The Tuul Crib 7,354 #1 Posted September 30, 2018 For some reason I haven't noticed this before when I picked up this tractor... something was missing. Any ideas? Its a 312-8 Share this post Link to post Share on other sites
Racinbob 13,043 #2 Posted September 30, 2018 You don't have a dial-a-height thingy. Some of the 300's and GT models didn't come with them standard. You can add one. They used to sell a complete kit but now you'll most likely have to find used parts but that should be easy. 🙂 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,739 #3 Posted September 30, 2018 26 minutes ago, Racinbob said: You don't have a dial-a-height thingy. Some of the 300's and GT models didn't come with them standard. You can add one. They used to sell a complete kit but now you'll most likely have to find used parts but that should be easy. 🙂 - Good eye! So if we search for "Thingy" in the WH Manual Section - this thingy should pop right up???!!! 1 3 Share this post Link to post Share on other sites
953 nut 67,442 #4 Posted September 30, 2018 51 minutes ago, SylvanLakeWH said: - Good eye! So if we search for "Thingy" in the WH Manual Section - this thingy should pop right up???!!! First of all I think he is referring to his choke. If "Thingy" fails to come up in your search you can try "Doohickey"! 2 2 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted September 30, 2018 7 minutes ago, 953 nut said: First of all I think he is referring to his choke. If "Thingy" fails to come up in your search you can try "Doohickey"! I also falls into the category of Thingamajigger!!😳 2 Share this post Link to post Share on other sites
KC9KAS 4,746 #6 Posted September 30, 2018 @The Tool Crib Also missing the choke knob/cable.. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #7 Posted September 30, 2018 18 minutes ago, KC9KAS said: @The Tool Crib Also missing the choke knob/cable.. 18 minutes ago, KC9KAS said: @The Tool Crib Also missing the choke knob/cable.. Yes and I've been looking for the right one do you know the part number by chance ? Share this post Link to post Share on other sites
KC9KAS 4,746 #8 Posted September 30, 2018 1 minute ago, The Tool Crib said: Yes and I've been looking for the right one do you know the part number by chance ? Sorry, I do not. I have 2 running 312's and a 312 roller. I will try to check the roller to see if it still has the chole cable. 1 Share this post Link to post Share on other sites
Achto 32,096 #9 Posted September 30, 2018 Give these a look. I've always had good luck the cables from here. You will most likely have to trim it to length. http://www.psep.biz/store/toro_mower_cables.htm 1 Share this post Link to post Share on other sites
Racinbob 13,043 #10 Posted October 1, 2018 Not to be confused with hoobie doobie which you'll find in the transmission section. 1 2 Share this post Link to post Share on other sites
Tankman 3,528 #11 Posted October 2, 2018 My 16 hp Work Horse didn't have the dial-a-height. Found one on eBay, $20. Easy to install. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #12 Posted October 2, 2018 9 hours ago, Tankman said: My 16 hp Work Horse didn't have the dial-a-height. Found one on eBay, $20. Easy to install. I went to eBay and type in dial-a-height and it didn’t come up. Any idea on the keyword. Share this post Link to post Share on other sites
AMC RULES 37,259 #13 Posted October 2, 2018 Try "wheel horse lift" Share this post Link to post Share on other sites
The Tuul Crib 7,354 #14 Posted October 2, 2018 11 minutes ago, AMC RULES said: Try "wheel horse lift" Still not finding it. Is there a part number? Share this post Link to post Share on other sites
AMC RULES 37,259 #15 Posted October 2, 2018 Might try placing a "wanted" classified ad here on RedSquare... to find someone parting out a tractor for your specific model, or application. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #16 Posted October 2, 2018 3 minutes ago, AMC RULES said: Might try placing a "wanted" classified ad here on RedSquare... to find someone parting out a tractor for your specific model, or application. Will do thanx! Have a great day !😎 1 Share this post Link to post Share on other sites
clueless 3,427 #17 Posted October 2, 2018 1 hour ago, The Tool Crib said: Will do thanx! Have a great day !😎 A-Z Tractors (vendor section) has every thing you need, put one on my 312 last year. You will need the dash and shiftier plates also or you can notch the ones you have. Go to the manual section and pull up the parts list for a later model 312, or any 400 series it will show you everything you need. Share this post Link to post Share on other sites
Tankman 3,528 #18 Posted October 2, 2018 (edited) You can also try. "Wheel Horse" search on eBay. Lots of stuff to page thru but, that's how I found the Dial-A-Height for my Work Horse. Available at partstree.com but priced out of this world. https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/41-20o801-520-8-toro-520-8-garden-tractor-1990/manual-lift-linkage-520-8/ Edited October 2, 2018 by Tankman Share this post Link to post Share on other sites
