bumpsteer 38 #1 Posted July 14, 2018 So I replaced my brake lining and clutch spring (there were two small ones hooked together). Now I have developed a no start condition. I beleve it to be in the clutch safety switch or what wheel horse calls the pedal interlock switch. When it first started this I was sitting on tractor and had pedal pushed down and it would not start lifted off pedal and pushed a few more times and it cranked. Had this happen several times. Now it will not work. It starts fine by jumping solenoid. Where is the dadblasted switch located crawled under tractor and cant find it. I figured it would be someplace on the linkage. Help please. Doug Share this post Link to post Share on other sites
Racinbob 10,256 #2 Posted July 14, 2018 Yours is on the right side of the transmission. It is actuated by the idler arm. Share this post Link to post Share on other sites
bumpsteer 38 #3 Posted July 14, 2018 Thanks, I found it. Had to remove the shifter plate to get to it but its fixed now. Share this post Link to post Share on other sites
tunahead72 2,332 #4 Posted July 15, 2018 Just curious... What did you do to fix the problem? Share this post Link to post Share on other sites
bumpsteer 38 #5 Posted July 21, 2018 I removed it and sprayed it with WD to break the crud up then sprayed it down with contact cleaner use 600 grit on the spades and reinstalled. 1 Share this post Link to post Share on other sites
