Schrec050584
Toro wheelhorse 520h
Kurt-NEPA
24 minutes ago, WVHillbilly520H said:
@Kurt-NEPA try this...
I'll check that out!
Thanks!
Edited by Kurt-NEPA
Schrec050584
Hey kurt, when you hook up the snowblower do you have to use the big spring for lift assist even on a hydro tractor?
cleat
Assuming you mean the 2 stage then yes, you need the big spring that mounts on the right side just under the front edge of the hood.
If not the blower will lift but it lifts crooked, also the spring helps the blower float over rough terrain and puts some
down pressure on the front wheels for better steering.
Schrec050584
I have a single stage blower
WVHillbilly520H
You don't have too, but I did when I had a single stage it really does help not only with lifting but actually holds that flag in the lift rod.
Kurt-NEPA
I didn't need the spring, so I left it off.  Works just fine
Schrec050584
Where can i find the rubber hold downs for the hood. Anyone?????
lynnmor
See this thread: rubbers
WVHillbilly520H
12 hours ago, WHX20 said:
Never heard of Royal Purple Jeff.
Jim, it's gearhead oil, was made formainly high performance engines with flat tappet cams when they started dropping the ZDDP levels because of emissions/ converters, Jeff.
Schrec050584
Hey guys anyone know what color i should paint the wheels for my 520h and also where i can find paint to do the deck belt guards? Thanks alot for all the help already given.
cleat
I guess that is up to personal preference but I use silver wheel paint.
This is exactly what I use. My wife works at TSC so we get a discount.
https://www.tscstores.com/STEEL-HIGH-PERFORMANCE-WHEEL-P18133.aspx
This is what my tractors and decks get painted with
https://www.tscstores.com/340G-EXCEL-AEROSOL-FARM--IMPLEMENT-HARVESTER-RED-PAINT-P6177.aspx
https://www.tscstores.com/PAINT-IMP-INTL-HARV-RED-946ML-P16783.aspx
Cleat
Edited by cleat
Schrec050584
Can anyone tell me what rear oil is used in a wheelhorse 312-8. 12hp Kohler motor
pfrederi
Gear Oil 80-90w or 75-140
Schrec050584
Engine oil for 12hp kohler is sae 30 right or can i run 10w 30 synthetic?
WHX??
Correct ...strait 30 weight although 10w30 syn will not hurt it. 10w might be the better choice for cold weather starts & running.
Schrec050584
How do you drain the gear lube in the rear of a wheelhorse 312-8
Edited by Schrec050584
cleat
Little flush plug underneath that uses an allen key to remove.
If, for some reason it is stripped I have drained it by loosening the big oil supply tube to the pump.
This is below the pump / cooling fan on the right hand side bottom.
The 520 uses an Eaton 1100 that uses the fluid in the rear end for it's oil so no separate oil drain is required for the hydro unit.
Cleat
Schrec050584
Sorry i was referring to the wheelhorse 314-8 i was also talking about
  • Similar Content
    • Brooklyn581
      By Brooklyn581
      Rear mount leaf collection system blower. Trailer with Canvas avail for an additional $100.
      $200 for both or Would trade both for a snow thrower attachment that mounts to the older style long frame for a Wheel Horse Charger 12. Upstate NY Pick Up only.
      Excellent condition. Even the decals are original.
