Robertrueker 1 #1 Posted July 24, 2018 (edited) I have been trying to figure out what happened to the govener, I took the engine off to adjust the valves, it had a valve seat loose. I tipped it on its side to repair that. I then reatached the engine to the tractor. I go to hook the carb back up and it's like the govener wants to move backwards. In my hunt on the internet I found a video of the exact same thing my engine is doing and posted a link to the video. Any help would be appreciated thanks! Edited July 24, 2018 by Robertrueker Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,373 #2 Posted July 24, 2018 The video meant nothing to me and I have zero experience with the Onans. You realize a governor tries to reduce rpm and the spring between the throttle cable and governor tries to increase rpm. As rpm increases the force developed by the governor also increases. When that force equals the force developed by the governor/throttle spring that is the rpm you end up with. Garry Share this post Link to post Share on other sites
Kurt-NEPA 756 #3 Posted July 24, 2018 Have you hooked up all the springs? The governor adjusts the carb throttle by balancing the engine speed against spring pressure. Looking at the video, it seems normal to me. BTW, the manual has the procedure to set the starting point for spring positions. Check the manual section. Share this post Link to post Share on other sites
Robertrueker 1 #4 Posted July 24, 2018 The thing is when I hook up the spring it now pulls it in the opposite direction it wants to go if I hook up the linkages to the carb it won't move at all Share this post Link to post Share on other sites
Kurt-NEPA 756 #5 Posted July 24, 2018 Any chance you could post a picture of what you have? Share this post Link to post Share on other sites
Kurt-NEPA 756 #6 Posted July 24, 2018 This any help? Share this post Link to post Share on other sites
Robertrueker 1 #7 Posted July 25, 2018 Crazy thing is.. that was exactly how I had put it back on. In the first place. But I thought there had to be something wrong. I had the cable adjusted wrong so it would pull the lever but just would bottom out and not operate the carb. I adjusted the cable so it can use the spring to push as well as pull. It's working fine now. Thanks Guys I was having a moment there🤦 1 Share this post Link to post Share on other sites
