redbeard22 123 #1 Posted August 18, 2018 Hey everyone, just wanted to post up a couple pics of a project im currently working on. The goal of this project is to make a wheelhorse style tractor similar in size to a d250 but simple design like the smaller models. I am building a custom frame based on a wheelhorse frame but heavier duty,longer and wider. This tractor will have a 12hp briggs from another wheelhorse, a 6speed trans with 1.125 axles, 26x12-12 rear tires, hydraulic lift and possibly a 3pt hitch. Ill post some pics let me know what you guys think. It might take me a minute to figure our the picture thing. 5 1 1 Share this post Link to post Share on other sites
Marv 996 #2 Posted August 19, 2018 looking forward to following this. Will be quite a task i am sure. Marv Share this post Link to post Share on other sites
953 nut 65,233 #3 Posted August 19, 2018 58 minutes ago, redbeard22 said: figure our the picture thing. Upload the pictures to your computer, click on the choose files... at the lower left of a new post and it will take you to your photos on the computer. Share this post Link to post Share on other sites
Sarge 3,470 #4 Posted August 19, 2018 So, you're building a C-195 (Super C) or a heavier version of a D-200? Sarge Share this post Link to post Share on other sites
redbeard22 123 #5 Posted August 19, 2018 im having trouble resizing the pics to be able to fit them on here under the 10kb limit. is there a thread explaining how to do this? Share this post Link to post Share on other sites
Skipper 1,792 #6 Posted August 19, 2018 Ah that is because you are not a supporter i think. I can upload any size pic and video. You can rezise with a large number of tools. Personally I find it easy to send them in an email to myself, and have outlook rezise to "small". Takes seconds. 1 Share this post Link to post Share on other sites
redbeard22 123 #7 Posted August 19, 2018 ok ill give that a try 1 Share this post Link to post Share on other sites
redbeard22 123 #8 Posted August 19, 2018 here is the front of the frame where the front axle attaches. the frame is 3x3 angle iron 3/8 thick the plates for the front axle are 3/8 thick and the axle pin is 1in 1 3 Share this post Link to post Share on other sites
redbeard22 123 #9 Posted August 19, 2018 well it looks like I have reached my limit for uploads with just one pic so give me a little time so I can sign up to be a supporter and hopefully later today I can post more pics 4 1 Share this post Link to post Share on other sites
redbeard22 123 #10 Posted August 19, 2018 ok here we go now we are in business, I threw in a pic of my old clausing lathe from the late 40's early 50's before they were bought out by atlas I believe . its a model 100 mk1 I believe because the mk2 and mk3 had a quick change gear box for threading things mine has interchangeable gears on the end instead. anyway you can see the sleeves I bored out of 1.5 solid bar for the spindle shafts to fit into and I turned some nice brass bushings that were press fit into the sleeves so I don't wear out the sleeves or spindle shaft. I will be adding grease zerks on the sleeves before the project is complete. I will be using a set of spindles off a john deere 112. everything on this new frame has been welded with a Lincoln ac225 buzzbox with 7018ac rods. I am trying to base this frame design off of the tractors that have an angle iron frame this one is just going to be heavier duty. I plan to have hydraulics for a snow plow and 3 point hitch. if anybody has any questions or ideas lets hear it. hopefully later today I will have the plate don't and welded on to bolt the 6 speed trans in and I can have it setting on the tires and see what its gonna look like. 2 8 Share this post Link to post Share on other sites
ebinmaine 78,272 #11 Posted August 19, 2018 Looks fantastic so far. This could be an awesome machine!! I'll be following along. Thanks for becoming a supporter. 2 Share this post Link to post Share on other sites
Machineguy 877 #12 Posted August 19, 2018 I like it!! This is gonna be cool!! Thanks for sharing! 2 Share this post Link to post Share on other sites
953 nut 65,233 #13 Posted August 19, 2018 (edited) for becoming a Supporter. A bit off topic, but I've got to ask, what the heck were you taking apart with a ten foot pipe on the end of a pipe wrench? Edited August 19, 2018 by 953 nut 3 3 Share this post Link to post Share on other sites
redbeard22 123 #14 Posted August 19, 2018 Lol that was used to try to take the nut off of a trailer hitch ball on my truck, it was pretty rusty and on there for a while. 4 Share this post Link to post Share on other sites
