pfrederi 21,231 #1 Posted August 17, 2018 Been working with a older deck 5-1000 i believe (no data plate.). The max height cut I can get is about 2-3/4 inches. Put a couple 1/2" boards under rear wheels to simulate going to larger wheels...raised the back of the deck but not the front. Unlike newer decks there doesn't seem to be a leveling adjustment. Any thoughts on how to get it up to 3 or 3-1/4" cut??? Share this post Link to post Share on other sites
daveoman1966 3,884 #2 Posted August 17, 2018 (edited) I have a pair of deck wheels...they are 2" wide x 8" dia with shoulder bolts and steel bearings. Bolt threads are 1" or so. These would probably solve the cut height issue and give you much more range...$32... SHIPPED to USA zips Edited August 17, 2018 by daveoman1966 Share this post Link to post Share on other sites
peter lena 10,091 #3 Posted August 17, 2018 https://www.tractorsupply.com/tsc/product/martin-wheel-6x1-3-8-plastic-deck-wheel-1-2-in-bushing-1-3-8-in-offset-hub?rfk=1 I have these wheels on 3 decks, and they give me the high cutting height I want, they also stand up very well , and at 14 $ a pair, ordered from tractor supply I think it will help your problem. I do not have any older decks , but the added wheel height gives me a very good cutting height without a burn. I would also check your lift point hook up , maybe you can modify for more height, pete Share this post Link to post Share on other sites
Ed Kennell 47,617 #4 Posted August 17, 2018 1 hour ago, pfrederi said: Unlike newer decks there doesn't seem to be a leveling adjustment. Any thoughts on how to get it up to 3 or 3-1/4" cut??? Paul, do you have the pin that rides on the curved center support channel? The location of that pin should balance the front to rear height. You may have to drill new holes to adjust the pin location to get the front up level. Share this post Link to post Share on other sites
pfrederi 21,231 #5 Posted August 17, 2018 Are you talking about the pin #47? It is currently in the second hole as shown in parts diagram. The long slot below was used on earlier model decks 5-1421 that used a long bent rod to adjust the height. Guess WH used the same bracket assembly #38 on different decks.. Do you think if I moved the pin to the top hole that would help?? Share this post Link to post Share on other sites
Ed Kennell 47,617 #6 Posted August 17, 2018 Yep, #47 pin should control the front height. Try a different hole to see if it makes a difference. You may have to drill new holes or modify the pin support bracket to get the height you want. 1 Share this post Link to post Share on other sites
pfrederi 21,231 #7 Posted August 18, 2018 Dug out a pair of 7 inch wheel for the deck put them on but as i anticipated it just raised the back of the deck so there was way to much difference between blade height at front and back. I know you want a little for best cut but this was almost 1/2". Using Ed's suggestion moved the rod #47 to the top hole in the axle assembly...success!! little over 3" now and just a shade lower in front. Thank you all 2 Share this post Link to post Share on other sites
Ed Kennell 47,617 #8 Posted August 18, 2018 Thanks for the update Paul. Share this post Link to post Share on other sites
Sarge 3,473 #9 Posted August 19, 2018 That's great info to know - there are times it's beneficial not to cut the grass so short, mine is loaded with water grass now from doing just that. My question is this - how well does the deck perform at 3", does it throw more clippings forward towards the engine, or about the same as always? The skirt I added to my 48" made a big difference, but in the top height notch, it still wants to paint that engine intake cooling screen with clippings, which I really hate on a K341 as they run hot enough as it is. Sarge Share this post Link to post Share on other sites
pfrederi 21,231 #10 Posted August 19, 2018 My grass is really too wet to mow right now The little I did didn't throw clippings but I believe that was due to the wetness. At the rate we are going with rain I may not be able to answer Sarge's question until next year.... Share this post Link to post Share on other sites
Ed Kennell 47,617 #11 Posted August 19, 2018 Same here Paul. The grass looks like April instead of August. I'm mowing 2X/ week …I usually mow every two to three weeks in August. We got "seat time". 1 Share this post Link to post Share on other sites
pfrederi 21,231 #12 Posted August 19, 2018 I tried to mow a bit but the water flying off the front tires got my feet wet.....May be time for the sickle bar when it finally dries out. Still have pools of water in the yard.... 1 Share this post Link to post Share on other sites
Sarge 3,473 #13 Posted August 20, 2018 We're about to get slammed with a major storm here, otherwise, it's been extremely dry. The issue this year is the water grass - it's gotten way out of control on most properties locally and that stuff is a pain to cut correctly as it likes to hold moisture (hence, the name) and plug up almost any deck design/brand. I need to get busy and make some baffles for my 48" - the left rear corner loves to plug up quickly no matter what the conditions are at the time. The other problem has been how the discharge side works - these 48" models love to throw the grass into the height gauge wheel and bar, then plug up the discharge area. Once it does that, the stuff just comes out in globs... Sarge 1 Share this post Link to post Share on other sites
Ed Kennell 47,617 #14 Posted August 20, 2018 I've been using the RD decks and mowing every 4-5 days. So far I have been able to get good distribution with no clean up needed. The decks are all going to need a good cleaning after mowing season. Share this post Link to post Share on other sites
Tankman 3,528 #15 Posted August 20, 2018 Deck off every winter. Clean ‘n paint if needed. Wettest late summer I can think of. Still mow but try for sunny, dry days. Lately rain it seems every other day. Share this post Link to post Share on other sites
