Guest 88vic #1 Posted September 27, 2018 I have a 1968 Raider 12, I need a picture of the throttle cable down by the engine of how its hooked up. I think im missing a bracket. Thanks in advance ! Share this post Link to post Share on other sites
WHX?? 58,236 #2 Posted September 27, 2018 Should be real close to this 4 Share this post Link to post Share on other sites
pfrederi 21,184 #3 Posted September 27, 2018 mine aren't as clean 2 Share this post Link to post Share on other sites
WHX?? 58,236 #4 Posted September 27, 2018 One thing the pic doesn't show is the clamp that holds the throttle cable is a clamp behind the air cleaner on the breather retaining stud. Lemme know you need a pic I'll sent the missus out to the shed It's raining out 3 Share this post Link to post Share on other sites
WHX?? 58,236 #5 Posted September 27, 2018 A dirty tractor is the devil's workshop Paul 2 Share this post Link to post Share on other sites
Guest 88vic #6 Posted September 27, 2018 Thank you so much ! Thats all I needed. I need that clamp behind the air cleaner and she'll be ready to fire up after 15 years sitting in a mower graveyard. I saved it from going to the shredder. Its exciting ! Share this post Link to post Share on other sites
953 nut 69,563 #7 Posted September 27, 2018 10 minutes ago, pfrederi said: mine aren't as clean Mine either! Well, actually that is Paul's too, that is the Charger he bought from me. 1 Share this post Link to post Share on other sites
WHX?? 58,236 #8 Posted September 27, 2018 Thanks for saving her Fan... it's kind of a weird setup back ther. A longer nut, almost looks like a all thread coupler for spacing then the clamp and a nut with a split ring lock washer thrown in for good measure. 2 Share this post Link to post Share on other sites
Guest 88vic #9 Posted September 27, 2018 Im up to 10 horses in the stable, 5 of them running. Im working on the other 5 throughout the winter. Wanting to attend some shows for 2019. Share this post Link to post Share on other sites
WHX?? 58,236 #10 Posted September 28, 2018 11 minutes ago, WHEELHORSEFAN3 said: Im up to 10 horses in the stable, 5 of them running. Im working on the other 5 throughout the winter. Wanting to attend some shows for 2019. Excellent Fan, you're in the right area for shows and ! Share this post Link to post Share on other sites
953 nut 69,563 #11 Posted September 28, 2018 You need to put the "Big Show" on your calendar, June 20 - 22 near Chambersburg, PA. Check their website later in the year for a flyer. https://wheelhorseclub.com/ 1 Share this post Link to post Share on other sites
Guest 88vic #12 Posted September 28, 2018 I just told the wifey she needs to take vacation days those days. We are going ! Share this post Link to post Share on other sites
953 nut 69,563 #13 Posted September 28, 2018 2 minutes ago, WHEELHORSEFAN3 said: We are going ! There will be a lot of RedSquare members there. Plenty of posts will come up as we get closer to the date. Share this post Link to post Share on other sites
WHX?? 58,236 #14 Posted September 28, 2018 10 minutes ago, WHEELHORSEFAN3 said: We are going ! A event not to missed and no excuse if you live anywhere in PA! 1 Share this post Link to post Share on other sites
Guest 88vic #15 Posted September 28, 2018 One of my projects this winter will be making a generator that I can put on the front and run off the pto. I want it to be able to switch easily between my horses. That is a project im really looking forward to. Share this post Link to post Share on other sites
peter lena 10,077 #16 Posted September 28, 2018 do you have a local hardware store ? chances are they have a small parts, slide box area , with just what you are looking for, by the way, the best way to secure a slide cable is at, few points ,as well as the very end, for mechanical advantage. this would also be a good time to lubricate its function. I noted many bolt on opportunities in the pictures for a secure mounting of this cable, that WERE NOT used. CABLE CLAMPS ,Pete 1 Share this post Link to post Share on other sites
pfrederi 21,184 #17 Posted September 28, 2018 Hard to get a good picture of the stand off This is what you need to get 2 Share this post Link to post Share on other sites
