IthacaJeff
Loose wheel bearings
IthacaJeff
Hi folks:
The wheel bearings in one of the front wheels of my 416-8 imploded the other day while mowing. 32 years old, I'm not complaining. Anyway, with the advice of another thread I picked up a set of 4 flanged bearings off an ebay seller. . .3/4" ID, 1 3/8" OD. Problem is they are a loose fit in the wheel hub. I should need to tap them in, but they just slide in and out. No real play, but they can just fall out. The insides of the hubs are clearly worn.  Any advice on snugging up the bearings"
Thanks,
J
953 nut
I would just take a punch and make a few dimples in each side of the hub. The bearings should need a bit of persuasion then.
  • Like 5
N3PUY
Coat the wheel where the bearing goes in with a thin layer of JB Weld and insert the bearing.   It'll be good for another 32 years!
JAinVA
I have a piece of pipe in the shop that I drive down on the sleeve and it shrinks the opening to make the bearing a tight fit.The JB weld solution is probably the most cost effective solution.
RandyLittrell
The right size impact socket would probably work as well. Drive it over, just like the pipe.
Randy
IthacaJeff
I like those ideas. I'll start with the pipe over the sleeve if I can find a pipe the right size. . . .thanks, gents.
Charles123
Ping  Then over and put loctite green sleeve  Locker
tunahead72
So @IthacaJeff, how did the pipe work? I have the same problem with my C-105.
gwest_ca
I had a pair of wheels where the tube split on the inside at the seam in the tube.
Drove a 1-1/2" shaft collar over the tube and then installed new bearings. Worked perfect.
Garry
IthacaJeff
In the end I used Loctite green sleeve bearing retainer. Seems to be working!
  • Similar Content
    • Kenneth R Cluley
      By Kenneth R Cluley
      I have decided to upgrade the wheel bearings on front wheels of Rear engine rider. The original flange "bearings" are Taiwan lets call flow through not sealed . The hub of wheel has a grease zerk and entire hub fills with grease until it flows through bearings and out side. I have purchased a sealed flange bearing and cannot decide if I should pull the shields and just pump it up till it flows through or flush out and pack with Pete approved Lucas high pressure and replace seals and not use zerk anymore. What do you geniuses recommend? I realize I would have to regrease on some maintenance interval either way.
    • Jeff_B
      By Jeff_B
      Where's your go-to source for QUALITY 103119 bearing shaft assemblies? Also, I don't have my deck apart yet, but seem to remember they're tough to remove from the housings. Any tips or tricks? Finally, just recently I've had a couple of  the center bearings go loose on two different decks. Once is one thing, but twice? More than a coincidence? Should I be releasing tension on the belt by loosening the mule drive when not in use? We've had WH tractors for over 40+ years and I've never done that before! THANKS in advance!
    • RichInWalworth
      By RichInWalworth
      Question. I have a 1990 single stage snow thrower for my 312-8. I am trying to replace the bearings on the drive shaft. How do you remove them? I have taken out the set screw, soaked the collar in pb blaster, put some heat to them, pounded on them. etc. They will not move. Am I missing something? The only thing that is curious is, there is only one set screw in each bearing collar. There appears to be a second partially drilled hole but no set screw installed and it does not appear to be tapped. What gives???
      Rich In Walworth
    • porschpow
      By porschpow
      Good Morning everybody!
      I am in the process of sharpening the blades for my mowing deck (Model 78360 - Serial 7904987) and I noticed that the deck has a crack in it right where the bracket to the mounting hardware (to the tractor) is. SO I know I have to get that repaired.
      But while I was at this, I thought I could do a good quick once over on the deck to make sure I am ready for the season.
      What I would like to do is the following:
      Change the bearings for the spindles (or pack them with more grease)
      Get new rear tires (since they squeak)
      And that's about it
      If anyone here thinks I should do anything else, I would love to hear it!
      Where does everyone get the hardware (bearings, wheels for these rebuilds?)
    • mkueb
      By mkueb
      Does anybody have a good source for replacement front wheel bearings for a mid to late 1970's D160 wheel horse tractor?  There are two push in bearing units (inner and outer) per wheel.   I first attempted to replace with standard bearings but quickly found out these are not standard sizes.   It's been a while since I check and I don't completely remember,  but I think the wheelhorse bearings where something like 1/16" of an inch larger OD than a standard catalog bearing.   At the time,  I remember finding bearings but they wanted somthing like $100 for each bearing.   I was able to located two bearings and did purchase them for a reasonible price,  but am still looking for two for completing the set.   The part numbe ron the two that I was able to locate is 104396.   If anybody has any ideas,  I would appreciate.
      Thanks
      Marc
