posted October 9, 2018 What manual Richard? ... not showing up? I assume you are looking for a carb for a 8hp Kohler Paul? If so just go to and look for K181 carb. Just make sure the choke configuration is correct. if in doubt let us know. Share this post Link to post Share on other sites
953 nut 66,586 #5 Posted October 9, 2018 10 hours ago, WHX21 said: What manual Richard? .. This one....... must have not pushed the Paste....... 1 Share this post Link to post Share on other sites
stevasaurus 23,705 #6 Posted October 10, 2018 It should be a Carter "N" carb. They are super easy to clean and rebuild with a kit from E-Bay. :) Share this post Link to post Share on other sites
