Goat 2141
No charge
Goat 2141
Have a 520h it will charge the battery how can fix it.
RandyLittrell
Your gonna have to give us more to go on. I recommend checking all your grounds first. Don't just tighten them, undo them, use a small wire brush to clean them and then put a little dialectric grease on the connection. If still no go after that, I sure somebody smarter than me can help!!
Randy
Pollack Pete
Are you sure the battery is good and fully charged? Gotta start out with a good battery.
FatJackDurham
I had the same issue. I replaced the rectifier and it fixed the problem, but you should also check the fuse between the rectifier and the battery.
Check Fuse: use a voltimeter, test the battery voltage - should be 12+. Then, leaving one lead on the negative terminal, check the voltage on the center spade of the rectifier, with everything still connected. IT should be the same voltage. If not, your fuse or fuse connectors are suspect.
If the fuse checks out, you can try replacing the rectifier. If that doesn't work, dunno.
Edited by FatJackDurham
Goat 2141
Randy
Ty will Checkit out
Goat 2141
Battery is new
Goat 2141
Were is rectifier at . All fuse are good ty for the help
FatJackDurham
Rectifier is on top of the engine, attached to the sheet metal shroud, just in front of the battery. Looks like a flat rectangle with three prongs in a row. The prong on the right will have a double connector, be careful not to break it. The rectifier is held in by a single bolt. Take the bolt out, slide the rectifier towards the bolt hole about an 1/8th of an inch, and it will come right out.
Here is an example on Ebay, with some pictures, but you can get them for cheaper on amazon.
https://www.ebay.com/itm/Voltage-Regulator-Rectifier-For-Onan-Engines-P216-P218-P220-191-1748-191-2277-/331722291941
Be sure to test the middle prong with the wire STILL ATTACHED and the negative battery terminal for voltage. Even though the fuse is good, the fuse holder may have corroded terminals in it. I had to replace one recently on my 416-8 which was preventing it from charging. Also, with the engine running set your voltimeter to Alternating Current and put your probes on the two side terminals, one on each side, at the same time. Your A/C voltage should be around 35 volts plus or minus.
Also, download and consult both the demystify guide.  In the "glossary" section, it describes all the electrical components and how to test them. In the 520H section, it will have an electrical diagram.
  • Similar Content
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
    • RJ Hamner
      By RJ Hamner
      I have a new-to me 1990 520 with a KwikWay loader. Have been going thu piece by piece and checking for anything that needs attention. Found some wobble in the rear hubs (both sides) the key ways on both the axles and hubs shoe some pretty heavy wear.  Was wondering if you have used the hub repair kits that A-Z sells and any comments good or bad?
      Thanks
      Bob
