gwest_ca-(File Mod) 12,166 #26 Posted September 2, 2018 1 hour ago, Detour said: Also when I turn key to start the volt meter goes all the to neg is that normal Yes. The gauges are powered in the RUN position but you go past that to get to START where they are not powered so they take a jump. Garry 1 Share this post Link to post Share on other sites
Detour 3 #27 Posted September 2, 2018 I’m at a stand still. About the only ting I haven’t tried was the oil switch and parking brake switch could it be them ??? Wainting on a phone call from someone he nose Share this post Link to post Share on other sites
N3PUY 1,031 #28 Posted September 2, 2018 55 minutes ago, Detour said: I’m at a stand still. About the only ting I haven’t tried was the oil switch and parking brake switch could it be them ??? Wainting on a phone call from someone he nose Look at the "starter motor circuit" diagram...….. the oil switch and the brake switch are NOT part of the "start" circuit. Share this post Link to post Share on other sites
N3PUY 1,031 #29 Posted September 2, 2018 With a test light start at the battery and probe each connection along the wiring diagram..... you must have the key in the "start" position. Share this post Link to post Share on other sites
Detour 3 #30 Posted September 2, 2018 Not no this mower and listening to owner I think the hole problem was the PTO in gaged. No marking tell on or off when I tried this before must had another safety schwitch disengaged. Can some one tell me where the black long rubber hose from the air filter housing goes. Or doesn’t it just hang down as a hose clip Winthrop a very little small hole fitting Share this post Link to post Share on other sites
Detour 3 #31 Posted September 2, 2018 Sorry for the spelling. Working and texting. Just need help with the breather hose now I don’t think it was hooked to anything Share this post Link to post Share on other sites
Kurt-NEPA 756 #32 Posted September 2, 2018 19 minutes ago, Detour said: Can some one tell me where the black long rubber hose from the air filter housing goes. Or doesn’t it just hang down as a hose clip Winthrop a very little small hole fitting Sounds like the hose that triggers the idiot light for a dirty filter. It goes to a switch between the dash and the engine on the passenger side of tractor. What usually happens is that the nipple on the switch breaks and the hose hangs down. Won't hurt anything. 1 Share this post Link to post Share on other sites
Detour 3 #33 Posted September 2, 2018 I think I see that small square box that the hose once went to that has two plung in wires that go to it. If it was off it is now. If the problem wasn’t the PTO in gaged then it was a wire connection. Thanks to everyone. 1 Share this post Link to post Share on other sites
