Busman 14 #1 Posted September 22, 2018 I have a tiller on my c125 and I can't seem to get it set up correctly. The idler pulley on the front is rubbing on the brake pedal. How can I fix this? Share this post Link to post Share on other sites
Racinbob 10,294 #2 Posted September 22, 2018 It looks like the wrong size idler pulley. That looks like a 4" and I'm thinking that one should be smaller. Somebody will chime in with the actual size. 1 Share this post Link to post Share on other sites
daveoman1966 3,612 #3 Posted September 22, 2018 Wrong pulley(s)...wrong belt? The belt # 110265 is 141" x 1/2. Here are two pulley setup options: 1 Share this post Link to post Share on other sites
clueless 2,898 #4 Posted September 22, 2018 21 minutes ago, Racinbob said: It looks like the wrong size idler pulley. That looks like a 4" and I'm thinking that one should be smaller. Somebody will chime in with the actual size. Also your missing the tension spring that hooks to it. 2 Share this post Link to post Share on other sites
Blackhood Bill 720 #5 Posted September 22, 2018 I just bought a tiller for my c-145 and I seen your post and just went out to measure my pulley. Here is a picture of mine with a tape measure.hope this helps. This is for 36" tiller. 2 Share this post Link to post Share on other sites
Busman 14 #6 Posted September 23, 2018 Thanks I was hoping it'd be that easy. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,503 #7 Posted September 23, 2018 Have listed some of the idlers that Wheel Horse used along with suitable replacements. Click on the fuzzy picture. Garry 1 Share this post Link to post Share on other sites
sparkys toy 76 #8 Posted September 27, 2018 Couldn't tell from your pix but it didn't look like the tension spring is installed,which would pull the idler would rotate down away from the pettal bar just got a new oem idler pulley from toro and it fits great Share this post Link to post Share on other sites
Busman 14 #9 Posted September 27, 2018 I bought a 2.5 inch pulley and it fit much better. Now I’ll need the spring to apply tension. I’ll get one this weekend. Share this post Link to post Share on other sites
