Pullstart 70,105 #26 Posted August 28, 2018 What a score, @Shed! Welcome to the forum, not sorry to say, you’ll likely get stuck here! Share this post Link to post Share on other sites
Shed 377 #27 Posted August 30, 2018 Does anyone have a picture of a factory k90 throttle setup mine isn't right at the carb Share this post Link to post Share on other sites
peter lena 9,901 #28 Posted August 30, 2018 nice pick up, but as a grandpa, that little boy did it for me, Pete 1 1 Share this post Link to post Share on other sites
Shed 377 #29 Posted August 30, 2018 Gattett is his name we couldn't javf asked for a better kid to have hes sp easy going, he is the reason I was able to bring both home my wife and grandma(my mom) helped to. 1 Share this post Link to post Share on other sites
Shed 377 #30 Posted August 30, 2018 What's missing with this carb linkage it doesn't seem right 1 Share this post Link to post Share on other sites
peter lena 9,901 #31 Posted September 2, 2018 looks like the pivot linkage back to carb is missing , you might find a picture to help out out there, models and years are different. also that cable pull should be secured as close to the end as possible for mechanical advantage, along with a through lubrication of that cable for easy use. pete Share this post Link to post Share on other sites
Shed 377 #33 Posted September 2, 2018 Ok so I removed that random bracket off and came up with this I have a tab sticking off and asand asI turned it the Gov spring got tighter so I found a spot where things were neutral and made a cable clamp and that's what I ended up with I did lubricated the cable and housing. My glass fuel bowl was gummed up so I took it apart I need to make a new cork gasket unless they sell them and re do the fuel line also I seen there is no oil or mesh in the air filter so I read a few things in here and seen guys put stainless mesh and non detergent oil in the filters. Share this post Link to post Share on other sites
953 nut 66,628 #34 Posted September 3, 2018 I think you may want to get a longer cable so it will come up straight from the bottom like Craig's. Looks like that may bind on you. 1 Share this post Link to post Share on other sites
Shed 377 #35 Posted September 9, 2018 I'm looking to wire up the hood mounted kill switch where does the wire go to I see your points cap is like mine with a botton was that were the kill switch was on these Share this post Link to post Share on other sites
AMC RULES 37,259 #37 Posted September 9, 2018 Pretty sure the switch grounds out the points. Will get you a pict later on today. Share this post Link to post Share on other sites
Shed 377 #38 Posted September 10, 2018 Well I put some fuel in the fuel line of the rj59 I looked up the casting on the rear and it turned out it's a Feb 5 1959 rj but any way pulled and pull nothing happened so I pulled the motor and the carb and it was just full of crusty hard stuff. Not a varnish but a hard flaky white crust. So should I soak this carb and rebuild or just buy a replacement if soak it what do you recommend carb cleaner did not even take it off. And should I just pull the motor apart and rebuild it or just go with it and check the gaps and run it Share this post Link to post Share on other sites
