rjbaldwin51 4 #1 Posted August 18, 2018 I have a C-105 that I have had since 1976 and the rear fender is cracked on both sides. I would like to fix that and repaint. Being that it is plastic does anyone have a preferred method of repair? It still runs strong and I use it for mowing and rototilling. Thanks Share this post Link to post Share on other sites
shallowwatersailor 3,213 #2 Posted August 19, 2018 You might consider finding a metal fender from an earlier long wheelbase or later ('85-on) Wheel Horse. They bolt on using the same holes. The C-105 with the plastic fender was from 1980 to mid 1982. It could be repaired, depending how bad, using fiberglass cloth. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,369 #3 Posted August 19, 2018 If you are wanting to keep it factory original with the 'glass fenders try @Adams94 for his new reproduction ones, or if not do what @shallowwatersailor John has suggested above with a set of metal fenders, Jeff. 1 Share this post Link to post Share on other sites
SylvanLakeWH 24,153 #4 Posted August 19, 2018 Love my C 105 as well! Great machines! Previous owner changed out mine to metal. I like the look better and it does not have the UV fade / crack issue. But as noted can fiberglass or replace with after market... Good luck! 1 Share this post Link to post Share on other sites
Adams94 1,065 #5 Posted August 20, 2018 Yes I have what you need if you are interested send me a message. Thanks alot Share this post Link to post Share on other sites
Chris T 349 #6 Posted August 20, 2018 On 8/18/2018 at 6:26 PM, rjbaldwin51 said: I have a C-105 that I have had since 1976 and the rear fender is cracked on both sides. I would like to fix that and repaint. Being that it is plastic does anyone have a preferred method of repair? It still runs strong and I use it for mowing and rototilling. Thanks I have a pristine condition original fender pan removed from a C-85 if you are interested, depending on condition of yours Share this post Link to post Share on other sites
rjbaldwin51 4 #7 Posted August 27, 2018 Thanks to all for the info. Coming up on winter in the NW so think I will repair it with fiberglass and epoxy. Share this post Link to post Share on other sites