redbeard22 123 #15 Posted August 19, 2018 Ok i have an update got the plate for the transmission made and welded in bolted up a trans and slapped some tires on it. 9 1 Share this post Link to post Share on other sites
Skipper 1,792 #16 Posted August 19, 2018 Awesome project! Could you spice it up with some more measurements and references to how you upscale, and why you make the design and material choices you do? That would be insight in why you do as you do, and what you are aiming for. And it would be very interesting reading for those who might have similar idears 1 1 Share this post Link to post Share on other sites
redbeard22 123 #17 Posted August 19, 2018 Now the front is 43 inches to thebbn outside of the tires which is rite where i wanted to be about the same as a d250 i think they are 44 but the back does not have the correct wheels and tires that i will be using i dont have them yet. I plan to use 26x12-12 on the rear probably bar tread as i will be using this tractor in the woods to pull my small dump trailer for firewood. Once i get the correct tires on the rear the frame will sit perfectly level front to back. Next is figuring out what to do about the sheetmetal. I was thinking of widening the original center console and dash to the new width of 13 inches but not sure how comfortable that will be. I will also be stretching and widening a hood and adding running boards 2 1 Share this post Link to post Share on other sites
redbeard22 123 #18 Posted August 19, 2018 The while objective behind this build is to have a tractor the size of a d250 or john deere x700 series. I saw one of the jd x700 at a local fair and liked the size but about had a heart attack when i saw the price. So here i am building one. I got all my dimensions from tractor data and found a d250 to be almost the same size as a x700 so i referenced dimensions from both. The choice of material for the frame was easy. Wheelhorse had a tough simple design that they stuck with for many years because it worked so all i did was figure since its going to be a bigger heavier duty tractor so should the frame so i just used angle iron and plate that i thought would be good enough to handle the job. 5 1 Share this post Link to post Share on other sites
ebinmaine 78,272 #19 Posted August 19, 2018 5 minutes ago, redbeard22 said: Wheelhorse had a tough simple design that they stuck with for many years because it worked I'm thinking you've made a great choice modeling after these. 1 Share this post Link to post Share on other sites
redbeard22 123 #20 Posted August 19, 2018 Im going to consider this tractor a wheelhorse even though some of the parts are off a john deere. Its still going to be red with white wheels when its all done just need to come up a model name 1 Share this post Link to post Share on other sites
ebinmaine 78,272 #21 Posted August 19, 2018 2 minutes ago, redbeard22 said: come up a model name Get her closer to completion and post some pics under a separate heading looking for a name. We'll be glad to throw a few out. Many of us end up naming our own horses anyway. Share this post Link to post Share on other sites
953 nut 65,233 #22 Posted August 19, 2018 9 minutes ago, redbeard22 said: need to come up a model name Considering how strong it will be I would offer the name Hercules. 2 Share this post Link to post Share on other sites
mmmmmdonuts 274 #23 Posted August 20, 2018 Looks great so far. I don't know exactly your plans but I do have a few suggestions. If you have room try and tuck in a hydraulic reservoir. The bigger the better. Use float position on the hydraulic cylinders as well. Extremely handy on a 3pt. You should also size the 3pt to a cat1 rather than cat0. Power steering would also be extremely helpful especially given how big and heavy this will be. Looking great so far. Will love following this thread. Share this post Link to post Share on other sites
redbeard22 123 #24 Posted August 20, 2018 I like the idea of power steering that may be an upgrade in the future for now im just trying to get it running and driving before fall when it is firewood season need it to drive through the woods and tow my small dump trailer and im also on a tight budget. Hydraulics are in the plan but they may not happen rite away. 1 Share this post Link to post Share on other sites
Chris G 3,371 #25 Posted August 20, 2018 Looking good so far! I will be following along on this one as well. 1 Share this post Link to post Share on other sites
