katanski 2 #1 Posted August 14, 2018 How do you remove the electric PTO from 522xi? Share this post Link to post Share on other sites
shallowwatersailor 3,220 #2 Posted August 14, 2018 I never had one off, but there is a clutch-stop bracket bolted to the engine block and a bolt into the crankshaft that need to be removed. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,978 #3 Posted August 14, 2018 Don't see anything in the 5xi service manual but here it is. Click on the picture first. Once the bolt and flat washer are removed from the end of the crank plus a bracket to stop the assembly from turning the clutch should pull off. Garry Share this post Link to post Share on other sites
953 nut 63,941 #4 Posted August 14, 2018 Most electric clutches are retained by a bolt in the end of the crankshaft. with that bolt removed you will find the clutch has internal threads (some are 3/4" and some are 5/8" bolt size). Running the correct size bolt into the threads will push the clutch off the crank shaft. Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #5 Posted August 14, 2018 , and might I add you'll either need an air or electric impact wrench or a socket on, a breaker bar and rubber mallet to help break the center crankshaft retaining bolt loose, then after you have loosened said bolt up (do not remove) as the old PTO is probably rusted to the crankshaft snout you'll need a 3 jaw puller to help getting it moving after you have it loose then finish removing bolt and clutch, Jeff. 1 Share this post Link to post Share on other sites
953 nut 63,941 #6 Posted August 15, 2018 This Thread by @pfrederi has a lot of useful information on electric PTO clutches. Share this post Link to post Share on other sites
katanski 2 #7 Posted August 22, 2018 (edited) Thank you everyone who responded to this questions. It can off easier than I thought it would. Everything just slid off of the crankshaft. Edited August 22, 2018 by katanski 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,978 #8 Posted August 23, 2018 This application is one that should get a coating of Neverseize on reassembly. You are lucky it can off with ease? Garry Share this post Link to post Share on other sites
katanski 2 #9 Posted August 28, 2018 On 8/23/2018 at 7:07 AM, gwest_ca said: This application is one that should get a coating of Neverseize on reassembly. You are lucky it can off with ease? Garry I literally pulled the parts off of the crank with my hands, It did get plenty of Neverseize when it went back together. Share this post Link to post Share on other sites
