Pullstart
Shop project...
Handy Don
13 hours ago, Pullstart said:
e-tank?  Luckily it’s surface rust… mostly.  Some of the sheet metal is soft underneath, but the frame is solid.  I know it’s all relative, but remember a few years back I scrapped a ‘99 Silverado with 92k miles because the frame was junk.  I’m happy with this, and aware of what bad is..
Salted roads and winter driving? If that was a coastal truck, I’d suspect joyrides on salt water beaches or splashing through high-tide puddles.
Pullstart
Possibly it was at one time, but not in the last 20 years at least.
Pullstart
This was fun… the other week we had a slide out drive apparatus fail.  I couldn’t stomach the replacement cost, so I dove in.  I was into this repair for $50 and in my experience it has never worked so well before!
  • Excellent 3
Pullstart
How do they say it?  You can wish in one hand and want in the other and see what fills up first.
Stock S10 axle is a 7.5” GM 10 bolt.  I found a 71 Nova 8.2” 10 bolt on Marketplace for $75.  It’s the width I want, bolt pattern I need, and the 3.08:1 ratio I desired.  It’ll need perches cut off and welded on for the correct width and I need brakes.  I’m curious if I can use the S10 brakes on the Nova axle.
953 nut
As long as the backing plates will bolt up I don't see why they wouldn't.  :twocents-02cents:   Long term I would gather parts and pieces for disc brakes all around.
ebinmaine
Why not just use Nova brakes on the Nova axle?
Pullstart
It doesn’t have any brake components.  I either build all new, or use what I have.
You’re talking to a guy who loves the 4 wheel manual drum brakes on his ‘69 C10 :lol:
  • Haha 1
adsm08
The rest of us prefer actually stopping.
I will say, drum brakes do have some advantages. In 200K miles my Escape never needed the rear brakes replaced, and the last time I inspected them they were barely even worn from new. They are also better at holding back against torque than discs.
The 4-wheel disc brakes on my Ranger can't stall the engine in 4-low/1st.
8ntruck
:text-yeahthat: drum brakes have some degree of self energizing designed into them.  Depending on the geometry of the lining material, shoe pivot location and shoe length, the torque generated by the brake can actually apply more normal force between the shoe and drum.
In resistance to brake fade, the disc brake is much better than a drum brake.  The disc brake sheds heat much better than a drum.
Pullstart
The video of the broken diff…
Pullstart
@Handy Don I believe I mistook your question on post 1051.  I read that as a question towards the S10, but I believe it was based on the ‘99 Silverado in the quote.  Yes, the Silverado was used mainly for winter driving previous to my purchase.  It was 15 years old when I purchased it with 34,000 miles.  The original owner bought it new and plowed his driveway with it.  I feel like possibly he had another low mileage summer vehicle as well.
Pullstart
This is my mathin’ on gear and transmission changes, what it should do for engine rpm vs tire speed.
None of which can be proven, without a tachometer that the truck doesn’t have, or a full tank of fuel through it to calculate fuel mileage.  I also now have the issue of a mechanical cable speedometer and an electronic speedometer on the transmission tail shaft, and the gear change.  I might end up sticking a tach in, and paint marking the common speed limits like 25, in third, 55, and 70 in OD.
Pullstart
I’ve also been fighting a stumble or hesitation off idle.  I saw a video yesterday on tuning and it was mentioned that today’s fuel with 10-15% ethanol requires about 4 degrees advance over ethanol free fuel.  That ethanol ratio probably changed at the pumps since this was daily driven all those years ago.
squonk
Shoes are different between the 2 and you're fighting the Holley off idle mixture  transition to low speed  stumble. Timing may help but I'm almost certain it's fuel related
adsm08
I had an Omega with a 3800 right around the time ethanol fuels became common. I fought that same issue for a while with little success before I found a station that kept e-free fuel on hand and just gave up.
Edited by adsm08
CRF857
  • Haha 2
CRF857
  • Haha 2
adsm08
3 hours ago, CRF857 said:
C/S "engine is missing".
Tech notes: Unable to verify, opened hood, visually inspected, found engine to be in proper location. Started and noted engine runs rough, recommend diagnosing.
  • Haha 2
  • Similar Content
    • DennisThornton
      By DennisThornton
      1947 Empire (Jeep) Tractor
      The Empire tractor consisted of military power components from World War II-era jeeps. It had a 4-cylinder, 40 hp Willys-Overland engine, a Model T-84 Spicer 3-speed transmission, Spicer transfer case with high and low speeds, Willys rear end, steering column and gearbox. It also had PTO, individual clutch-type rear brakes with a stop provided for parking and a rear belt pulley. The fuel tank and an Empire-style seat were mounted on a large operator's platform (made from Navy ship decking). Its simple, basic gauges (ammeter, oil pressure and temperature), ignition switch and starter button also came from the jeep. The Empire tractor was originally made for exportation in the Lend-Lease Program after World War II.
      If I had to mention a couple of things that made the Empire Tractor really unique, one would be the straight bar hitch that pulled from under the center of the tractor (patented) thus making an overturn nearly impossible. The other selling point was, of course, the Willys engine and drive train made famous in the Jeep during World War II. The Empire was a well equipped tractor, very reliable and versatile with its wide range of speeds. Today this tractor draws a lot of attention at shows and is very sought after by collectors commanding higher than average prices.
      $5k
    • CRE1992
      By CRE1992
      Well fellas I decided to buy a jeep wrangler as a new toy. I have always been into the off-roading scene since I was a kid. I always loved trucks, jeeps, atvs. Recently a friend of mine traded his mustang for a lifted wrangler and its a blast to go off-roading in or wheeling as they like to put it.
      I couldn't help myself and wanted to join in so I bought a 1993 with 153,000 miles on it with a ton of add ons for a great price. It has a 5.5" suspension lift, a 2' body lift and rides on 35" tires. She has 4.56 gears which are awesome for crawling, 4wd low range and 1st gear and you don't even have to touch the gas pedal. It is a 4.0L 6 cylinder engine back by a 5 speed manual trans. The rear drive shaft is a custom cv drive shaft with a slip yoke eliminator. The rear axle is a ford 8.8 limited slip with disc brakes out of a ford explorer. The frame is perfect not a spec of rust and was coated with POR-15.
      She does have her fair share of issues but I am working on getting those straightened out! I just had the front drive shaft rebuilt and balanced. I ordered all new extremely heavy duty shocks. I need to fabricate 2 custom rear shock mounts as the "custom" ones that were on it broke off lol. She needs 2 new leaf spring packs in the rear. Some body work. A good cleaning after this weekend. Some fender flares. Etc!
      If anyone has any good oh crap off-roading or wheeling stories with their jeeps or pictures please share. After this past Sundays experience I could probably top them lol.
      I hope you enjoy the pics and the video my jeep was the main attraction. (I did not edit the video a friend did, so turn down the volume or the music might scare you)
      LINK FOR VIDEO: http://s1201.photobucket.com/user/silveradostud/media/Jeep%20Fun/IMG_31371_zps0e82da88.mp4.html
